Class 387
Aictos
28 Apr 2009
What are the 387s working today? Looking at covering the Brighton Mainline on them if possible.
Class377/5
19 Jun 2010
Cheers, couldn't see the ends of the unit, as was hiding behind the wall from my view on this 390. Imagine on way south from The factory?
Nope. Factory moves are diesel dragged from Derby to Bletchley via Bedford. What you saw is the AC commissioning run from Bletchley to Crewe via Wembley. Other commissioning path is Bletchley to Brighton and return.
chris89
21 Dec 2009
Edinburgh
Thank you again :D
Class377/5
19 Jun 2010
Just seen the new working from Monday confirmed. There will be 14x 387 diagrams with only 5x 319 departures all day from Brighton in the week.
RobShipway
20 Sep 2009
If we are down to 5 departures from Brighton for Class 319s, then if you work on 1 Class 319 a week coming off service then I would suspect that the week beginning 23rd March there should be no Class 319's doing Thameslink services.
This of course does also depend on how the Class 387's are being delivered.
Class377/5
19 Jun 2010
Any idea when that is likely to be 0 x 319 departures from Brighton in the week?
I'd say no 319s by May as they attentions simply putting a 387 into a 319 diagram. They need to rewrite the diagrams around as many units swap between routes.
Current situation is 16x 387 have been in service with 387120 still to be in service. There is 14 required from Monday giving a float of 2 units with 1x 387 away for other duties.
LBSCR Times
17 Sep 2013
Sussex born and bred
Can you confirm which 5 weekday departure will remain as 319 as of Monday?
Thanks
AFAIK
Departures from Brighton at
07.00 / 19.08 / 23.02 / 23.36 / 00.10
With an empty at 22+22 to Blackfriars.
The departures from Bedford are at
03.42 / 16.08 / 17.54 / 19.54 / 20.22 / 20.52
However, the majority of the Three Bridges locals are 8.319.
bb21
Emeritus Moderator
4 Feb 2010
Can anyone confirm today's workings for 387s or is it the same as weekdays?
Class377/5
19 Jun 2010
Keep the decrepit 319s with the great unwashed north of St Pancras.
Its sensible planning as 319s need to stay on Sevenoaks and Sutton services to you keep the 319s where fellow class mates are incase of an issue. This won't change much until the arrival of the first 8 car 700.
14x 387 diagrams today. Haven't compared the working from today with weekdays tho.
richa2002
8 Jun 2005
Once all 387s have arrived, is it expected that there will be no diagrammed 319s on 'fasts' between St. Pancras and St. Albans?
Class377/5
19 Jun 2010
Nope. There are fast services that go to Sutton and Sevenoaks and these will continue to be 319s.
Minstral25
10 Sep 2009
If 387 121 has been in service but only 16 in total, where are the other units that haven't seen service?
Peter Sarf
Croydon
If I recall correctly 387101-387104 and 387122-387129 have not seen service yet. That gives 17 units used and usable so far (i.e. 387105-387121 inclusive). OK perhaps 387120 is on other duties rather than in service. Class377/5 will have the correct info.
RobShipway
20 Sep 2009
If the missing 387's have been released, some maybe doing standby duties possibly?
With others maybe still doing running tests, before being released to Thameslink?
Class377/5
19 Jun 2010
387105-119/121 have been in service. Not been around to see if 120 is in service. There's still units damaged from the flood waters affecting availability. Plus one unit is out of the service pack for other duties.
Don't forget the 387s require maintenance like any other stock which is why you have a float of spare units to cover.
MCR247
7 Nov 2008
Don't you mean more maintenance - they were made in Derby after all! Replacing the door buttons that have fallen off must be quite time consuming for staff :p
samj
3 Oct 2008
Southern liveried 319214/216 were out on Brighton-London Bridge duties today
Yabbadabba
23 May 2014
The spares just floated off after the great Farringdon flood lol :D
Ok I apologise for the bad humour.
southern442
20 May 2013
Does that mean that the Brighton line will be completely devoid of 319's by the time all 387's are delivered?
Which line will see the 700's first?
