DarloRich
Not many people use them for the entire route though. Many people use Cross Country for regional journeys.
I dont! I would also disagree that there are not many people using the service for long distances.
arrrrrrrrrrrrrrrrrrrrrrrrrrrrrrggggggggggggggggggggggghhhhhhhhhhhhhhh
YOU CAN NOT POLISH A TURD!
you can change the bloody carpet all you like but they still rattle true, they are still uncomfortbale a matter of perception and they are still too smallnot long enough - solved by doubling up - or too small inside - a function of the ability to tilt? both arguable.
Try a long run, say Edinburgh - Plymouth and tell me you like them. :roll::roll:
I shall be impressed when they are destoryed. Or at least moved on to more suitable services away from me!
that isn't a rant it a factual observation!
I just do not think they are appropriate for the services upon which they are used.
Not everyone in the South West lives in Exeter though. For some it can be a long journey just to get to Exeter.
There is a logical disconnect between your first sentence which itself is at least partially arguable - see my bold comments - and your second sentence which is your belief "I....do not think" which others might not share!!!
That's not really a rolling stock issue though, as demonstrated by the rather better catering on the Virgin Voyagers.
Is there space on a current XC Voyager to install a proper buffet? Probably, but not without reducing the number of seats even more, and the last thing a Voyager needs is less seats.
Well that's the thing, isn't it, a classic case of damned if they do, damned if they don't. People used to complain that Virgin's "Shop" was a waste of space, so XC convert it to provide more sears, and then complain that there's not a buffet ....
Doubling up of services though does not detract from the fact that the units themselves are too short. Long distance Inter-city train services should not be split into separate portions (Try not to recall the APT-P here, shush ): It limits passenger circulation, causing imbalances in passenger loading rather than passengers distributing themselves more evenly throughout the train after it has started moving, and also causes inefficiencies in staffing.not long enough - solved by doubling up
It is not just the tapered body profile of a Voyager (which I don't think is particularly pronounced or noticeable anyway, admittedly) that can lead them to appearing "small" inside: As well as the short overall length of the entire train, the carriages themselves have been poorly designed to make good utilisation of the available space. The passenger doors are located a considerable distance inboard of the vehicle ends. This allows the vehicle ends to taper inwards, which has probably admittedly allowed the main length of the Voyager vehicles to be slightly wider than they otherwise would have been, but is a substantial enough distance to essentially reduce the useable space between the passenger doors to that of a 20 metre carriage rather than a 23 metre one. And on top of that, each carriage, except the vehicle with "The Shop", then has a capacious disabled toilet fitted, eating into the remaining available space for passengers when only one in each driving car probably would have sufficed.- or too small inside - a function of the ability to tilt? both arguable.
Given that Electrostars and Desiros are outer suburban EMUs only, I would hope that it should go without saying that the seats on trains of the longest distance Intercity operator in Britain would be of a better standard than those found on an outer suburban EMU! Clearly seated comfort is a matter of personal preference, but in my opinion theres not much to recommend the Voyager seating over the seats in LMs 350s in terms of padding, although the Voyager seats are at least superior in the amount of back support they provide, even if they still remain too narrow and have less than perfect pitch for Intercity services IMO.Voyagers are decent, fast, trains that are quick off the mark, with actually quite comfy seats (better than the bits of wood on some Electostars/Desiros). The only downside is that they are too short.
This statistic is borne out in practice as well: Crosscountry trains witness significant passenger churn rates at Bristol, Birmingham, Sheffield, Leeds/York (depending which way the train is routed), Newcastle and Edinburgh, where perhaps as many as 60 75% of the passengers on some services will alight and be replaced by others at these focal nodes.Not many people do this though. The average journey length when the franchise was let was just 81 miles and I'm not sure a buffet would be justified for a journey of this length.
Wait til you get to 6' 2" and then you'll start complaining
It was based on Virgin Cross Country.If the average journey within the franchise is 81 miles as stated above then the average journey on XC services proper (ie Voyagers) will be much longer than 81 miles - the ex-CT 170 services will account for lots of shorter journeys which would bring down the average considerably.
