Class 387 to GN
23 Nov 2015
387s are limited to 100mph on GN.
So what's the point in transferring them, then, as they offer no advantage over the 377s other than less comfortable seats. In fact, they'd be better keeping the full complement of 365s, which are superior in every way.
jon0844
1 Feb 2009
I would hope that one day there's a plan to run them at 110mph. Just not yet?
D365
29 Jun 2012
SDO, built-in CCTV for DOO and there have been more 387/1s transferred than was planned with the 377/5s.
Depending on the compatibility of it to the infrastructure, that's a possibility. For the moment I see it as future-proofing.
Skimble19
12 Dec 2009
How does that happen? I mean, someone doing the work would clearly notice and say something to a manager - and then what happens?
Well, to answer your question: they get put in to service and nothing happens :lol: Had a fair few passengers and other staff commenting on it, and noticed it on at least 3 units myself. Not sure if they're the more recently transferred units or not.
Class377/5
19 Jun 2010
10 more units meaning more capacity.
It's an infrastructure thing. The 700s and 387 both have new pan designed that NR doesn't like on its delicate OHLE.
Er the 377 offer SDO, DOO as well!
Only advantage is that GN and SE get more Electrostars increasing capacity while GW gets more new build so everyone is a winner. Personal opinions of comfort aside of course.
D365
29 Jun 2012
Only advantage is that GN and SE get more Electrostar's increasing capacity while GW gets more new build so everyone is a winner. Personal opinions of comfort aside of course.
I was talking about the reason for replacing 365s with Electrostars of any kind, as much as I am a fan of the 365s.
Isn't the advantage of the change likely to be with SN, rather than GN, because SN end up with far more 377/5s that are more easily used in multiple with all their other existing and older 377 variants?
Failed Unit
26 Jan 2009
Central Belt
I know we have a problem with timings (as in the 317s and 321s need to go off lease before the 700s come in) but as we know 387s are less capacity in terms of seats and crush loadings. Passengers are very unimpressed that they are replacing the current units now they can't physically board. Surely keeping all the 365s would be a better solution for capacity and comfort. Along with less units to train staff on?
D365
29 Jun 2012
By replacing 21 365s with 29 387/1s, that's eight units gained compared to what was first planned (pre-GTR). And like I said earlier, the Electrostars bring several operational benefits.
387star
3+2 seems to be a thing of the past now
The 377 centre carriages are a chore to walk through with seats blocking where most of the aisle should be
I don't find the 387s too uncomfortable
43096
23 Nov 2015
Operational benefits and to hell with the passengers....
That's GTR all over.
jopsuk
13 May 2008
I do wonder if the timing had worked out whether 30 AC-only 379s (with some of the luggage racks and all of the catering docks replaced by seating and 1st class changed to 2+2) would be what's coming in onto the GN, leaving the Dual Voltage 387sfor Southern/Southeastern? And if that might still happen in the 2021 franchise?
Class377/5
19 Jun 2010
Ok, didn't read like that to me.
Southern doesn't gain anything. Intact they get less stock as originally the 32 Thameslink 377 were going to be spilt 19 for GN, 13 for Southern. Now the 32x 377 to Southern are replaced with the 32x 377 going to Southern so a net increase of zero instead of the 13 originally planned.
Mo 365 goes off lease until after all the 387s are with GN.
Yes because increased capacity (both seating and unsteated) is a horrible things to force on passengers.
D365
29 Jun 2012
What, because replacing four-car trains with eight cars is GTR's greatest failure?
I'm fairly sure that the Class 379s could be adapted for a DC supply, in any case the soon to be electrified 'CorPan' might well be the recipient.
Failed Unit
26 Jan 2009
Central Belt
How do you work that out?
We know an 8 car 387 has less seats than an 8 car 321 / 317 / 365.
We also know that a 387 has less space to stand than any of the above. We know that GTR has no intention of using SDO (as they stated on the web forum) so Saturday has significantly less capacity.
I can't see how passengers using the 0655 Cambridge-London service are getting any improvements in capacity? (As an example) In fact it is getting significantly worse.
They may increase some shoulder peak services from 4 - 8 car but the majority of people who travel in the peak or at weekends are going to see a significant deterioration in their service until the class 700s arrive.
...Now the 32x 377 to Southern are replaced with the 32x 377 going to Southern so a net increase of zero instead of the 13 originally planned.
You need to modify that I think. I'm not having much success working out you actually meant to write...
It still means that there are more "ex Thameslink" units going to "Southern" than previously planned when a number of them were going to Great Northern. But I wasn't actually referring to a "numerical advantage" as you must have assumed, but the "practical advantage" of having 377 variants being able to work in multiple.
But you then introduce a different and separate point, which I assume is to do with the fact that the total number of 377 variants with Southern is staying the same overall, because a batch are now leaving to somewhere else, perhaps Southeastern?
I'd love to know where the increased capacity is on the 18:23 KX to Cambridge. Reduction in seating, and reduction in standing room.
