MatthewRead
Although allegedly according to some sources the 319 flex is being considered for the North Downs route.
Makes sense to me
I've looked it up for you. In 2014-15 total entrances and exits amounted to
Bramley: 273790 of which 1/3 were seasons. About 750 per day
Mortimer: 186084 of which 1/3 were seasons. Just over 500 per day.
and to complete the group
Reading West: 412642 of which nearly 40% were seasons. About 1,100 per day.
It should be noted that Reading West is also served by the half-hourly Newbury stopping service.
I leave it to the reader to decide whether the service at Mortimer and Bramley is excessive. It has been half hourly for many years.
Whether stops should be removed is only an issue if (a) the station at Green Park is built and (b) trains stop there and (c) trains of the same power-to-weight ratio continue to be used.
Makes sense to me![]()
Doesn't make sense to me. The D319 would be far less rapid, plus it takes us right back to the same microfleet issue.
Newbury stopping service is only hourly, the Bedwyn semi-fasts skip Reading West.
On a similar note, would the Class 230 be suitable?
There are no aspirations on the part of the DfT or Network Rail to electrify the North Downs line, let alone any plans or funding.
There was never any intention to cascade all the Class 165/166s away from Reading to elsewhere.
The situation with the proposed station at Green Park, and with the other suggested station at the other end of the Reading to Basingstoke line at Chineham, is a bit more nuanced. At the moment two dmus can maintain a 30 minute interval service as there is sufficient turnround time at each end of the journey. Adding another stop means that, for reliability, 3 dmus would be needed for the same interval. As the number of additional passengers from either or both of Green Park and Chineham would not increase passenger numbers by 50% - to pay for increase in the train fleet of 50% - the economics of the operation become untenable.
To get round this the journey time needs to be reduced. This could be done by increasing line speed - but the short distances between stops does not make this very effective - or by increasing the trains' acceleration. This means more horsepower - so a more powerful dmu or electrification are the only ways to maintain a 30 minute interval with two trains.
Both solutions are expensive - the second more than the first.
Monday's GWR delivery in the system now, here. Later path this time.
The GWR 387/1 are to be used for that under some plans that have been talked about elsewhere.
2 things: I see last night's Bletchley - Reading TCD delivery was changed last minute to North Pole, what gives?
Also, I've just come past Wembley yard and there's a shiny green 387/1 sat there? Didn't see the number.
It proved very difficult to deliver the unit to Reading TCD at that time of night last time round - both in terms of resourcing a conductor driver and in terms of the delivery (with the need to run round / shunt barrier wagons getting in the way of normal Depot operations). An agreement was reached with North Pole to accommodate a 9th unit for delivery purposes - I would expect to see one moved to Reading to balance in the near future as I'm sure Hitachi are thrilled at having to give up more Depot space to us.
OK, cheers for the info. Could they not have dropped it off / moved it to West Ealing? Or are the Sidings still not ready yet?
Could have been pathing issues, just a guess but I'm sure our Reading TCD buddy will let us know as soon as he knows
It proved very difficult to deliver the unit to Reading TCD at that time of night last time round - both in terms of resourcing a conductor driver and in terms of the delivery (with the need to run round / shunt barrier wagons getting in the way of normal Depot operations) .
To be fair... Hitachi don't really have any of their own units to fill the depot![]()
Could have been pathing issues, just a guess but I'm sure our Reading TCD buddy will let us know as soon as he knows.
Regarding the 387 at Wembley, that could have been 387142 or 387143, both were out on test between Wembley and Crewe today. The 387 numbers for GWR just keep rising, nothing stopping the production site at Derby I see! Very efficient!
I think GWR are soon going to have space issues for these! All I can think of is ROG taking a few more to Reading for the time being?
Which would be great, but you seem to be overlooking the small issue of the fact we still have the LTV fleet (minus 166215 & 150002) to maintain!
We ain't the TARDIS, that's for sure!!!
What's happened to the starship 002 then? Not blown up again has it?
Relocated to Bristol St Philip's Marsh.![]()
The situation at Hanwell really needs resolving. HC services all cancelled this morning due to a signal failure seemingly affecting only them.
A full (3 coach only :rollGWR 165 stopping isn't good enough as a replacement when it leaves passengers behind - especially when you've got 8 coach trains with plenty of room passing through stopping everywhere else.
