Trivia: Which station has the curviest platform?
KevinTurvey
9 Oct 2016
The gap at Earlestown can be quite bad especially on a 150, it would be very easy to have a tumble if not looking where you're going.
I recall one of the platforms at Shipley is quite bendy too.
23 Jan 2013
East Anglia
The Sudbury branch platform at Marks Tey had extensions built onto it when 150s used to work down there, as the gap between the platform and the doors on a 150 was considered too great. Came with a 5 mph speed restriction too. They've gone now as 153s and 156s work the route with doors at the end of the coach.
mcmad
11 Mar 2015
Some sections of the lower numbered of the platforms at Glasgow central are under 200m radius, Inverness as already mentioned and Burntisland are also up there.
gallafent
23 Dec 2010
Can I have Farringdon Thameslink, with its right-left-right curve? Although perhaps not as tight as some, surely three curves on the same platform counts for something? ;) (seen here facing south …)IMG_5344.JPG
Anvil1984
28 Aug 2010
I didn't realize it was the bit shared with the Metro that's the problem (I'd read that it was Hartlepool and believed what I read); though I'd be surprised if it was clearance issues, based on the fact that the 950 goes down there (and on the metro only line to South Hylton, see this photograph (not mine) https://www.flickr.com/photos/northeast_rail_photos/26985753831/in/photostream/ )
Yes however as I mentioned the 950 is limited to 40mph between those points and probably has modifications to enable it to run where normal 150s can't. 150s are technically allowed to run full Durham Coast line in passenger service barring Sunderland South Jn to East Boldon where it's not allowed to even run ECS. Anyway getting off topic now
mrcheek
11 Sep 2007
Weston-super-Mare has quite a curve.
As for gaps, the worst Ive experienced has to be Platform 3 at Bristol Temple Meads, very dangerous at times
Coolzac
8 Nov 2014
Grosmont on the Esk Valley? Pacers have been known to get stuck on that tight curve!
Coolzac
8 Nov 2014
Here is a picture of Grosmont for those who haven't been...
Harbouring
20 Jul 2017
Fratton has a lengthy curve too, I presume this is why the cameras and monitors were installed to help dispatch?
philthetube
5 Jan 2016
If you take the thread title literally, "curviest" then it must be Farringdon, as mentioned earlier, unless someone can beat three curves.
Hamilton square, Liverpool Central stations
At a guess the worst section on Merseyrail is the stretch between Green Lane and Birkenhead Central, with sharp reverse curves.
Birkenhead Central platform itself isn't quite as bad, however.
Many of these sharp curves are the result of joining up a pair of previously straight routes, converging nearly at right angles.
That's why Earlestown and Bristol TM got their curves, also York.
The Warrington & Newton was initially laid out with a junction facing Liverpool at Earlestown, and the sharper Manchester curve was put in later as an afterthought.
It's the same a short distance away at Parkside, where the easy junction for the Wigan Branch Railway facing Manchester was put in first, and the much tighter Liverpool curve much later (through the sharply curved Lowton station).
The LNWR eventually built the Winwick-Golborne cut-off on the WCML to avoid the two sets of slow curves.
At Bristol, the curves joined the original GWR to the Bristol & Exeter, and at York they joined the York & North Midland to the York & Newcastle.
Harbouring
20 Jul 2017
Portsmouth and Southsea has maybe 3 or 4 curves but I’m sure there are stations that might have more.
Hornet
16 Jul 2013
A few more Check Rail Chafers off the top of my head.
Forres.
Penistone.
Whitehaven.
Narberth.
Calstock.
Hinchley Wood.
Virginia Water.
Sutton.
Plockton.
Exhibition Center.
Ryde Esplanade.
Barnt Green.
The one below is with us no longer:-
And this one has moved:-
Dr Hoo
10 Nov 2015
Hope Valley
Forres (another one-time triangular) recently re-positioned to a straight alignment.
Bantamzen
4 Dec 2013
Baildon, West Yorkshire
Re Shipley, platforms 3-4 are probably the least bendy of the lot, P1-2 are probably in the middle of the set with very noticeable gaps on P2 (towards Skipton), and P5 is for me the most bendy of them all, sometimes you feel like you need mountaineering gear to cross the gaps!! (Well OK maybe a slight exaggeration). It hard to tell if this is up there as the bendiest though, it's relatively short length means its hard to compare to something like Poole.
Definitely. I think because "curviest" wasn't ever defined, having reverse curves through a platform must be curvier than a single curve whatever the radius...
Crossover
4 Jun 2009
Shipley p5 is quite a curve, so much so there is a marked location for the guard to despatch from under the Off indicators against the station wall - it is about the only place where there is a chance to see all 4 coaches at once. The other platforms there don't strike me as particularly bad in that regard. The aforementioned platforms at Earlestown similarly.
One that hasn't come up so far, and to be fair only applied to one end of it (around 50m near the buffers is pretty much straight) is Scarborough p3 - because 185's have the doors at 1/3 2/3, there is quite a gap between the train and platform edge for the front coach (of a 3 car)
Crossover
4 Jun 2009
Interesting to see that the 150 is cleared to South Hylton - have any ever run up there?
Regarding the 950, could it be that is doesn't have door plates/sills that could foul something?
