Elecman
Heyrod located just East of StalybridgeWhere’s the nearest Feeder Station to Stalybridge?
Probably not cleared Ardwick-Guide Bridge-Stalybridge either, and that will need doing as well.Only hauled (non-passenger service) into Victoria (and through to Miles Platting Jn). They are cleared for passenger service from Deal St Jn to Windsor Bridge South Jn (i.e. through Salford Central) which I don't think has ever been utilised.
Obviously cleared from Windsor Bridge South through Ordsall Lane, Water St and Castlefield.
Both 802s and 331s have pantograph monitoring, although it may be cheaper and more flexible to use the in-house testing consist.I think there are now other trains with OHLE monitoring capability, possibly 802 (or other 80x)? 802s are cleared on both routes
Lets hope common sense prevails or that will be another example of millions wastedCorrect. When fully wired it has been suggested they keep the cable in to remain as an independent grid feeder.
As I understand it (going from memory of posts by Joseph Locke years ago) there was never any official suggestion of removing it, only people on here talking of removing it. If it were removed, any work in the Stalybridge area, requiring both routes to be switched off, would cut off a major source of power to routes like Manchester-Preston.Lets hope common sense prevails or that will be another example of millions wasted
Anyone know what this is about?
Transpennine route upgrade suspended?
Is it just the leeds area or the full line?
Seems funny there's northern trains running to stalybridge when the line should be shut for electrification work.Sounds like overinterpretation of a specific incident or issue in a particular possession to me.
Guide bridge line is closed, replacement buses on.If that has been amended its been done at least a week ago as the schedules are all WTT, I can't find any suggestion anywhere that Stalybridge was supposed to be closed today.
It's a safety stand down due to a fair few incidents. That's what I get from the tweet anyway.Sounds like overinterpretation of a specific incident or issue in a particular possession to me.
It's possible (I don't know) that the Stalybridge electrification team will start work on Lostock-Wigan next.Sad that on the basis it will have be done sometime the opportunity wasn't taken to keep the piling team on to keep heading east
It's always been the plan that the section East of Stalybridge would be among the last to be done, due to problem tunnels and those houses at Mossley. There'd be little point in putting masts up if they have to be moved later because the track has been lowered or realigned.Sad that on the basis it will have be done sometime the opportunity wasn't taken to keep the piling team on to keep heading east
Is there more or less tunnels on the stalybridge line compared to the calder valley line.It's always been the plan that the section East of Stalybridge would be among the last to be done, due to problem tunnels and those houses at Mossley. There'd be little point in putting masts up if they have to be moved later because the track has been lowered or realigned.
It's not really about the number (or even the length) of tunnels, but the clearances (or lack of) in some of the tunnels. IIRC from previous discussions on this thread, the problem tunnels are Stalybridge tunnel (just to the east/north of the station) and Scout tunnel near Mossley.Is there more or less tunnels on the stalybridge line compared to the calder valley line.
Not been down that line for a while, always get the northern trains to manchester now since TPE have an habit in cancelling trains.
From Manchester to Leeds the Huddersfield/Dewsbury route has 6.03 miles of tunnel in 7 separate bores.Is there more or less tunnels on the stalybridge line compared to the calder valley line.
There was some discussion of this on page 13 (the current page) of the Lostock-Wigan thread. Piling started on that route simultaneously with its completion around Stalybridge. I've no idea how far we are from a start on masts.It's possible (I don't know) that the Stalybridge electrification team will start work on Lostock-Wigan next.
It seems like design work for electrification from the Church Fenton North Ladder to Leeds is much further along, with plans for bridge replacement or removal and level crossing removal being out in the public domain, whereas such works aren't visible for Leeds to Dewsbury. East of Leeds has to grapple with remodelling the area around Neville Hill and reconstructing the viaducts between Richmond Hill Tunnel and Leeds station, whereas West of Leeds has to grapple with modifying Morley Tunnel to accommodate the wires, both of which seem as challenging as each other.Keeping the Piling team going, looking at the Don Cofey videos, Leeds to Dewsbury ought to be straight forward as much less effected by works futher west and the major job of moving Morley station has been done. An electric shuttle from Leeds to Dewsbury using the Batley East crossover would then be theoretically possible, if unlikely in practice.
Failing that there's always east to Hull...
The closed Spen Valley route bypassed the Morley tunnel but had the Gomersal tunnel instead which was 1.4 miles shorter at 0.51 miles.
Answering my own query.One massive long portal, over both Huddersfield lines and the full width of the Sidings on the Up Side at Guide Bridge. That one is strange, I very much doubt the Sidings will be wired.
When will they finish putting up the wires on the guide bridge line?Answering my own query.
This portal now looks like it carries a 25kv feeder from Guide Bridge, along the upside of the Sidings, over the Sidings and Huddersfield lines, and onto the Down Huddersfield side.
Once all the steelwork and small parts are up the actual running out of the catenary and contact wires and registration of the contact wire would be a quick exercise over the relatively short distance here,When will they finish putting up the wires on the guide bridge line?
Do you know if there are any plans to wire any of the roads in the Yard, or the curve and Loop onto the Glossop Line?Once all the steelwork and small parts are up the actual running out of the catenary and contact wires and registration of the contact wire would be a quick exercise over the relatively short distance here,
