The countless times I’ve been on a XC departing Piccadilly and the vast majority of reservations are for New Street. Manchester-Birmingham is the main flow north of Brum and it really is a case of 3 services stitched together to make 1. Take away the main flow north of Brum on to HS2 and the case for continuing 2 XC each hour from Piccadilly on the WCML sinks like brick.
Perhaps future south coast and south west services from Manchester & Sheffield should operate like the TPE services to Scotland on the WCML.
- 1tp2h Manchester - Birmingham - Plymouth
- 1tp2h Manchester - Birmingham - Bournemouth
- 1tp2h Newcastle - Leeds - Birmingham - Plymouth
- 1tp2h Newcastle - Leeds - Birmingham - Bournemouth
- 1tp2h Liverpool - Birmingham - Plymouth
- 1tp2h Liverpool - Birmingham - Bournemouth
- 1tp2h Hull - Doncaster - Birmingham - Plymouth
- 1tp2h Hull - Doncaster - Birmingham - Bournemouth
Seems like a good idea, but Cheadle Hulme limits car capacitiy to six-car trains I’m pretty sure.Birmingham New St to Manchester Piccadilly 2tph (Sandwell and Dudley, Wolverhampton, Stafford, Stone, Stoke, Kidsgrove, Congleton, Macclesfield, Cheadle Hulme, Stockport)
There’s no point in that might as well keep it for connections from Poynton, Bramhall, Adlington - Stoke etc. Not much demand but keeps it for the sake of it, unless there is a good enough compromise.The Northern stopper could terminate at Macclesfield since all of the stops have been replaced with this service. Congleton would now have a half decent service, especially on Sundays.
Is there the capacity between Coventry and Leamington? Though I wish it could happen: that would be great.Birmingham New St to Oxford 2tph (Bham Intl, Coventry, Kenilworth, Leamington Spa, Banbury)
How??? People on this thread keep mentioning this topic but how is this even going to happen. And the benefits: saving a ~300m walk. Not worth it. Use the large station that has been recently refurbished.Services from Bristol and the southwest could terminate at New St or be diverted to Moor St as some are planned to.
Nuneaton to Leamington via Kenilworth was already running pre-COVID surely? Although running services across Coventry came as something of a surprise, but they’re back in RTT from May 17th. Shouldn’t need the NUCKLE website now...There has been a long campaign in Warwickshire to reopen Kenilworth station and run trains between Leamington Spa and Nuneaton, so as to provide one change journey at Nuneaton for Leamington - East Midlands Region passengers (mainly Leicester). Also, see the NUCKLE website (Nuneaton - Coventry - Leamington Spa).
I believe there are plans to reinstate the former dive under at Nuneaton (maybe a curve to/from Platform 1 for trains to reverse direction?) as Coventry had its direct trains to Leicester curtailed at Nuneaton when the track works back in 2004 severed the connection.
I'd love to get some data on, for a typical XC service departing (say) Manchester, how many passengers on that train are still on by the time the train reaches Stoke/Brum/Bristol/Oxford/Reading/wherever, to see where the "tail off" in volume of passengers occurs starting from each stop.
Taking New Street as an example, I've been on XC services where practically the entire load of passengers changed over there, whereas on others have only a relatively low proportion of people get off/on.
Strikes me as a horrible two-hourly pattern through New Street which is the last thing you need when trying to make best use of capacity.
TPE to Scotland is a bit different though isn't it. The choice of routes is at Carstairs, not at the busy centre of the rail network.Perhaps future south coast and south west services from Manchester & Sheffield should operate like the TPE services to Scotland on the WCML.
It means that the trains have variable amounts of dwell time in Birmingham New Street and therefore platform occupancy and everything else has to fit differently in alternate hours - that is a bit of a nuisance when all the other trains run on a repeating hourly pattern.Is it? Each destination is hourly from the north and half-hourly from the south.
If you go back to the post-Operation Princess timetable in the middle of the 2000s, Cross Country was run like this.
Essentially, standard pattern from Birmingham south as today. Reading trains came from Manchester and Bristol trains from Newcastle but with the northern points for the Bournemouth and Plymouth services cycled between three routes (Manchester, Scotland via WCML and Scotland via ECML / Leeds in a complicated pattern), with one terminating in Birmingham each hour.
