Waverley125
Genuine question.
There may be operational reasons but from the customer point of view it facilitates seat reservation. The coach has a letter and the seat has a number
If your reservation is for A2 it is perfectly clear which seat it is - if it was for 1-2 it wouldn't be clear to the typical member of the Great British Public if that was seat 2 in coach 1 or seat 1 in coach 2.
Southern use numbers, rather than letters. It would make things much simpler.
Southern do but thats only because the PIS changes the coach numbers each direction.. and its beneficial for stations with short platforms and splitting services.
But then its not really needed on services that don't do either.. but the PIS can't cope with that.
LOL - just thinking of all the confusion the exising "F, B and A" gives on the Face, Back and Airline seats respectively
Eurostar use numbers and it doesn't cause confusion there
A few trips I have had on the continent have been interesting in this regard. On my first trip, my friends and I were booked in coach 17 of what turned out to be a ten coach train. On my last trip I used the Paris-Madrid sleeper and was booked in coach 62, which, it appears, was the lowest numbered coach in the train!
However, why a 7 coach train would be numbered with coaches 10-16 I really don't understand! Strange at the time and I still find it strange now!
I disagree. Southern don't label their coaches with numbers or letters as they don't offer seat reservations, so it's not necessary. Announcements/displays will say which coach you're in, in relation to the front of the train, which will change en-route in the case of reversals.Southern use numbers, rather than letters. It would make things much simpler.
For example if the train is formed of two units and three coaches per unit, the first unit would have its coaches numbered 10-12 and the second 20-22.
It works this way in Denmark if I remember correctly.
But TPE have gone retro and started using B & F for table seats on the 350s. And it because it's not used anywhere else on their routes (AFAIK) it confuses people.usually these days they are either all 'A' or no letter is used
