West Midlands Day Ranger
Discussion in 'UK Railway Discussion' started by gnolife, 13 Nov 2011.
Thread Status:
  1. gnolife
    gnolife Established Member
    1,627
    4 Nov 2010
    Johnstone
    Hi guys
    I'm planning on doing a WMDR on Saturday 19th November. Can anyone tell me if the attached plan is reasonable for me to do (I'm a pretty fast walker usually), and if so, what classes of train I'm likely to find on it.
    If its unreasonable, can you please tell me what the problem with it is, and if possible, an alternative way for it.
    Thanks
    Dan :D
    EDIT: Forgot to mention that its starting at Crewe, but that shouldn't make much of a difference
    Rail Forums
  3. MidnightFlyer
    MidnightFlyer Veteran Member
    12,827
    16 May 2010
    You may need to get a spurt on between Moor St and New St for your LTV train, 9 mins is ever so slightly too fine platform to platform.
    The rest looks fine though :D
  4. IanPooleTrains
    IanPooleTrains Established Member
    1,216
    21 Nov 2010
    Brereton, Rugeley, Staffordshire
    It looks feasible however, I am going to bring up an issue
    IIRC, you can't use the WMDR between Coventry and Leamington Spa, you can use it from Moor Street but not Coventry I don't think
    It's easily doable, I am eighteen and a half stone and can do it in just under five minutes from station to station and, without seeing gnofile, if he is lighter than I am, he can do it quicker
  5. MidnightFlyer
    12,827
    16 May 2010
    Allowing for late running, traffic lights, ticket gates...
  6. Tomonthetrain
    Tomonthetrain Established Member
    1,290
    12 Jul 2011
    I've done it in 6 minutes from new street p4c to moor street p1 So its possible
  7. IanPooleTrains
    1,216
    21 Nov 2010
    Obviously allowing for that it is a bit of a push but I shouldn't think it is going to be too much of a problem
  8. sonic2009
    sonic2009 Established Member
    4,121
    19 Jan 2010
    Moulton nr Winsford
    West Midland Day Ranger is valid from Coventry - Leamington Spa via XC.
  9. gnolife
    1,627
    4 Nov 2010
    Johnstone
    I'm using http://www.nationalrail.co.uk/managed/promotions/pr9cb0cc0a040004006ad8690e40c16f/areaMap/West_Midlands_Ranger.pdf as a guide to where its valid, and that suggests that Coventry -> Leamington is valid
    As for Moor Street -> New Street, the train I change onto at Lichfield City, calls at Birmingam New St 10 mins after the one I'm planning on catching from New St - I'm trying to get as many stations as possible as the reason for the changing services at Lichfield City
  10. IanPooleTrains
    1,216
    21 Nov 2010
  11. Crossover
    Crossover Established Member
    7,777
    4 Jun 2009
    Yeah, I've used WMDR between Coventry and Leamington Spa a few times before so you should be fine...at the end of the day it makes no sense as to why it wouldn't be valid
    Not sure about the rest of the plan as using app at the moment so will have a look when on the laptop :)
  12. headshot119
    headshot119 Established Member
    1,724
    31 Dec 2010
    Cardiff
    I've also used a WMDR between Leamington Spa and Coventry and not had any issues.
  13. raildude
    raildude Member
    95
    24 Oct 2011
    Nantwich
    This is another map from London Midland
    [​IMG]
    Shame that Shrewsbury-Crewe isn't on it really.
  14. IanPooleTrains
    1,216
    21 Nov 2010
    Just thought, I could have been thinking of the Great Escape ticket
  15. eMeS
    eMeS Member
    475
    12 Jun 2011
    Milton Keynes, UK
    Not knowing anything about modern rover tickets, I Googled the initials you used, and came up with this:
    Worlds Most Dangerous Road
    Ouch!
    It's still transport - even if not the type we all know, and love...
  16. dvboy
    dvboy Established Member
    1,835
    6 Sep 2011
    Or the Network Daytripper Plus.
  17. gnolife
    1,627
    4 Nov 2010
    Johnstone
    Alright, thanks all for confirming that my plan is somewhat realistic.
    What classess am I likely to be seeing while I'm there?
  18. Lrd
    Lrd Established Member
    3,018
    26 Jul 2010
    This is just of the top of my head, one or two might be wrong, I just worked down your plan
    1. Virgin Voyager
    2. ATW 175 or 158 (Think it's more likely a 175)
    3. LM 170/323 (Not sure what goes up to Shrewsbury)
    4. LM 172
    5. LM 139
    6. LM 139
    7. LM 172
    8. LM 170
    9. XC 220/221
    10. LM 350
    11. LM 153
    12. LM 350
    13. XC 220/221
    14. CT 165/168
    15. LM 170 (Not sure about New St - Lichfield)
    16. LM 350/323
  19. Crossover
    7,777
    4 Jun 2009
    I have just had a look at the plan and generally it looks OK.
    If you can move quick the 9 mins from Moor Street to New Street should be fine (afterall, you and bb21 made the cross Pontefract connection at the WY challenge! :))
    The Droitwich Spa could be dodgy if the train is running at all late - but it is only a cross bridge connection (make sure you are at the back of the inbound service to be closer to the bridge :))
    Another note on that - if you make the PPM move you have planned, when you get back, there is an xx:02 service as far as Kidderminster I believe (pretty sure we used it) which turns round and returns - it all depends what you are after.
    As for traction:
    1. Probably VT 221, though there is a chance of a Pendo (see frequently requested diagrams thread)
    2. Almost certain a 158 - not sure if 175's run up the line to Telford (happy to be corrected though)
    3. 170 (not electrified beyond the VT depot in the Shrewsbury direction so no chance of much else)
    4, 5, 6 and 7 - as above (unless you get really lucky and a lone 150 turns up on 4 and 7)
    8. As above
    9. May be a 170 - not sure if Voyagers run the Nottingham - Cardiff route
    10 and 11 - as above
    12. Could be a 323 or 350
    13. As above
    14. As above unless it is a loco hauled
    15 and 16 - LM 323 on the X-City (some terminate "short" at Lichfield City)
    17. LM 350
    Also - be prepared for last minute changes on the day - I've rarely had a day on a WMDR/Great Escape go completely to plan!
  20. gnolife
    1,627
    4 Nov 2010
    Johnstone
    And it nearly killed us :D
    Thanks for the help guys :)
  21. Crossover
    7,777
    4 Jun 2009
    What doesn't kill you makes you stronger, right? :P
  22. Jollycam
    Jollycam Member
    29
    18 Mar 2010
    Warwickshire
    Indeed... and to say that the non validity on XC isn't publicised very well is an understatement!
  23. gnolife
    1,627
    4 Nov 2010
    Johnstone
    Oh, and another thing
    How far ahead can I buy my ticket? (Ideally, I'd like to have chance to make seat reservations for any trains possible)
  24. Crossover
    7,777
    4 Jun 2009
    Not sure there are any limits...I've bought mine a day before and in Yorkshire so you should be OK
  25. bb21
    bb21 Moderator Staff Member Moderator
    23,389
    4 Feb 2010
    God I hope he is not 18 and half stone, otherwise we all have no chance.
    No, it didn't. I was fit as a fiddle. ;)
    You'll only get reservations on possibly 1, 2, 9 and 13. Not really worth it I reckon.
  26. dvboy
    1,835
    6 Sep 2011
    It is better since I complained here about it previously.
    Re classes, agree with above mostly - train 2 will be a 158, 9 will be a 170, 12 and 17 will be a 350.
Thread Status:
Share This Page
