Northerner
- Joined
- 4 Aug 2013
- Messages
- 43
Simple question regarding banner repeaters , why do then revert to the "on" position when train passes them, before the train has actually passed the associated signal?
A second train should not be signalled into a platform if the starter is off for another train in that platform.
Certainly not on most installations nowadays, but some older ones might still. I can certainly think of one case where the platform starter's an auto. There's also the possibility of one approaching when it shouldn't - "proceed at caution, being prepared to stop short of any obstruction" mitigates against that, but the banner repeater off might lead the chap into a false sense of security. Unlikely...but you never know!A second train should not be signalled into a platform if the starter is off for another train in that platform.
The requirement for the banner signal to revert to danger behind a train, even if the signal it refers to is still at 'clear', has been around for many years where track circuits are in place. At the restored/preserved St Albans South signal box, our simulator reverts any banner signal to the 'On' position as soon as the track circuit in advance of the banner is occupied; the indicator on the block shelf is also switched to the 'On' position. This was how things worked up until 1979, when the box was closed.
For information the banner repeated the Home signal and it was the berth TC for the Home that put the banner back to 'On'. I appreciate that this wasn't perhaps a general rule, but I thought it was an example from some time ago worth mentioning. (It was the Up Slow and Up Fast lines that had the banner repeaters due to curvature and road bridges on the approach to St Albans City station.)It's not quite that simple. Where there is already a separate TC between banner and 'main' signal or where one is to provided for other reasons, then it will generally replace the banner to danger, because this has no additional cost.......
More recently NR have put up a tri-state repeater adjacent to the box:
This is on the Down Fast and is repeating the aspect of the signal at the far end of the platform. (The other banner repeater is on the Down Slow but has not been changed to a tri-state version.)
There's a green banner for the signal protecting Lenton North Junction too, on a 50mph route (approaching from Nottingham). I wonder if they have superseded the white-only ones on new schemes.
These are green banner repeaters being installed on the MML due to the speed increases, it works the same s a normal banner repeater except it shows green when the associated signal is green, and white when a restrictive signal is shown.
callum112233:1564626 said:These are green banner repeaters being installed on the MML due to the speed increases, it works the same s a normal banner repeater except it shows green when the associated signal is green, and white when a restrictive signal is shown.
There's one at Wigan North Western too.
oops, beaten to it^
A lot of new banners are green but they are still installing white only ones.
The new one at sandy on the ECML up lines are capable if showing green although are yet to be commissioned so currently only show white (they have only been operating for almost 2 years so give them a chance to get around to it...!)
The new one at Alexandra palace on the up slow shows green and is very useful, especially with a semi fast in the morning peak so you don't end up stopping at reds in the platforms at places like Hornsey where people bang on the cab door insisting you let them on etc.
But the new banner put in at Hertford north on the up as part if the Hertford re-signalling is a white only as far as I know (it certainly dosnt show green even if its capable of it) so I'm pretty sure they only put green ones in if its likely to speed things up.
Slightly unrelated but the new standard for banners at junction signals is that you need split banners. At Alexandra palace the new banner is not split and as a result it will remain 'on' even if the signal is 'off' but with a diverging route. This has caught quite a few people out as a lot of drivers stop at the banner if its on to avoid stopping in the platform when not booked to call there (for reasons described above). The signaller then ends up having to call them up to let them know the signal is off but they need to draw forward to find out!
Why on earth would a driver in a modern train want to stop at a banner repeater to avoid entering a platform. Surely the drivers who go over this route were briefed on the workings of this system?
If the signal doesn't clear for the diverging route until it's in sight (as many with approach control do) then you'd never get the banner repeater to come off even if it was a splitting example...but then I suppose you might be able to release the signal earlier? Drivers stopping at banner repeaters sound like drivers waiting forever for a yellow to turn into a green anyway...done with the best intentions, I'm sure, but sometimes not at all helpful!
Thanks for the explanation - seems fairly sensible, I suppose. Can't see a problem as long as everyone's aware that it's an accepted practice at that location!See my above post-there is no way you can stop a non-stop train in some of those platforms due to the crowding. Hanging back is a fairly recognised method there. As I say above, the chances of getting the diverging route there at that time of day is almost zero so it really only happens during disruption. The signallers understand we do it and tend to phone us up to let us know its set for the fast.
Must be a GN thing then, never heard of anyone stopping at banner repeaters ever, now stopping at the platform ramp is not uncommon as the signal is in full view (location dependent), or crawling along till it clears. I really find it hard to see the justification of doing as you mentioned.
So thanks for your rather patronising input but we are actually briefed on the system and do know what we are doing. It's far more sensible and safer to stop at the banner rather than stop a train in the platform that dosnt call there.
I would say it would far safer to regulate the speed of your train so you were no approaching reds if you know there is a train in front. This is the method I use, or even slow to a very slow speed approaching the signal. I suppose route knowledge plays a huge part in this scenario as it does with all train driving. I would say you are correct in saying it is safer to stop short of the platform but I would say it is more sensible to regulate the speed of the train to avoid having to stop at all.
