I am not sure "What Bradford wants" as seen by the Council, will be the sole criterion for routing NPR even in Bradford. We will have to wait to see which intermediate stops all along the route from Liverpool to Manchester, Leeds, Hull, Middlesbrough, Newcastle etc., are deemed to be in scope. The tunnelled sections into Liverpool and Manchester increase agglomeration benefits by sharing costs with HS2. In Bradford, this is not the case - the cost/benefits will rest solely on NPR. We do not know yet, the precise route through the Pennines - are we talking of a new long tunnel or a series of base tunnels - say cutting directly across from Rochdale to/ or under Halifax? Will there be calls for NPR trains to stop at either of these stations - after all Warrington is in the frame.
Will the inter-city connection time between Leeds and Manchester weigh more than that from Bradford? I found the suggestion earlier that head-line trains from Leeds to Manchester could avoid Bradford, to make the bubble diagram for NPR timings come true, pragmatic but unsatisfactory. I wonder how that will go down in Bradford - having waited for years on the regional side-lines, how will continuing to be partially off-route help the city? I hesitate to write this but, as a non resident, can I respectfully suggest that what Bradford needs may differ from what it wants. It needs to be on the main line where all NPR trains stop offering a regular drum-beat service across the Pennines and regular direct links to the East Coast, North East and Scotland to the East and Liverpool, Crewe and Chester in the West. George Kettering's aphorism that "a problem well stated is a problem half solved" springs to mind. This problem should not be seen as an either/or question - there needs to an answer containing logical "and" answer as in: "Bradford needs improved communication to the entire NPR network and that a dedicated station, which maximises the local regenerative impact, be built. Discuss".
P.S. The idea of creating an entirely new section of city is not without precedent - as seen in the case of Old Oak Common.
