Whats the up coming timetable changes to Southern/Gatwick Express?
LudwigTails
31 Mar 2023
Brighton
So far the changes I have heard that is more noticeable to Southern as follows:
the ones with ? is i am unsure.
387s (dunno would they be /1 or /2) will appear more frequent on the west coastway route?
Brighton to Hove shuttle to be reduced to be only Sunday only
GX are finally going to get back 12 carriages on weekday + Saturday running?
I heard also that (some) 387/1s are coming to Southern (would it be with southern right when the timetable changes happen?)
Are there anymore major changes thats going to happen?
CarrotPie
18 Mar 2021
̶F̶i̶n̶l̶a̶n̶d̶ Northern Sweden
There's more info here and here.
The thread about additional units (379s) for GTR mentions that the first doesn't arrive until October, it’s not going to change anything in June. You’re probably 6 months too early for that to filter through to diagramming.
Also, the West Coastway only sees two 387/1s from June, according to posts in the dedicated thread about the fairly significant SN timetable changes on that specific area of route. A diagram in post #166 attempts to show where the different sub-classes will eventually be used:
(Although there’s also a limited amount of info about it buried in the national June timetable thread, already linked by @CarrotPie).
CarrotPie
18 Mar 2021
5 May 2023
Portsmouth
All of these are correct, good to see the Hove shuttle is gone, bit pointless IMO
LudwigTails
31 Mar 2023
Brighton
for some reason it seems to show an error when i click the links in post 166
Yes they got reloaded by NR under new links, they’re reposted in post #183, the individual parts of the track access application are posted as pdf attachments. Having said all that they don’t tell you much more than you‘d get from reading the thread.
Jan Mayen
30 Sep 2020
Sussex
I'm under the impression Gatwick Express will be upto 12 carriages. Presumably some will be 4 or 8.
Nicholas Lewis
9 Aug 2019
The current formations of 8 cars run round with fresh air most of the day so they don't need strengthening to 12. Plenty of other routes in the Southern area that can make use of the stock
Nicholas Lewis
9 Aug 2019
Are you suggesting that no one travels from Victoria to Brighton now?
Certainly not but i use the Brighton Line and spend plenty of time on platform 1 at E.Croydon to observe how well loaded GX are and then see the following Southern behind stopping at ECR coming in far more busy.
LudwigTails
31 Mar 2023
Brighton
to be fair the last time i rode gatwick from brighton to victoria, the 12 car capacity could be useful on gatwick runs, everytime i stop at gatwick (in terms of week days) a lot of people gets onboard the train and almost every seat is filled. So it aint really dead air. But it is dead air when its only running from london to gatwick and back. (And its kinda fun tbf, you just have an entire train to yourself lmao).
Minstral25
10 Sep 2009
I'd dispute that, as someone who regularly goes from Redhill to Brighton, the GatEx from Gatwick to Brighton normally arrive Gatwick relatively full and depart same - normally when I use at least half of seats will be taken - depending on time of day of course but mid-afternoon before peak and again just after peak when I travel they are often very full.
infobleep
27 Feb 2011
It empty more when I travel on them but that is usually in the evening after 8 pm.
