Cause was identified as a dead pigeon jammed in a semaphore. Luckily marksmen were on hand.
If it was already dead, why we're marksmen needed?
Just out of interest do drivers receive any training to try and get their trusty steeds running again? For obvious reasons I'm considering diesel loco's and DMU's here. I'm just thinking that on somewhere like the S & C where a rescue loco is several hours away it might be worth trying to restart a loco / DMU rather than declaring it a failure on the windswept fells!
(Actually, on a serious note, I have seen a boot be used to try fix a Pacer door before!)
It also works on 455s doors as well!![]()
Although many buses don't have door interlock like trains (let's not get that HST argument involved in this threadI've also seen it used on a bus many years ago
The average malfunctioning Networker door can occasionally be fixed with a sharp prod of an umbrella and then wiggling bits of the mechanisms in a generally irritable manner. Waving one's hands around and muttering at the same time has no ill-effects. Gentle prodding is usually less effective as it seems to make everything even more broken. This is all from experience...![]()
Personally, I would stay on the train until instructed to get off by the appropriate member of railway staff.
but, that is just my opinion.
I wouldn't wait for an instruction if there were flames coming toward my backside![]()
Because the pigeon was what caused the signal arm to get stuck. The marksman shot the dead bird causing it to fall allowing the signal to move.If it was already dead, why we're marksmen needed?
With regards to people 'self evacuating' the train, wasn't there an incident a few years ago, where a passenger evacuated himself from a HST that was on fire,& got struck by a train going the opposite way?...
I cant remember where & when this happened though, but I remember reading about it somewhere.
Was on a 150 at Rochdale. We kept trying to close the door because it was chilly - pressed the close button, the door took a long time to close, then closed so quickly it bounced back and opened again. This happened every time.Although many buses don't have door interlock like trains (let's not get that HST argument involved in this thread) so when it last happened, the driver just let the door stay open!
One time I fixed a Networker door by pressing the open button!the doors were just going from 1/4 open to 3/4 open and cycling back and forth after someone pressed the Close button as they left, don't know if that had anything to do with it but there was certainly nothing stuck in it. The doors started closing then the hustle alarm sounded as the driver had pressed the close doors button, this seemed to stop the doors closing, or re-opening. Very odd!
From what I remember those who did self-evacuate jumped out on the track side rather than the cess side, you'd have common sense would suggest if you're going to jump out of a train you do it away from the other running lines.
What if it's quad-track and you're on a centre line?
I think with modern EMUs the instructions state "switch it off then back on again!" - certainly seemed to be the case when the 390 I was aboard suddenly stopped in the tunnels outside New Street and the power went off - it seemed to just reboot and we were on our way!
