The only other option I can think of is the busiest workings would have to be 6 car 150 workings on fully electrified services, which partly defeats the point of the electrification work!
They could of course significantly increase the amount of via Bolton EMUs by extending electrification from Lostock Junction to Wigan South Junctions
possibly cut Kirkby back
There's a reference in the CP5 plan to some 6-car DMU working on Manchester-Scotland even after electrification, at peak times. (ie 2x185).
This is because 1x350 is not enough and there aren't enough units for 2x350.
I know that it doesn't do anything for the number of redundant cabs, but I wonder whether Newton Heath would be inclined to form up some hybrid 3-car 150s again once there is some more rolling stock to play with post-electrification. At least there would be more consistency in their capacity.A 6 car 150 would be more wasteful than a 6 car 185 (unless it was the two prototype 3 car units doubled up) due to having 4 redundant driving cabs. A 6 car 185 would also provide a consistent number of seats, while a 6 car 150 using 3 random units out of the current Northern pool will provide many varying numbers of seats.
....You haven't stated how you would deal with the potential problem of getting too many passengers for a 4 car 319 on some services and not having enough paths for more services or long enough platforms for 8 car workings....
Perhaps I have overlooked something, but I am only able to count a total of 58 class 150s in use with Northern: 30 x Class 150/1s (18 of which are former FNW, and hence partially DDA compliant, units) and 28 x Class 150/2s (11 of which are former FNW units).Given that there's 27 x 2 car 150s at Northern with accessible toilets and 33 x 2 car 150s without and the 150s they could permanently make up 27 x 4 car units each with an accessible toilet to bring down the cost of making them DDA compliant.
Maybe I'm missing something here, but if there is consideration for using 350's on the anglo-scottish runs, couldn't you use "all new" 319s instead? presumably the 100mph top speed is the same a 350 manages?
Im not entirely sure, but I think that Transpennines 350/4s might be 110mph capable. The new 350s have also already been ordered at this point, so any suggestions about using alternate rolling stock on the Manchester to Scotland services initially is moot.Maybe I'm missing something here, but if there is consideration for using 350's on the anglo-scottish runs, couldn't you use "all new" 319s instead? presumably the 100mph top speed is the same a 350 manages?
This is what I believe is the appropriate total:I used Wikipedia but I'll work it out logically.
27 x 150s from FNW
10 x 150s from ATN
6 x 150s from LM as replacement for the 180s
4 x 150s from LM as replacement for the 4 x 156s that went to EMT
8 x 150s from LM as extra capacity
I don't even get 58!
