350369 currently on 11:46 Euston to Crewe now In full Lnwr livery. Once 368 is out that's the 3s half way through!
Are the 350/3 getting an interior change?
Don't know why no coach lettering though? Surely if someone asks which coach the toilet is in, or which coach an assist is in, you'd want something better than '3rd coach from the front rear door' on an 8 car. Especially when they've got used to having coach letters on that stock.
I think they cause more confusion than not, to be honest, given that most trains don't run as single units. Ideally they'd modify the PIS so it would show correct letters based on formation, or (given that there are no reservations) the SWT mod that does the "Coach 1 of 8" thing.
Good point, especially if more 8 car running is planned. Out of interest is there an exterior display on the side of every coach on a 350? I know at least one window on each side has a matrix display which is able to show a destination.
Nope, only on the end carriages, from what I can remember.
LNER, and their predecessors on the ECML, use sheets of A4 paper that slot into plastic holders affixed to the inside of the door windows on the mark 4 sets, and inside the lower pane of the toilet windows on HST sets, to display train information - They're not adhesive.A way around it was be to use repeelable stickers and stick them on the inside of the doors on each set at the start of service or when they are coupled. Although I admit this doesn't seem likely. I believe LnER do this though?
LNER, and their predecessors on the ECML, use sheets of A4 paper that slot into plastic holders affixed to the inside of the door windows on the mark 4 sets to display train information - They're not adhesive.
Ahh I see. So they could potentially do this on a 4 8 or 12 car 350 set?
Smethwick Galton Bridge in the process of being tangoed this morning.
Photos at https://flic.kr/s/aHsmhZQvpq
Painted gold and black and right in the heart of West Brom territory: sacrilege.
More like Wolverhamptons revenge on that West Brom bunch of losers
Still pride of the Midlands though, unlike a certain Staffordshire club.![]()
There isn't much need because (a) there are no reservations, and (b) the old lettering was meaningless because letters were repeated in an 8 or 12 car set. Getting rid is probably the most sensible option, or if viable implementing the SWT numbering system - in the case of a split/join you need to know the coach number while inside, as seeing which the front 4 are is easy from outside.
If I ever wanted to meet someone on a long 350 formation I'd say something like "second from the front" or "back", those being the ones I tend to go for anyway as they are the quietest from Euston, at least from the "long" platforms.
This SWR numbering system sounds intriguing, what does it involve?
@samjessupdesign
Replying to
@captainelectra
Not huge changes Adam, same basic design, less green coverage on body ends (to give the design more symmetry), both big and small logos have been resized and repositioned, everything has been lined up a little more, First Class stripes added, metallic vinyl wrap all round.
7:54 am · 22 Aug 2018
350240 Will be next into the temporary livery, swapped out today to take it's place for relivery overnight.