Went on 2x387 again last night. Once again the usual lottery as to which end the first class will be. No extra length over 2x365, and in fact what is a lightly-loaded train now felt cramped and crowded. Train had really bad flats, loud creaking noise whenever the train was moving, one of the internal sliding doors kept opening/closing, passengers complaining the interior was too hot, and PIS was displaying incorrect information throughout the journey.
Oh, and came away with back pain too.
Hardly an upgrade in any sense of the word.
Failed Unit
26 Jan 2009
Central Belt
Posted something similar. Waiting to see someone post what the crush load is. But considering the reduction in seats you have more standing before you even get to the 317 / 321 / 365 and there isn't much room to stand.
GTR have won on my journey. I no longer use the 1653 kings cross - Cambridge service. Moved onto 1722. At least while it is still 2x 321
jon0844
1 Feb 2009
The 387s really should have more room than a 317, but they do have a bit room in the vestibules which probably helps a bit?
I'm yet to use one at a very busy time - not even on TL. Off-peak they're quite nice and feel quite luxurious compared to a 365 or 700, and loads better than a 317/321.
Personally, I'm looking forward to the 700s more than the 387s. I'll trade some creature comforts for more breathing space, as well as the capacity boost on weekends.
43096
23 Nov 2015
Wrong. It isn't an increase in seated capacity.
29 387s replace 25 317/321s, so an increase of 16 vehicles. That equates to 6467 seats replacing 7391 seats, a REDUCTION of 924.
Only on "planet GTR" is that an increase.
D365
29 Jun 2012
And how many of these 'lost' seats are the middle seat which, according to most punters, is never used?
The 387s aren't going to be staying on former 317/321 diagrams for long anyway.
jon0844
1 Feb 2009
In the heavy peak the middle seats do get used but for a lot of the time people stand when there are many seats dotted about. Sometimes this is because it can be hard to go down the aisles, and if busy people don't want to get trapped (even if this isn't really a problem most of the time).
Please, please, *please*, can we get away from this complete myth that the middle seats aren't used?
Take a trip on any 317 or 321 peak service, and you'll see that they most certainly are used. Granted they're the last to fill, but it's a complete misnomer that they aren't used.
D365
29 Jun 2012
If the 387s had 3+2 seating, would they be any better received?
Failed Unit
26 Jan 2009
Central Belt
Of which i suspect some are needed to enable kings cross - kings lynn frequency to be increased. Good for the north of the route. But still much worse for the overcrowded bit.
Maybe, or more room to stand at least.
They would've be the best things since sliced bread if GTR had allowed sDO to be used and 8 cars sets at the weekends. Now more people will be left on the platforms and the 387s will be even less popular at stations south of Stevenage
Hadders
27 Apr 2011
Off-peak they're quite nice and feel quite luxurious compared to a 365....
I'm surprised at that. Although the 365s being 'dumbed down' at the recent refresh probably helps the case for the 387s.
jopsuk
13 May 2008
well, that's the temporary situation. The calculation long term is harder.
Failed Unit
26 Jan 2009
Central Belt
It is. But considering all the other things GTR have forced on their customers. (Such as mass cancellations) reduction in capacity even short term is an own goal. In particular when the units in question have SDO but GTR refuse to use it. Hopefully in December all weekend services will be diagrammed with 365s to at least give us a chance of boarding a train.
jon0844
1 Feb 2009
Yes that's why I said it. The 365s are still great but now much more 700 like.
Doesn't make them a bad train, but it was certainly nice for long journeys when they weren't so white and had carpets. Just a perception thing as the seats are (mostly) the same.
You wouldn't have an aisle at all then! People would have to board and alight via the windows!
Class377/5
19 Jun 2010
Its the interim period where stock is currently not in its final set up. But you, like another poster are forgetting than long term, less seats have to be offered as the accessibility regs means changes to toilets will reduce capacity on the older trains had they stayed in service meaning the gap comes down.
Easy.
32x 377 leave Thameslink
29x 387 leave Thameslink
GN gain 29x 387 vice 19x 377 so gain 10 extra units
32x 377 go to 'Southern' who release 32x 377 to Southeastern so Southern have zero gain but Southeastern has 7x more than the original 25x 377 announced.
So no there isn't actually any additional 377s going to Southern from the original stock plan, in fact the complete opposite is true!
Wait until the upgrade is finished before writing it off.
I was actually talking about capacity increase of swapping 19x 377 for 29x 387 but as for your figures on the 317/321, seems you've made some rather silly errors...
317 - 270 seats x 12 = 3240
321 - 271 seats x 13 = 3523
387 - 213 seats x 29 = 6177
317+ 321 = 6763 seats and that's without taking into account the requirement for accessible toilets meaning each unit will be lowered by something like 10-20 seats. Take a mean average of 15 seats removed and the totals are 317 + 321 = 6388
So yes there is some seating capacity loss but this will be off set by the increased length of trains meaning more seats. Once again it proof of the ability of this forum tunnel vision to block the overall picture whilst not actually comparing like for like.
Also note tat many users complain of not cycle spaces, new trains allow for this as well.
Yet every single time its discussed with commuters they want rid of it. There is research to back this view up. So what should you go with? Actually evidence or comments on a forum? Think you know the answer.
