I see.
However I wonder when the new trains come and signaling what it will be? I can't see it being normal fixed block signaling with manually driven trains. I know the metro has less overall demand compared to the London underground. Yet I seem to recall somewhere that ATO could be possible on the South Gosforth Pelaw strech?
Possibly true. However the problem is not overall system capacity, and particularly not overall capacity (in terms of passenger space per hour), it's the expense of improving the peak frequencies on the outer reaches. Coming from the South, it is typical to find the services from Sunderland / S Shields absolutely rammed by Pelaw, but the Pelaw starters (which are every other train in the peak) have spare seats (and oodles of standing room) usually until Gateshead Stadium, and only ever pack out if there's a problem. Even a modest change in the headways on the branches at this time would do much for crowding levels, particularly the Wallsend-Monument section which I understand is very crowded (and only 5tph) during the peak.
The problem is that even with a reduction in the number of Pelaw terminators, a substantial investment in drivers and units would be required just to move to a 6tph peak service. And this is the sole reason why ATO would ever be worthwhile - for the same reason it's used on the DLR, to reduce labour costs (remember a DLR 'captain' earns about 75% of a Tube driver's salary) particularly on the branches.
But it's these sections which would be the most costly to convert, with three level crossings north of the Tyne, and the interface with NR metals south of it.
The signalling system itself is fairly modern, using an Indusi trainstop system, and should T&W metro truly need a substantial increase in capacity, a large part of the system has passive provision for 3-unit services (if you're ever on it, the underground stations all have an additional area to one end of the station box which is not fitted out), in place of the 2-unit services used now. This would add 50% to the capacity without requiring any more drivers and using the existing permanent way.
