Class 387
AM9
13 May 2014
St Albans
What's wrong with the announcement?
Look out for new train smell on 387121 on its first day.
301 387116/302 387118
1W04 05:44 Brighton to Bedford
2W23 08:40 Bedford to Three Bridges
2W30 11:14 Three Bridges to Bedford
2W43 13:40 Bedford to Three Bridges
1W92 16:14 Three Bridges to Bedford
1W57 18:24 Bedford to Brighton
1W68 21:30 Brighton to Bedford
303 387108/304 387106
1H83 06:34 Bedford to Beckenham Junction
1G63 08:02 Beckenham Junction to Bedford
1W21 09:54 Bedford to Brighton
1W32 12:38 Brighton to Bedford
1W43 15:24 Bedford to Brighton
1B50 18:28 Brighton to London Bridge
1B55 19:42 London Bridge to Brighton
1W66 21:02 Brighton to Bedford
305 387109/306 387112
1W01 04:16 Bedford to Brighton
1W83 07:24 Brighton to Bedford
1W23 10:24 Bedford to Brighton
1W34 13:08 Brighton to Bedford
1W45 15:50 Bedford to Brighton
1W56 18:38 Brighton to Bedford
1W69 21:22 Bedford to Brighton
307 387121/308 387110
1W00 05:10 Brighton to Bedford
1J88 07:58 Bedford to Elephant & Castle
1G69 10:04 Elephant & Castle to Bedford
1W29 11:54 Bedford to Brighton
1W40 14:38 Brighton to Bedford
2W61 17:20 Bedford to Three Bridges
2W62 19:44 Three Bridges to Bedford
1W73 22:22 Bedford to Brighton
309 387109/310 387113
1W84 06:54 Bedford to Brighton
1B14 09:28 Brighton to London Bridge
1B19 10:42 London Bridge to Brighton
1B24 11:56 Brighton to London Bridge
1B29 13:12 London Bridge to Brighton
1B36 14:56 Brighton to London Bridge
1B41 16:12 London Bridge to Brighton
1W97 17:38 Brighton to Bedford
Thanks for that. I'm on the 11:54 from BED.
It's a bit untidy but it has been in service for 7 whole hours now!
It's an irony seeing all the approving looks from passengers who having seen the TL posters don't realise that these trains are just loaners. The cattle trucks start arriving next year.
asylumxl
12 Feb 2009
Hiding in your shadow
Bombardier already know about this, I've spoken to the guys who travel around on them it's a missing audio file, should be sorted soonish.
Yeah. It was obviously something along those lines, but the question is why was it missing in the first place? Do they not check the PIS before they hand the train over?
Also, why use audio files? Text to speech voice synthesis has improved a lot in recent years. There are plenty of lightweight, open source systems they could use.
Class377/5
19 Jun 2010
Believe is to do with the name change that was supposed to have happened in December.
SPADTrap
15 Oct 2012
Sorry if I've missed it but is there any indication where the 387s will go after TL have finished with them?
21C101
19 Jul 2014
Luton Airport. Originally (like first few days) the 387s used this.
Thats certainly less of a mouthful, however they use Luton Airport for the other end of the shuttle bus on national rail website timetable enquries so that might have put a spanner in the works?
I wish they would formally rename Luton as Luton Town to make clear the distinction.
Kite159
27 Jan 2014
West of Andover
That would confuse some passengers using Luton Airport for the first time, thinking the station would be nearby the airport (like Gatwick/Manchester) rather than a bus-ride away. Ah well ;)
LLivery
13 Jul 2014
The track is suitable for 110mph South of Bedford not 125mph. The wires however were built for 100mph. The increased speed along with the multiple pans means the wires may not cope with the extra pressure. One pan creates a ripple, the second creates another. A third can cause the wires to move to far. To counter this the wiring set up must be different. One reason for the cost increases on the GWML is making the current OHLE suitable for trains up to 125mph and multiple pans up (ie 12 car Suburban train) at the same time.
Ahhh thank you! I completely forgot the wiring issue.
Will the 387s ever announce Parkway properly?
You'd think Bombardier could have at least managed that before they went in to service...
No Southern train can say Sydenham correctly even though Southeastern can. Compered to Sydenham, Parkway should be a doddle.
Not opening at all IS a problem, but the others are slow enough that they cause frustration and I dare say confusion/panic with some unfamiliar passengers (especially tourists).
This problem needs to be fixed, somehow, for good.
I've been on a 377 at Anerley and it took two/three minutes to open the doors. You would have thought they would have sorted this out by now - the S Stock manage it
hassaanhc
5 Jan 2014
Southall
S Stock manage it because they have trackside beacons at every station, whereas 377s only have it at a select few and mainly rely on GPS!
But then that would confuse people into thinking they'd arrived at Kenilworth Road.
Although that could be solved by renaming the latter Luton Town Nil.
Class377/5
19 Jun 2010
Well if would make sense to have beacons in the core for every station, since it's quite like the sub-surface lines.
There's been beacons at Core stations since 2009, ie before the 377s were introduced (in fact they were needed for 377 operstion).
James Wake
30 Aug 2013
A pair of 387s sat down at East Croydon this morning, with 106 at the rear. Blocked platform 2 for some time, southbound.
Was a train fault, it was actually on 0724 BTN-BDM, but terminated at ECR, caused 5 min delays on 0825 and 0828 trains to LBG and 0830 to VIC.
SN319
5 Apr 2014
Does anyone know if any of the weekday 12/42 departues from LBG-BTN are worked by 387's?
user15681
3 Jun 2012
At the moment, 10:42 and 13:12 departures from LBG are booked for 2x387 - same diagrams so same two units on both services.
