Todmorden Curve
61653 HTAFC
18 Dec 2012
Does anyone on here know what's the most likely traction to be used on these services?
Will the Todmorden Curve be too tight for a Class 142, even though the curve will have a check rail?
I think one of the reasons the original alignment couldn't be used was that it was unsuitable for 23m stock running in more than single-car formations (155/156/158s), so the 'new' curve is at least less sharp than the original.
driver9000
13 Jan 2008
Not sure if it has been mentioned but I see the new junction on the East Lancashire line between Burnley Manchester Road and Hall Royd Junction leading onto the curve has been named Stansfield Hall Junction.
IrishDave
30 Jun 2009
Brighton
Interesting - the new edition of Quail track diagrams book 4 (published this week, my copy arrived yesterday) names it as Whiteplatts Jn! What's your source?
NotATrainspott
2 Feb 2013
One hopes they've built it with an eye towards eventual electrification as well.
I wouldn't imagine Network Rail doing anything without passive provision for electrification now since they would be footing the bill for fixing their own mistakes.
Signalling diagrams I have seen have it as Stansfield Hall Jn too.
Darren R
26 Jan 2013
Lancashire
Whiteplatts Junction? Where have they got that name from - it hasn't been called that since 1895!
Darren R
26 Jan 2013
Lancashire
Was there not a Lancashire and Yorkshire Railway signal box of that name in that period which was later replaced by the Stansfield Hall signal box ?
There was indeed - situated in the V of the junction. It closed in 1895 to be replaced by a new box on the other side of the tracks. I believe that's when the junction was renamed Stansfield Hall.
Sox
22 Oct 2010
Maybe they have reverted to an even earlier name to avoid confusion with the last name (unpurged records can be a real engineering issue, e.g. drawing title blocks, wiring diagrams etc).
But surely the junction is the old junction, even down to retaining the S&C for the loco siding and crossover, so renaming it will just cause confusion?
Signal Head
26 May 2013
The Sectional Appendix doesn't name the junction, but the engine spur is named as Stansfield Hall. The signalling plan (for the existing layout) also doesn't give a name, presumably because it ceased to be a 'real' junction when Preston PSB was commissioned.
The siding area has always been known as Stansfield Hall since then, that's what I expect the new junction to be called, and is what is shown on the drawings I have seen.
L+Y
4 Jul 2011
Ah, this is something I'd always wondered.
The original Todmorden curve was closed in 1972/73, then?
Any idea when the last trains ran over it?
Signal Head
26 May 2013
Not the last train, but the list of closed lines formerly held on the Rinbad site lists Todmorden East Junction to Stansfield Hall as 'taken out of use' on 31/3/73. The 'Junction' suffix seems not to have been applied to SH box, according to the naming in the Preston stage Section C notice.
The area was resignalled onto Preston PSB in October of that year.
Darren R
26 Jan 2013
Lancashire
So Saturday, 9th November is now the starting date for these works.
That's the plan - posters advising of the closure went up at Blackburn station last week (guessing that's where the Lancashire Telegraph journalist got the story from! :lol:)
With a stated closure period of 20 weeks that makes for a re-opening date of 31st March by my reckoning. How long will be needed for route learning, and from which depots will the crews be drawn? I'm guessing the first trains over the curve will be spotted by the end of March.
Just read a posting on the Manchester - Liverpool Electrification thread, part of which is relevant here:
Originally Posted by WatcherZero
The Todmorden Curve will be completed in February, Lancashire CC has agreed to TfGM request that the new Blackburn, Accrington, Burnley, Manchester via Todmorden service will call at Littleborough offpeak however there wont be any DMU available to operate these extra services through to Blackburn until Dec 2014. So from May 2014 until Dec 2014 as an interim measure the Kirkby-Wigan-Rochdale service will be extended to Todmorden and then reverse on the curve, in addition the two evening Victoria-Rochdale services will be extended to Todmorden. From Dec 2014 the Manchester-Todmorden service would be extended to Blackburn though it isnt clear if that would continue as an extension of Wigan/Kirkby-Rochdale or an entirely new service between Manchester and Blackburn.
So it's going to be December before services start because of a lack of units. I can see there being major ructions from the local press, politicians and rail user groups.
Xenophon PCDGS
17 Apr 2011
So it's going to be December 2014 before services start because of a lack of units. I can see there being major ructions from the local press, politicians and rail user groups.
I can see this news raising a smile on the faces of those who are tasked with the continued operation of the X41 bus service from Blackburn to Manchester.
