Hang on, isn't 57212 in 150921 or am I behind times?
Both of the 3-car 150 hybrids (150921 and 150927) recently had their additional carriages removed for their C6 exam, and they were both renumbered back to just 150121 and 150127. However, it looks as if carriage 57212, which was as you correctly say part of 150921, has been put in to 150126 instead, hence 150926.
I shall look out for the unit when I'm out and about in Bristol tomorrow
Also, why was a 3-car 150 replaced with a 2-car 150 just before the busy periods?! (i.e. school and rush hour).
As stated above, yes BB you are behind the times.
That's what's booked to happen. The two 150/9s are booked to work Severn Beach Line services in the morning and other services in the evening peak.
I forgot the diagram to be fair.
150926 was on the 1838 Westbury to Avonmouth this evening.
or that there was a fault requiring hitting with a hammer (normal SPM repair technique ).
The other usual repair technique I've seen employed by SPM's finest is the application, using the theory of levers, of a size nine steel toe-capped boot. In other words, give it a kick.
926 is currently working-
1F13 11:30 CDF-PMH 14:54,
By my reckoning it should then work-
1F26 15:23 PMH-CDF 18:43
5F99 18:46 CDF-CDF 19:08
1F99 19:30 CDF-PMH 23:04
5F99 23:09 PMH-Fratton depot 23:32
Neither 150125 or 150925 are allocated today.
And yet the 1646 Bristol Parkway to Warminster, which is one of the 150/9 diagrams, was formed of 153318 and 150266 :P
This looks like a 150/1 witha Single carriage attached (as in case of 158/9)rather than another vehicle in the middleVideo 150926 https://m.youtube.com/watch?v=iUtKw6hITsM why is the flying F in the wrong place?
The single 150 carriage wouldn't be able to go on the end because the 150/1s lack the carriage walk through where the driving cabs are.
I wonder why these class 150 hybrids have always been with the 150/1s though (rather than 150/2s)? I know the extra carriages added from the damaged DMUs also have 3+2 seating, could this be why?
