Class 387
JN114
28 Jun 2005
Thanks JN114. I do appreciate your responses even though as a service user it is very frustrating!
Am i right in thinking that since the 387's are running all day HC are unable to turn at Hayes anymore? If so that just exacerbates the problem.
That exact scenario was looked at in the contingency plan review. Connect can run to Hayes bay with a full Electrostar service running - HC Unit and Driver need to step up one diagram to make it a 10 minute turnaround (so 2T18 becomes 2Y16, rather than 2Y18 it would form at the Airport) and that gives you a just-about working 4tph service in and out the bay. Heathrow aren't particularly keen on it, as apparently it doesn't really work with their driver diagramming, but I don't know any more on that.
However, if there's any subsequent limitation in capacity on the Relief lines between Hayes and Paddington will see the Connect service suspended to give priority to the higher capacity 387s, as it only works of everything is running on time. If Connect are suspended Hanwell is to be served 1tph with a Turbo, to mitigate risk of 387 calling outside of daylight hours. Hopefully can all be sorted out properly once Hanwell get some decent lighting.
Peter Sarf
Croydon
I wonder if some temporary lighting at Hanwell would be worth it while the proper lighting that is sympathetic to the architecture there gets designed and installed ?.
317 forever
21 Aug 2010
North West
We will have had 1 very short-lived operator of class 387s. National Express! They took up 6 387s but are now in the process of selling c2c to Trenitalia.
Skimble19
12 Dec 2009
The signal failure affecting only them was an ATP fault on the Airport branch. The 387 services called once it became daylight, 2S09/10 was to be the first circuit to do so, but Connect re-instated from 2T22 off Paddington at 0803.
Hanwell is a listed station, if it was that easy to just change the lighting it would have been done when they did the other stations in the summer. It isn't that easy, and that's why November 2017 has been given as an estimated completion date.
In that case would it not be sensible to temporarily allocate some dispatchers there during the hours of darkness? Or is it so rare that it wouldn't be worthwhile?
Class377/5
19 Jun 2010
It's not in the 387 dispatch safety case on GWR (I've heard) so would makes months to get everything signed off. Upgrading the lighting will be quicker.
Peter Sarf
Croydon
For those who want to know. On Monday 23/01/2017 the c2c 387s were working 12-car on the 17:16 and 17:43 departures from Fenchurch Street (both to Shoeburyness iirc).
Peter Mugridge
8 Apr 2010
Epsom
Yes - and they have them neatly sorted into odds and evens! The two rakes are, and apparently have been since before Christmas:
387 302 + 387 304 + 387 306
387 303 + 387 301 + 387 305
in that order.
I bashed both workings tonight ( it's their regular diagram ); rather conveniently both call at Limehouse meaning no need to risk the fairly tight leap back to Fenchurch Street from the first one - it can be done though.
Not often one can clear a whole sub class for haulage inside ½ hour...
Kite159
27 Jan 2014
West of Andover
in that order.
I wouldn't say the leap back to Fenchurch Street is tight, as you arrive a couple trains before the 2nd ECS rolls in
Peter Sarf
Croydon
in that order.
Ashamingly easy !!.
spark001uk
20 Aug 2010
I had my first go on a few 379s today (Stansted express), and after having a butcher's around once inside, I conclude these are basically 387s, going by things like extra marker light on front, power sockets at all seats, grab handle types, look of the toilets, etc etc
What I did notice however, was how the seats have had extra padding put on them, that the other sub classes don't have. It's made them rather more comfy in my opinion. Pic attached.
I tell you what, people following my posts today must be starting to think I've got some sort of seat fetish! ;)
jon0844
1 Feb 2009
The 379s are nice trains, but also suffer the same issue with cramped aisles.
For the services shared with airport users and commuters, they're pretty horrible for the time that they mix on the run. However, there was obviously a belief that people paying a premium to get to the airport should have some level of comfort - and they do.
First class is very nice on them, and positioned in a much better location.
It would be crazy for these trains not to be put into use somewhere else as quickly as possible.
Deepgreen
12 Jun 2013
Gomshall, Surrey
Victoria yesterday afternoon - the 1630 to Brighton. I was amused to overhear a guard/conductor/OBS (who can tell which?) that he hadn't been told about the "white" trains and wasn't sure if this was his working!
spark001uk
20 Aug 2010
...It would be crazy for these trains not to be put into use somewhere else as quickly as possible.
I agree, and it's a shame the extra padding in the seats wasn't chosen for the other sub-classes. Though I can understand, the others are mainly put into use for high volume commuter work. But the GX though, they should have put them in those, as like the stanEx the fares are at a premium.
Deepgreen
12 Jun 2013
Gomshall, Surrey
I feel I must have missed something here - are the 379s about to cease their Stansted operations?
spark001uk
20 Aug 2010
I think he may have meant it would be nice to have more of this class in operation on other routes.?
In my opinion the GX should definitely have had the same seating, also being a premium airport service and all.
Deepgreen
12 Jun 2013
Gomshall, Surrey
Ah - I agree with that, not to mention all the other 37xs! I thought I had missed an announcement that the 379s were moving home.
sjoh
7 Apr 2016
London, E11.
I suspect he actually meant post Greater Anglia fleet renewal in a few years. So, yes they will be moving eventually.
Deepgreen
12 Jun 2013
Gomshall, Surrey
Will they be replaced so soon? They are only less than seven years old - surely they have a long life left yet?
Edit - discovered this on Wikipedia :
"By 2019, the Class 379s will be replaced by a brand new fleet of Stadler FLIRT EMUs which will be fixed 12-car trains".
So, another question - what happens to them after 2019? Manchester Airport?
RichJF
2 Nov 2012
South London or Sussex
I think this pairing was out & about this morning! Either on the 1W86 to Bedford, or the 1A17 to Victoria. Passed my southbound train at Purley Oaks!
sjoh
7 Apr 2016
London, E11.
I believe there's a conversation going on about this in another thread (had a look, couldn't find).
Your guess is as good as any, there have been a few suggestions in these forums but the truth (as always) is that no-one really has a clue...
Class377/5
19 Jun 2010
As the pair is GX-operated, I assume it wouldn't stray to TL.
No 12 car 387s on TL either now.
Soon the only way to ride a 387/1 on TL will be 387124 on GatEx services.
Kite159
27 Jan 2014
West of Andover
Soon the only way to ride a 387/1 on GN will be 387124 on GatEx services.
Don't you mean Thameslink rather than GN there? :)
At least the good news is that if you see "formed of 12 coaches" on a Thameslink service it will pretty much be a 700 (and not a trio of 377s like I had last month on a late evening service)
Class377/5
19 Jun 2010
Oops!
Been no booked (weekday) non 700 12 services on Thameslink since the late summer IIRC.
southern442
20 May 2013
It would be absolutely fantastic if they converted them to third rail use for GX - but it seems unlikely to happen.
jon0844
1 Feb 2009
Not for a while, but GA is replacing all its trains so they'll be off somewhere. No doubt with a ROSCO perhaps having to reduce the fee with a lot of other stock to choose from.
OFFDN
30 Nov 2016
Herne Hill
I was under the impression that a number of 387/1s would be doing something else after they are released from TL duties but before they move to GN...
Class377/5
19 Jun 2010
Was never a plan for that. Always was cascade out and straight to new home. Initially to GWR but that changed last year to GN so they went straight there.
OFFDN
30 Nov 2016
Herne Hill
What I meant was that there were conversations happening yesterday to get 387/1s to cover the remaining 442 work until May when they are needed on GN, allowing the 442s off lease and giving the 387/1s something to do before the full 387 fleet is needed for the May timetable change.
