D365
- Joined
- 29 Jun 2012
- Messages
- 11,468
I picture a giant portable power bank with wheels, and a USB port at each end.
Yikes, I wouldn't want to put 750V and several hundred-odd amps through a USB..!
Youre obviously a senior network rail engineer or possibly work for the Orr?I picture a giant portable power bank with wheels, and a USB port at each end.
The really exciting aspect of the project is what are going to be used as the Thunderbird Locos to rescue units which have run out of charge on a single line in the middle of nowhere and of course what livery they are going to be in? Class 37s fitted with tight lock couplers. Maybe Southern could pay for a mainline connection at Eridge and one could be used for diesel galas at the Spa valley in between their frequent duties dragging dead units back to the third rail...
Going by Southerns performance in recovering the 377 that was stranded at Tonbridge by the landslip, you know the one thats now covered in graffiti and with the toilets overflowing on the floor, a 377 running out of charge on Marshlink would close the line for 5 weeks while the loco was sent down.More likely SNs 73202 would be fitted with a Delner for Rescuing, if possible of course. Bit like a 37 or 57.
The first rail replacement bus would arrive after 4 weeks but the emergency call points would still just hang up on you when you enquired about services. The Rye ticket office would be closed because of staff sickness throughout as is normal during disruption.
One of the aims is to go green though.Just a thought - hasn’t it been proven on the BML that a 57(?) can haul a 377 in service? So theoretically it might be easier to fit a 377 with batteries for hotel power only, and use a diesel to haul? Admittedly it might require a run around at uckfield and ashford, but the loco(s) could live at oxted and Hastings respectively and haul the dead sections?
There has already been a battery Electrostar, so it isn’t totally new techSeems bizarre to be planning these changes on the basis of using what is completely unproven technology. Uckfield in particular is hardly a quiet branch line to test out whether battery Electrostars actually are viable in service
Quick change battery packs are the answer!
I think they call that a ‘valuable learning experience’The one that run around on occasionally on battery power on ac lines just in case it failed and was quietly withdrawn after 6 weeks because the batteries were shagged? (despite all the triumphant press releases).
Doesn't inspire much confidence tbh.
They could of course off-peak use them between oxted and uckfield only during the day as additional services. It is fairly quiet between 11 and 3Seems bizarre to be planning these changes on the basis of using what is completely unproven technology. Uckfield in particular is hardly a quiet branch line to test out whether battery Electrostars actually are viable in service
It does all seem very quiet on what is happening?
I’m guessing this is a bit on the back burner right now!
Good luck on finding something to connect the 3rd rail up to...
And what are you going to connect those substations too?I guess its impossible to build substations... .
See my recent comment in the electrification % thread:
DNO supplies in the area are rubbish (minimal spare capacity as they thought they wouldn't need much in the middle of green belt / National Park / AONB etc... hence it will be a very long 33kV extension lead for substations...) The Redhill - Tonbridge line power supply is very poor before anyone gets too excited. The best opportunity is probably a feed from Dormans 132kV substation at 33kV. The Dormans - Pembury 132kV cable east of that is effectively maxed out (inc. resilience allowance) which suggests a Nat Grid 400KV intervention might be needed (passes a couple of miles south of Uckfield near the A22/A26 roundabout). Everything (not just rail) in the wider Sussex area (from coast to M25) is fed from Bolney GSP at 400kV (~2km west of BML at Haywayds Heath)"
I think it had been on the back burner for sometime tbh. Good theory but totally impractical in practise.
Lots of money, lots and lots of money. EMR and the ROSCOs will presumably be payingI'm sure they'll find a way. Just requires the money! Haha.
It will be a very very long length of (chunky/expensive) cable along side the railway line.Railway track is a great way of adding electricity capacity without causing too much disruption. You can run various types of HV cable either on cable trays or buried in the embankment. If there is spare capacity at any Sussex substations then you just run a feed along the railway corridor.
