Why use tail lamps when working tail lights are available?
Discussion in 'Traction & Rolling Stock' started by GM228, 10 Aug 2015.
Thread Status:
  1. D6975
    D6975 Established Member
    2,071
    26 Nov 2009
    Bristol
    In Ireland even light engines used to carry two tail lamps, so they had 4 red lights showing. Here is 232 coming down to Heuston from Inchicore in 1995
      File size:
      153.6 KB
      82
  2. GM228
    GM228 Member
    154
    9 Feb 2015
    This was due to a rule requiring all trains have two steady lit tail lamps/lights, as the majority of locos didn't have two tail lights fitted (most only had one) a specific rule also noted that all locos must have two portable tail lamps when running light, it was never amended when the 201s were delivered with two tail lights and so it applied to them also. Eventually all locos were modified with two tail lights and this practice stoped.
  3. 33056
    33056 Established Member
    2,355
    12 Nov 2007
    On a train somewhere in Europe
    That is a portable headlight which is authorised to be used if the built-in one fails or if there isn't a headlight, like steam locos for example.
  4. 455driver
    455driver Veteran Member
    11,332
    10 May 2010
    Deleted!
  5. headshot119
    headshot119 Established Member
    1,842
    31 Dec 2010
    Cardiff
    Pacers don't have a remote supply so your explanation is the most likely.
    Not much difference between 75 top speed and 70 because of a portable head lamp.
  6. Crossover
    Crossover Established Member
    7,941
    4 Jun 2009
    That would be my guess, but it was last year so I cannot recall, and it came through at a fair pace so I wouldn't have been able to tell if the engine was out (above the noise of the 185 behind it on pl 16, too)
    In such situations, how does the cab function if there is no power for anything else?
  7. headshot119
    1,842
    31 Dec 2010
    Cardiff
    You have two sets of batteries.
    Auxiliaries power things like the lights, and don't have a remote supply if they go flat.
    The desk is controlled from the main batteries.
  8. mainframe444
    mainframe444 Member
    87
    23 Feb 2010
    As you say, a tail lamp is used when the locomotive is shut down, to avoid flattening the batteries.
    On a class 37 (and I think a 31) the tail light switch in the cab actually turns on the tail light at the opposite end of the loco. This I think is a throwback to when a loco would be detached from a train, it meant that the driver could turn on his tail lights and drive away without having to get in the other end.
    In the case here, a driver has to get out of the cab and check that the tail light is lit before changing ends, so its probably easier to leave the cab he has arrived in, hang a portable tail light on the back of the loco, noting that it is working, than going to the cab nearest the train, turning on the tail light, and then walking to the back of the train again to check the lamp is lit.
    MainFrame
  9. 33056
    2,355
    12 Nov 2007
    Definitely the same on a class 31; working an AB signal box many years ago I saw a class 31 slowly approaching with red lights on the front so did what we often did back then and leaned out of the box holding the bardic lamp and pointing at it. The driver acknowledged with a "thumbs up" so I was a bit surprised when the loco stopped in the adjacent platform and the driver got out and went into the rear cab. On mentioning this later to one of my driver friends they explained that was how the tail lamps were set up which I thought was a bit strange at the time (late 1980s)
  10. Crossover
    7,941
    4 Jun 2009
    Ah OK - thanks for that. presumably, then, if the main batteries also went flat, the unit would be a little stuck?
  11. GB
    GB Established Member
    5,563
    16 Nov 2008
    Somewhere
    Simple answer is if its within the cab its less likely to get pinched by the locals or indeed other operators....and yes, that does happen from time to time...and no, there is no rule against it.
  12. TDK
    TDK Established Member
    4,126
    19 Apr 2008
    Wrexham
    It prevents the spotters nicking them
Thread Status:
Share This Page
