Strike through. Make it part of your scanning movement across the rows.With group bourdon, are we required to circle or put a line thru the 4 dots? Probs irrelevant but just wondering, Thanks.
Many thanks, thought so.Strike through. Make it part of your scanning movement across the rows.
Hello, newbie here!
I’ve successfully passed my assessments and interview for a Hybrid Relief role and I have my medical tomorrow.
From what I’ve read on here it seems to consist of height, weight, BMI, hearing, eyesight, BP, D&A test, ECG, chat about general health/medical history.
I’m so excited to start the new job but also apprehensive about tomorrow, worried I could fall at the last hurdle!
How have most people generally found the medical? Also, do you find out on the day of you’ve met the requirements or is it a bit more waiting?
Thanks so much.
Thought SE did MMI part of the psychometric test separately to the paper and computer tests/ VSEfor southeastern?? dont they give practice vses to go over??
I'm undergoing my assessment, I'm due to sit the VSE then if all is well do the MMIThought SE did MMI part of the psychometric test separately to the paper and computer tests/ VSE
They do send out a booklet, however I imagine it differs slightly from the real thing. Just provides the correct technique required to pass I guessfor southeastern?? dont they give practice vses to go over??
So I only have 1 more attempt at enhanced with any toc ? And 2 chances national even though I passed already . I thought as I failed enhanced with arriva id only have 1 chance with them and 2 chances everywhere as I’d assume different tocs enhanced standards will be different from each other ?AIUI you get two attempts at national and two at enhanced. If you fail to enhanced you have only one left at enhanced. If you fail to national then you only have one left at national. If you fail to enhanced but pass to national then you have one enhanced go left but still a national pass . If you pass to national and then have another go at national and the pass isn't even high enough for standard, it overwrites your national pass too.
That's where it gets a bit confusing. Yes you might have passed enhanced to a company that requires lower pass marks , but I believe that if that was the case, then you wouldn't need to redo the testing and would go straight to interviewSo I only have 1 more attempt at enhanced with any toc ? And 2 chances national even though I passed already . I thought as I failed enhanced with arriva id only have 1 chance with them and 2 chances everywhere as I’d assume different tocs enhanced standards will be different from each other ?
Thanks, that’s a a bit of a relief.That's the software I used and yeah you only get the point if you correctly identify every element in each picture.
I'm pretty sure on the day you get a cumulative score for every correct one you identify so it is easier. I would say the pictures used during the actual assessment are clearer so I found it a bit easier than the ones you're practicing on.
I don't know what the pass mark is unfortunately. I asked afterwards but they never told me.
I reckon during the actual test you get 1 second per image also so try it on that.
Let your eyes relax and look at the middle of the image. If you're eyes are darting about trying to find things that makes it harder imo.
That's the test I was most concerned about so I just did a little bit of practice every day and my score slowly started to improve.
Just stick with it and you'll be fine.
I failed enhanced , passed national . So I know I can only do 1 more attempt with arriva as that will be my second chance. But if I tryed another toc I will still only get 1 attempt or 2 at enhanced is what I need to find outThat's where it gets a bit confusing. Yes you might have passed enhanced to a company that requires lower pass marks , but I believe that if that was the case, then you wouldn't need to redo the testing and would go straight to interview
Pretty much one unless the toc has a lower enhanced than ArrivaI failed enhanced , passed national . So I know I can only do 1 more attempt with arriva as that will be my second chance. But if I tryed another toc I will still only get 1 attempt or 2 at enhanced is what I need to find out
That’s not DFFTIs it still the dials
Ah OK. I didn't do that. At least I don't remember itNo, the Dials is a different one. This is the Fault Finding...where you have to prioritize some faults in the panel train over others.
You have to put down the Fault Code as well.
Thank you. I will check that.DFTT is pretty straightforward compared to the other option imo of VSE. In the case of practice I think the traineetraindriver website has practice tho the pack practice should be sufficient.
Thank you for your advice.☺️I personally found the practice materials from the TOC and OPC to be easier than the actual test. All I can say is that I needed to do multi-level checks where I had to run to and from different sheets and ensure I came back to the right train code through all the steps. There was some brilliant past advice on here to cover up other train codes whilst you move between sheets to always ensure you always come back to the correct train - I read that but still erred because I didn’t follow that advice, however, I still managed to scrape through. I would suggest you strongly follow that advice but also practice the more complex sample tests. Keep calm on the day because you know you have done your preparation.
