You see, this makes sense to me. All I'm asking is why it can't be the same with TPWS?
Because things are getting mixed up.
You cannot simply isolate and reinstate the AWS because the isolation requires to use of a switch that is latched into the isolated position and cannot be reset except by a fitter. That's fine if you happen to have one nearby, but even then it is unlikely that an isolation would be granted or even necessary if you found your train "stuck on a magnet". All you'd need to do is "key out" of that cab, change ends and move the train a short distance so that the affected cab is no longer on the magnet.
Dealing with a train stuck on a TPWS grid is even easier because you can still move the train from that cab. There is no need to isolate the TPWS.
Also, for clarity:
The TPWS Train Stop Override and Temporary Isolation Switches are there solely to prevent the TPWS from activating and initiating a brake application when the TPWS receiver passes over a set of live TPWS grids.
A steady TPWS Temporary Isolation light means that the system has been temporarily isolated by the driver. Any other issues relating to the TPWS and it's ability to function would be indicated by a flashing light denoting a fault.
Setting up the cab with the TPWS receiver over a live TPWS grid interferes with the self-test, as indicated by Moggie. However, the information he gives is slightly incorrect (no doubt an issue with the source material). You
can get a brake release with a TPWS fault indication. I suspect there is some confusion between a TPWS fault and a TPWS false activation.
To go on:
Whether or not this problem was foreseen at the point where the system was designed and developed or whether it simply came to light later as a result of operational experience is unknown. Arguing it one way or the other is impossible, as is trying to use it to attribute blame.
The fact of the matter is that the problem exists. However, I don't know of a single driver who is unaware of it or does not understand how to deal with it. It really is no biggie.
O L Leigh