The simplification of routes in 2008 and since must have been made for good reason.
Send the top one to Manchester. 2 to Liverpool not needed, plus places like Stoke still need at least hourly Birmingham XCs.XC:
- 1 tph Liverpool - Birmingham - Plymouth
- 1 tph Newcastle - Leeds - Birmingham - Plymouth
- 1 tph Liverpool - Birmingham - Bournemouth
- 1 tph Hull - Doncaster - Birmingham - Bournemouth
Swap the Manchester and the Liverpool. Liverpool and Runcorn (ideally Widnes South instead) will get 2 London HS2 services every hour. The fast Manchester and Stoke to Milton Keynes via TV connection should be maintained, even if there is a Nuneaton stop or something.ICWC Semi-fast (Operated by LNW):
- 1 tph London - Manchester via Birmingham & Stoke
- 1 tph London - Liverpool via TV
- 1 tph London - Shrewsbury via Birmingham
- 1 tph London - North Wales
10 trains per hour for, say 12 hours per day, would mean 120 trains each way. If each train has 8 carriages, and around 80 seats per carriage, that's around 600 seats per train. So that means there would be 72,000 seats both arriving and departing from Liverpool toward Birmingham and London every day. Is there likely to be that level of demand for making such a journey?Sure. Why not?
Since you put it like that, it does seem a bit low. That said, I wouldn't go higher than twelpove.
Oh well stuff it... maybe let’s have:
XC:
HS2 (Western Branch & East Branch to EMP)
NPR (Consisting of TRU via Huddersfield & East Manchester bypass):
- 3 tph London - Manchester
- 1 tph London - Manchester via Stafford, Stoke & Macclesfield
- 3 tph London - Birmingham
- 2 tph London - Liverpool
- 2 tph London - Glasgow/Edinburgh
- 2 tph London - Nottingham
- 2 tph London - Sheffield
- 2 tph Birmingham - Edinburgh via Manchester & Leeds
- 1 tph Birmingham - Glasgow/Edinburgh
- 2 tph Birmingham - Nottingham
- 2 tph Crewe - Leeds via Manchester Piccadilly
- 2 tph Liverpool - Hull via Manchester Victoria
- 2 tph Liverpool - Nottingham via Castlefield
What are you proposing, putting Class 153s down it?
No thanks - not until they electrify south/west of Birmingham. There are already too many diesels running under the wires, and I doubt that XC will get any bi-modes for many years.The countless times I’ve been on a XC departing Piccadilly and the vast majority of reservations are for New Street. Manchester-Birmingham is the main flow north of Brum and it really is a case of 3 services stitched together to make 1. Take away the main flow north of Brum on to HS2 and the case for continuing 2 XC each hour from Piccadilly on the WCML sinks like brick.
Has Toton Interchange relocated to Nottingham?
Otherwise, how do the trains get to Nottingham from Toton?
2tph XC to Liverpool is needed.Send the top one to Manchester. 2 to Liverpool not needed, plus places like Stoke still need at least hourly Birmingham XCs.
They don’t get to Nottingham from Toton. Th S is under the assumption just a short stretch of the eastern leg is built as far as East Midlands parkway. Midlands Connectare proposing that there will be Nottingham services to Birmingham Curzon Street.
As for Manchester... I have no idea, but it must have some sort of convenient service by XC.
I’m not sure 2 tph XC is really needed to anywhere north of Birmingham. Given Liverpool won’t be hooked up to HS2 in the same way as Manchester (unless Liverpool gets a dedicated line via the NPR line through Warrington), I think it is more important for Liverpool to possibly have 1 tph to both Reading and Bristol than it is for Manchester. Leeds has had 1 tph for years.
Personally I think there is more value in a local stopping service in to Piccadilly and Leeds than a long distance XC service to Reading or Bristol that will be having the vast majority of it’s passengers taken away by HS2.
Both Liverpool and Manchester "need" a 2tph services between themselves and Birmingham, serving major stops along the way. Any direct cross-Birmingham connections beyond this are simply a bonus. I'd argue that Manchester is always likely to be the bigger market of the two from the likes of Bristol etc, but how much that can still be adequately served by a connection onto HS2 at Curzon Street is certainly up for debate.
