Class 314 Withdrawals
Bikeman78
26 Apr 2018
I wonder which units will be withdrawn first. A few months ago I remember there were teams of surveyors on a few 314 services who were presumably evaluating which units were more reliable and which ones will be going to the scrapyard first. Over the years I’ve been able to pick favourite units (weird, I know), so I’m hoping 202 survives as long as possible.
314202 was my last one for haulage. I finally caught up with it in May 2007, a few years after all the others. I did the sleeper to Glasgow and it was one of the first trains I saw. A return ticket to Neilston was rapidly purchased!
alangla
11 Apr 2018
Scot-rail gen site reports 3 class 314 units will be stood down from service tonight, apparently because the Ayr blockade had freed up some units. Not entirely sure how true this is.
Probably more likely that having 2x385 on a North Berwick and an extra two (so 4 in total) on the E&G has freed up a load of 380 units to return to Inverclyde. The Ayr chaos has probably helped as well though.
youngac
8 Sep 2017
ScotRail had an interesting response to a question about the future rolling stock on the Cathcart Circle yesterday.
‘You'll see Class 380s on Neilston & Cathcart Circle services, and Class 318/320s on the Newton route.’
Does that mean Class 385s are no longer to be used on any Circle/Neilston/Newton services?
SC318250
4 Jun 2011
I thought 380/385 6 car couldnt for in Neilston loop.
Wonder if it was mean to be 380 on Newton/Cathcart and 318/320 on Neilston
snookertam
22 Sep 2018
I'm not sure I would read too much into that comment by ScotRail's twitter. Unless there was going to be significant diagram changes then there will need to be some crossover between the diagrams. Neilston workings tend to stick to that route, whereas Newton via Maxwell Park & Circles are on the same diagrams. I reckon there will be some sharing of duties between the units on all services. There are 380 3 and 4 car stop boards now appearing at the Cathcart Circle stations, as opposed to the previous standard stop boards at the platform ends.
380s are allowed on the Neilston line, but if there's a failure at any point on the down line beyond Whitecraigs would need a wrong direction move to get it back. Down line is bi-directional as far as Whitecraigs - Muirend Crossover - why they left it there I don't know....
Not sure a 4 car 380 will manage so well on some of the busier services where there were 6 car 314s, but at least they have wider door vestibule areas than the 320s and 318s.
snookertam
22 Sep 2018
314 units original work was out of Yoker Depot on the Argyle line, so they've definitely been there before
Highlandspring
14 Oct 2017
Whilst I agree that 314s have certainly been to Yoker CS before, it only opened in 1987 when Hyndland Depot closed. The Argyle line was reopened in 1979.
Mag_seven
1 Sep 2014
here to eternity
Highlandspring
14 Oct 2017
Yes, 314s were still on the north side when Yoker opened. However they “originally worked” out of the long since closed Hyndland and Bridgeton depots.
JumpinTrainz
30 Jul 2018
Seems odd that they’ve actually started withdrawing the 314s. Doesn’t feel like so long ago 314212 was coming out of refurbishment with the new livery and interior. It really is nearing towards the end of an era for Scotrail.
Although I must say they’ve been great servants but it’s definately time to move on. Trains are far more advanced now (some may argue not always better), however this is a good step in the right direction for a more modern/efficient fleet.
Seems odd having 385s on Cathcart Circle lines somehow... I always feel 318s/320s would be a more worthy replacement.
alangla
11 Apr 2018
Probably the first in ages, if not ever, they have been to Yoker Depot
As far as I remember, they worked on the north side, mainly the Argyle line, up till the big unit reshuffle around 2000-2002 when the 334s arrived and the 303s were being withdrawn. This was the same shuffle that saw 318s appear on the north side lines for the first time
SC318250
4 Jun 2011
314212/207/213 have probably been stopped as they have come up for due a C4 overhaul
The next ones should be 314203/205/214/202 that will be due
314201 should be one of the last 4 to be stopped if it goes in order of last bogie change
route101
16 May 2010
Did the 314s only work Argyle services or did they do Springburn or Airdrie ?
I thought it was 320s that were not on Neilstons but im sure i seen one that way few weeks back .
Scotrail tweeted that the 1703 to Neilston will be a 380 Mon to Fri
Southsider
10 Aug 2015
320s have been on the Neilston line recently. Six car 314s most of the day yesterday.
Bikeman78
26 Apr 2018
One of the three off peak diagrams to Neilston is booked for a 318 Monday to Friday but often turns out a 320 instead.
Regarding the 314s, the off peak diagram to Wemyss Bay is now a 380 and two of the fast Gourock diagrams that were 314s have switched to 380s as well. There is still one fast and one stopping diagram for a 314 to Gourock off peak.
snookertam
22 Sep 2018
Six cars on a Sunday , strange .
It's been like that for a while now, seems to be connected with the Polmadie work. Newton services running through to Motherwell & Larkhall are 6 cars, and the diagrams on Sunday usually alternate between Newton & Neilston work.
snookertam
22 Sep 2018
Is this from the December timetable change? I was wondering where they'll get the extra 380s from to cover the Cathcart routes. Can only guess that the North Berwick handover to 385s would produce them.
EDIT: It was a 314 on that service today.
Bikeman78
26 Apr 2018
alangla
11 Apr 2018
Yes, 314s ran regularly to Drumgelloch/Airdrie, Springburn, Coatbridge Central, Lanark, Milngavie, Helensburgh and Balloch before the 334s arrived and 303s went.
Journeyman
16 Apr 2014
Agreed - the PEP-derived units have been reliable and dependable, and have got on with things without fuss for 40 years, but there's a lot of features in them that are pretty horrible. The window alignment has to be just about the worst you'll find anywhere - about half the seats don't have a decent view - and the seats themselves are ghastly. The detachable cushions are just about the right size to be tossed out the hopper windows as well! Add to that, the heating only has two settings - "off" and "nuclear". :)
I actually do quite like them, though, and will miss them when they're gone.
sannox
1 Mar 2016
The 17:18 peak to Weymss Bay and the return 18:24 is still a 314 set. It runs most of the night.
