Ash Bridge
Could 91's end up on the sleepers?
Is their low tractive effort rating sufficient for operating the Caledonian Sleeper though?
I can't see a bright future for the 91s, unless something quite spectacular happens.
Then the ghastly Voyagers could all be shunted off to Scotrail or Northern Rail or anybody else who needs a 5-car unit?
In a few years time when the MML electrification is complete there'll be plenty of spare 5- (and 4 and 7) car Voyager derivatives, in the form of the 222s. No-one seems to know if they'll have a home to go to, so trying to palm the Voyagers off seems a bit premature to say the least.
Waterloo-Exeter and South Coast - Bristol will need replacement stock for the 158/159 sets sooner or later
Ten or twelve coach rakes would be too long for some platforms on the Cross Country routes, would destroy the fast Voyager timings we have at present and would be grossly excessive for the levels of passenger demand usually experienced.What about using the Mk4s on Cross Country services as 10 or 12 coach rakes being hauled by class 67s, 68s or 57s?
You'd have to fit all-new bogies, as the design currently fitted were never designed to tilt. SIG would have developed a tilting variant of the bogie for the proposed West Coast sets.why not carry out the original cascade plan, finally fit the Mk4's with the tilt mechanism they were planned to have and use them on the WCML? Thats where they were supposed to go once they'd been replaced on the ECML by TGV-type stock. The carriages were intended to have tilt, the locomotives not (but still run at 125 on the WCML)
The class 91s have been through two rounds of reliability improvement programmes now, the chances are by the time they are withdrawn from East Coast services in 4/5 years time their reliability will be starting to deteriorate again.Surely its nuts to scrap locomotives that have had £millions spent on them just because the accountants now run the railways and EMU/DMU is cheaper to operate on the balance sheet.
Well, Mk 3s date back to the late 70s, so I'm not surprised they look dated.
Mk 3s looking dated? I must be getting old!
There aren't *that* many different ways to do a long thin metal tube with seats and windows. And the 800s look dated before they even enter service because of the sliding doors.
What was the reason for selecting sliding over plug in the end?
An obvious answer would be that sliding doors open/close faster and therefore reduce station dwell times.
That the Japanese don't "do" plug doors. All Japanese Shinkansens are sliding-door, which does make them look a little dated to a European. I think they argue they are simpler and so more reliable.
ScotRail's new AT200s will have plug doors, but I believe ScotRail had to be quite pushy to get them, and the body still has large blank areas where sliding doors would go if they were fitted.
Remove the slamdoors and they don't.
It seems strange that this is the case. Surely the aerodynamic profile of sliding doors is worse? I'm not an expert in fluid dynamics, though.
There is the proposed Manchester to Basingstoke via Milton Keynes and Oxford service. The route should be fully electrified. 110mph non-tilting or 125mph tilting EMUs would seem the ideal stock.
They are roughly the same age though.