I do not think the service pattern below is very useful.
There are several issues with this:
- 2 tph Manchester Piccadilly, Manchester Airport, (Crewe potentially), Birmingham Curzon Street in 45 minutes
- 2 tph Manchester Piccadilly, Stockport, Macclesfield, Stoke, Stafford, Wolverhampton, Birmingham New Street in 90 minutes
Stoke & Macclesfield surely only need 2 fast tph to Manchester. Increasing the number of stoppers in to Piccadilly also introduces a far more frequent (almost metro) service level at intermediate stations, which in turn can reduce car usage. Does Wolverhampton need 3 fast to Birmingham, or would more LNW & WMT services provide a far better outcome for passengers? Stafford will have a London to Manchester service and certainly does not need an additional 2 XC services to run alongside that.
- People who are from Greater Manchester and use Piccadilly, Stockport (or Wilmslow for London), plus those who normally board in Birmingham will transfer over to HS2.
- Macclesfield, Stoke & Stafford will have a HS2 London service that is likely to continue on to Stockport & Piccadilly, taking a significant chunk of the market with it. There will probably be another London service on the WCML that calls at all three on route to Manchester.
- Wolverhampton, like Stockport, may be better migrating over to Curzon Street. The journey times will certainly be faster.
- Many people on here think a change of train is out of the question, yet many people do this all the time. There will be a big proportion of people who do make a change at a HS2 station, which again diminishes the point-to-point demand.
- If this really just falls to serving passengers from Macclesfield, Stoke, Stafford & Wolverhampton to Birmingham & Manchester, is a XC service the best way to do that? The current fast Avanti & XC service patterns are:
- Macclesfield:
- 3 to Manchester
- 2 to Birmingham
- Stoke:
- 4 to Manchester
- 2 to Birmingham
- Stafford:
- 2 to Manchester
- 2 to Birmingham
- Wolverhampton
- 2 to Manchester
- 3 to Birmingham
- Is there a better way to serve those towns? Given these fast services only exist at these towns because they are on route between bigger cities, is it not better to reduce the number of fasts and replace with commuter stopping services?
Hereford to Hull is somewhat unbalanced. I don't really see why Hereford would be in the Cross Country network.I’ve thought up an idea which amalgamates the remnants of XC services into defined corridors. These would each have 2tph at half-hourly intervals, and none would require services to reverse at Birmingham New Street. The corridors are as follows:
As for the services, these would consist of:
- Corridor A: SW express to Birmingham via Camp Hill line
- Corridor B: South coast to Birmingham via Coventry
- Corridor C: SW semi-fast to Birmingham and Sheffield via Cross City line
- Corridor D: Cardiff to Nottingham via Cross City line
1tph Plymouth - Birmingham New Street (A)
Ivybridge, Totnes, Newton Abbot, Exeter St David’s, Tiverton Parkway, Taunton, Bristol Temple Meads, Bristol Parkway, Cheltenham Spa, BIRMINGHAM NEW STREET
1tph Bristol Temple Meads - Manchester Piccadilly (A)
Bristol Parkway, Cheltenham Spa, Birmingham New Street, Wolverhampton, Stafford, Stoke-on-Trent, Macclesfield, Stockport, MANCHESTER PICCADILLY
1tph Bournemouth - Birmingham New Street (B)
Brockenhurst, Southampton Central, Southampton Airport Parkway, Winchester, Basingstoke, Reading, Oxford, Banbury, Leamington Spa, Coventry, Birmingham International, BIRMINGHAM NEW STREET
1tph Reading - Liverpool Lime Street (B)
Oxford, Banbury, Leamington Spa, Coventry, Birmingham International, Birmingham New Street, Wolverhampton, Stafford, Crewe, Runcorn, Liverpool South Parkway, LIVERPOOL LIME STREET
1tph Bristol Temple Meads - Sheffield (C)
Filton Abbey Wood, Bristol Parkway, Yate, Cam & Dursley, Gloucester, Cheltenham Spa, Ashchurch for Tewkesbury, Worcester Shrub Hill, Droitwich Spa, Bromsgrove, University, Birmingham New Street, Tamworth, Burton-on-Trent, Derby, Belper, Chesterfield, SHEFFIELD
1tph Hereford - Hull (C)
Ledbury, Colwall, Great Malvern, Malvern Link, Worcester Foregate Street, Droitwich Spa, Bromsgrove, University, Birmingham New Street, Tamworth, Burton-on-Trent, Derby, Belper, Chesterfield, Sheffield, Meadowhall, Doncaster, Goole, Brough, HULL
2tph Cardiff Central - Nottingham (D)
Newport, Chepstow, Lydney, Gloucester, Cheltenham Spa, Worcestershire Parkway, Bromsgrove, Birmingham New Street, Wilnecote, Tamworth, Burton-on-Trent, Willington, Derby, Long Eaton, Beeston, NOTTINGHAM
It is an interesting one that no one has ever really pushed for this to be 2tph. One thing which makes it difficult is the TfW stopper on the opposite side of the hour, therefore there is already 2tph Cardiff to Cheltenham, and of course, multiple services from there north.Regarding Cardiff - Nottingham
2tph is twice an hour not once every two hours.
