Peter Mugridge
So do I, at Clapham Yard, being used to shunt (presumably failed) slam-door stock. They were unable to run in service together.
My photo was taken at Surbiton..... I'll try to dig it up.
It won't be the Belle anyhow, I believe it's a bodge up of BEL bodies stuck on CIG underframes with CIG bogies, motors and control gear. It won't look right and it won't sound right either (at least to me).
How many non steam locomotives or units have been allowed to run on the main line without yellow warning panels since the 1960s? The only other one I can think of is Sarah Siddons.When the new-design headlights were revealed on the Belle there were a lot of pretty angry comments about how they ruined the whole thing, that it wasn't worth putting it back on the main line if the front end had to be butchered so. Bet those commentators are singing a different tune now those self-same mods are allowing the yellow panels to be dispensed with..
Given the 5BELs were withdrawn by BR in 1972, you're relying on your memory not having degraded in the subsequent 40 years to assess whether it 'looks or sounds right' - setting aside the insertion of lights which are being done to meet current standards.
Anyone who genuinely remembers the 5BELs are easily in their 60s now.
For the rest of us this rebuild provides a welcome insight into what these units were like to travel on.
Don't see the need for castigation, after all it used to be connected to the rest of the network by means of a lift which enabled stock to be taken away for works attention.I'm going to be very cheeky here and include the Waterloo and City line in the category of 'main line' (as opposed to private or preserved lines) in the days when it formed part of British Rail - and therefore propose class 487 (the 1940 stock), and their 1990 stock replacements. I expect the castigation that must surely follow will be swift!
Nope. Not a fan at all.
Unfortunately I was never keen on this project given the amount of EMUs it has used to get it to this stage, unfortunately adding Rubbing Plates and LED lights - no room for the SR Jumper Cables or the original crest now either, has for me rather ruined the look either further.
I believe some W&C stock (the older Southern stock) ran to Wimbledon depot on its own at least once. Someone more knowledgeable can correct me if I'm wrong.
So you'd rather see it stuck in a museum looking totally authentic than see it out on the main line doing almost what it was designed for?Nope. Not a fan at all.
Unfortunately I was never keen on this project given the amount of EMUs - 2 VOPs, 2 CIGs and the Derby 4 SUB (and I think another VEP too) it has used to get it to this stage, unfortunately adding Rubbing Plates and LED lights - no room for the SR Jumper Cables or the original crest now either, has for me rather ruined the look either further.
Very keen on seeing this one! I'm sure [way back in the late 80s] I saw a 442 hooked up to a CIG or VEP in Wimbledon..a photo like this would go a long way to confirm I've not been imagining it all this time.
Totally agree. I was born in Wallasey, and travelled on many class 503s, though we didn't call them that at the time! I even remember the Mersey Railway clerestory stock that preceded them before 1956. I'd love to see the preserved 503 up and running, but we have to remember in today's day and age the costs involved would make it impossible to keep going as there is not sufficient interest. The Brighton Belle has attracted wealthy people to fund it and hopefully to travel on it in similar style to the VSOE. Those that cannot afford that style will still be able to view an iconic train from the last century in its working environment.The thing is, though, that ultimately there will be more public interest generated with the Belle than with SUBs, VEPs, CIGs etc. Unless you have very deep pockets then you are always going to have to rely on 'bums on seats' to generate revenue to keep your stock going, and that applies as much to steam locomotives as anything else. You can argue the merits or otherwise of why "xxx" or "yyy" should be restored by the NRM instead of the likes of Scotsman, but the bottom line is always going to be cold, hard cash. We regularly hear calls for the likes of D200/40122 to be overhauled, but would it generate support from 'normals'? Probably not. Then you have to consider what you would gain from an expensive overhaul, when there are other EE Type 4s in operation.
There's another issue too, which applies to both NRM exhibits and privately owned stock - units can be problematic when it comes to storage, simply because of their size. Storage costs money - where's the money going to come from? As an example, look at what happened to the Class 502 unit. No real demand for its regular use, and it was very much route restricted, both for the 3rd rail aspect and its sheer size - they are very wide. It sadly fell into disrepair and was dropped from the National Collection. (I wish its supporters well, for the record. I travelled many times on those units in my youth...)
If it meant that the likes of 1881 and the Derby SUB had remained in Preservation then yes.
as per the original plans for 1881.
As for the LED Lights on the front end - Just to avoid the small yellow option?
I think i'd rather have either seen the Small Yellow return with original and authentic SR Jumpers, or the GBRF 73/9 option - no Yellow but allowing the SR Jumpers back on.
Return of the Brighton Belle delayed awhile
Our hopes to see the Brighton Belle returned to the mainline in the same year as the Flying Scotsman were not to be. After a frustrating year be-set by problems with the complex re-wiring of the motor thirds and resource constraints, the Trust reluctantly took the decision to leave its home at Barrow Hill, a process which cost almost six months of productive activity.
The Trust paid fulsome tribute to the ground-breaking work carried out by Rampart Engineering. They were able to achieve what everyone said was impossible and Paul Ramsden should be proud to have created a national centre of excellence for heritage railway restoration at Barrow Hill. Our problem with hitting our stretching targets has been one of capacity the ability to work on at least four cars at the same time.
The new home for the project is at W H Davis at Rotherham, where all of the Belle cars now sit in a vast building akin to an aircraft hangar, with all components and spares sat adjacent to each car in racked out shipping containers. The project has suddenly moved up a gear by virtue of the massive space available, finally allowing the application of lean manufacturing techniques to the project with all the assets to hand instead of being stored at multiple locations throughout the Chesterfield area. A game changer
The professionalism of the W H Davis management team has allowed an excellent working relationship to be quickly established and the team has access to a large in-house engineering resource to accelerate completion of the project. Problems with the complex wiring systems apart, this final phase is essentially a production line; all of the engineering challenges have been fully resolved and the conditions set by the Rail Regulator are being met.
After re-launching a four car Belle unit, the speed of the completion of final two cars will be a simple product of the rate at which funding can be pulled in. The Trust is crossing its fingers that, with a tail wind, mainline testing might be completed by the end of the year, but getting it right is more important than doing it quickly - we'll keep you posted on progress.
Unlike Vivarail, this is made of mostly wood?
