ATW Loco Hauled set
CaptainHaddock
10 Feb 2011
Sorry to reactivate an old thread but I'm thinking of making a journey to Llandudno this weekend and noticed that there's a direct 0942 Crewe to Llandudno train (headcode 1T01). Is this stll the Sumer Satrudays loco hauled set?
PHILIPE
14 Nov 2011
Caerphilly
It is, but you can't rely on it running. It depends on train crew availability but may be confirmed until the day before
CaptainHaddock
10 Feb 2011
Thanks for the warning; in the end I went somewhere else instead but checking TOPs it looks like 1T01 was cancelled from Crewe and started at Chester instead.
40fan
7 Aug 2010
Stoke-on-Trent
It was worked by 2x150, 1T01 started from Chester, rest of diagram ran as normal. Reason for cancellation at Crewe was no driver.
Bikeman78
26 Apr 2018
The only people that sign it are Crewe/Holyhead drivers and Shrewsbury/Holyhead guards. I believe Holyhead cover all the North Wales work apart from Crewe to Chester. With hindsight it would work better to plan its use on Saturdays into the WTT and arrange crew diagrams to cover it. Put it on a two car diagram and use that to couple to another two car. So two sets go up from two to four cars. The ad hoc reliefs are lightly used because, if they run, they are only advertised last minute so the general public aim for the wedged out units.
PHILIPE
14 Nov 2011
Caerphilly
It's a bit late for the WTT this year and it won't exist as such next year due to 67s and Mark IVs on Cardiff to Holyheads and the Manchester being a 175
_toommm_
8 Jul 2017
I noticed this evening the 17:01 Class 37/MK2 set spent 30 minutes at Birthdir. Does anyone have any idea why?
craigybagel
25 Oct 2012
Almost correct - Llandudno Junction guards also sign it, and Monday to Friday they normally work all the Manchester services (the original Cardiff service is worked by Holyhead guards). On the weekend, as with on a weekday it requires a Crewe driver and Shrewsbury guard to prep the set at Crewe and bring it off the depot. They can then bring it to Chester and hand over to a North Wales crew for the rest of the day. A Crewe driver then brings it back on to Crewe depot at the end of the day. If no Crewe driver is available, the set can't leave the depot and other units will need to be found.
Bikeman78
26 Apr 2018
Yes I understand that. I wonder if any more train crew will be trained on the hauled sets. Hopefully the set that ends Holyhead Friday night will be used on summer Saturdays next year.
craigybagel
25 Oct 2012
There are 4 seperate sets of traction training needing to take place across TfW in the next few months as it is, it's going to be hard to increase the numbers that sign LHCS any time soon.
craigybagel
25 Oct 2012
In other news related to LHCS at TFW, 67008 is currently at Crewe EMD getting mods for working with the MkIVs. Proper Driver/Guard communication and interlock apparently.
geoffk
4 Aug 2010
I didn't know anyone visited Holyhead to see the place - I thought they just went there to catch ferries to Ireland.
I went to Holyhead on the loco-hauled set (67010) yesterday just for the ride and didn't stay long. I noted the through roads at Bangor, evidently not used recently, and there is one at Rhyl (westbound). Not much passes Rhyl without stopping. I knew that the westbound platform at Abergele had been built out to meet the through line and the loop removed.
krus_aragon
10 Jun 2009
North Wales
Rhyl's through road, like the one gone from Abergele, seemed to have been kept when boat trains ran out-of-course to meet their sailings, to the best of my knowledge. (Letting a limited-stop boat train bypass a local stopper to get to Holyhead in time.)
Bangor's had those through roads since it was built 170 years ago. With no loco-hauled trains terminating at Bangor any more (and no need to run-around) they see little use other than freight trundling through to or from Holyhead, or stabling a Voyager that terminates at Bangor in the evening (if not using the sidings behind platform 2 to stable between turns).
geoffk
4 Aug 2010
Thanks for the explanation.
Bikeman78
26 Apr 2018
1D33 run non stop from Chester to Llandudno Junction but curiously it normally runs through the down platform. Is there a fault with the through line?