Exactly. And if there happens to be a HS2 service calling at those stations on the way to Manchester, plus an additional London-Manchester WCML service (let’s say via Birmingham), are more fast services needed? I doubt it, which means of the 5 fast intercity services that run in Piccadilly, only 2 will be needed post HS2.That is a reasonable assessment - the "residual" XC/whatever via Stoke service probably becomes more about serving the Stoke-Birmingham and Wolves/Stafford/Stoke-Manchester markets more than anything else.
This would be an extension of the existing WMR Hereford service rather than a brand new one alongside. I think it makes sense as it joins up paths through Birmingham, allowing for better regional connectivity. I think it is also likely that XC will become incorporated into WMR or its successor, so considering it as part of the "Cross Country" network may no longer be relevant.Hereford to Hull is somewhat unbalanced. I don't really see why Hereford would be in the Cross Country network.
I'm not sure if there is any need to extend another Birmingham train beyond Bristol in addition to the service to Plymouth. If anything, there is probably demand for an extra train between Bristol and Exeter, but I think it would be better as an extension of the GWR service from Cardiff Central, which could also call at newly reopened stations (Wellington, Cullompton) between Taunton and Exeter. As for extending the second Reading back to Southampton, I don't think it will be needed when a lot of passengers will be using HS2 via OOC. 1tph south of Reading to Soton and Bournemouth will suffice.One of the Bristol trains should extend back to Exeter (not Plymouth), the Reading train should extend back to Southampton.
It's probably better to keep reversing at Derby as otherwise that city would only be left with 1tph direct to Nottingham. Also maintains the link between Wilnecote/Willington and Derby.2tph out of Cardiff might be difficult to justify. I am not convinced that Nottingham via a Derby reversal is needed after HS2 provided there is a frequent service through Derby to Sheffield. I would potentially send the train via Castle Donington to maintain the Tamworth and Burton-on-Trent link to Nottingham. Maybe Cardiff to Sheffield or Leeds and Cardiff to Nottingham.
If capacity is an issue, the local service on the Cross City line could be permanently reduced from 6tph to 4tph with 2tph to Bromsgrove and Redditch each. Alternatively, all Cross City local services could go to Redditch since Bromsgrove would see a greatly improved service with trains from Cardiff and Bristol calling there.The interesting question is just how many trains can be sent from the south west into Birmingham. Six seems quite optimistic, even with two going via Camp Hill.
My proposal is for this to replace the existing GWR service between Bristol and Worcester, and hence this would be the only service calling at Ashchurch for Tewkesbury.Your Bristol to Sheffield train is going to need to be overtaken whilst it diverts via Worcester which might limit its attractiveness. I appreciate it is putting two stoppers together but is that helpful when the only new link is Droitwich to stations beyond Worcester.
If this is the case, it may be better to swap the additional Cardiff service and run it to Hereford instead. Tweaking my plan further, you could have 2tph Hereford to Nottingham, 1tph Cardiff Central to Sheffield and 1tph Bristol to Hull.Regarding Hereford - Hull, is it intended to be an extension from Birmingham? Transport for West Midlands and Worcestershire County Council I believe intend to increase the frequency between Birmingham and Hereford to run every 30 minutes, which would require redoubling Shelwick Junction - Malvern for timetable robustness as well as an increased frequency.
