BlythPower
Of course, the 210 arrangement suffers the "train length" issue of LHCS a bit. And unless they were coupled "back to back" access between two units would be, um, limited...
Gangwayed at both ends...
Yet in the (related) 317s passengers are free to walk through the connector.
Mad isn't it, different strokes for different TOC's, I'd imagine.
Yes, but you wouldn't be able to have pax walking through the above-floor engine compartment. I suspect that the gangwayed cab was put on the DMBSO because it was a prototype and it wasn't worth developing a non-gangwayed cab for.
The 395s are hardly representative of a typical commuter train though: They're 140mph capable, essentially regional, units. Heck, they're better than the so called "Intercity" units that operate on Crosscountry!This one's easy....because when trains are ordered in the UK the last thing they think about is the looks of the cab ends. No attention at all in most cases. There's a few exceptions and the Javelin's are exceptional. Why can't units all have such appeal on commuter trains as these do?! It's a real bugbare of mine.
I would personally choose functionality over aesthetics: Fancy streamlined nose cones waste so much space that could better be used for seating (and they're bad news for passenger throughflow in multiple working as well) and would be absolutely ridiculous on a 75mph two or three car unit.
Yes of course: A streamlined nose cone on a 125mph train is aerodynamically functional, and you would hope that a 125mph capable unit would have sufficient carriages (As it would almost certainly be an Intercity type of train) that the 1/3 of each driving carriage lost to crashworthiness standards would make up a negligible proportion of the total train length (Sadly, as we all well know, this has not been the case in recent yearsIt depends though, if you're streamlining a unit that goes at say 125mph then it isn't really wasting all that much space as you would lose a 1/3 of the vehicle end to non-passenger accommodation anyway. Though I do agree on commuter units it makes no sense whatsoever.
How was it for noise though? Hell, how was the passenger saloon of the power car for noise, and the driving cab?
It's not used because IIRC, the way the connection works means that people passing through actually have access to part of the drivers cab. I presume this is the secondmans side; the old slammers used to have the drivers part closed and locked by the partition door that closed off the access to the drivers door vestibule. The secondmans side with the handbrake merely had the front corridor door hooked against it, you could easily get into the secondmans side of the cab. In fact, they became unhooked easily and passengers passing through had to reopen the front connecting door themselves to gain access to the next unit sometimes. I think the 455's have a similar arrangement, cab wise.
Back in the day, this wasn't seen as a problem.
I did get to walk through a 210 full length once; the engine bay was actually offset slightly and there was a proper corridor down the side of it, similar in width and materials style and colour to that in a Mk3 Sleeper, so no issues at all about access to the engine bay - it just wasn't possible.
I believe they were so they could work in multiple with the older slam-door units and locomotives used in the SR.
What I meant was pax wouldn't be allowed to walk through it, not that they physically couldn't.
