Class 397 125mph?
HSP 2
4 Dec 2019
11B
Three stretches of track that they may Wigan - Preston, Preston - Lancaster and Lancaster - Carnforth. Not sure about north of Carlisle.
matt
30 Jun 2005
Rugby
Do any of those sections have a speed limit of 125 for non-tilting trains?
HSP 2
4 Dec 2019
11B
So the only units that can run on the W.C.M.L. at 125 mph are Pendos?
driver9000
13 Jan 2008
No they don't. 110mph is the current maximum speed on their routes. They have been tested to 125mph on the WCML but work to raise speeds seems to have gone quiet.
Huntergreed
Events Co-ordinator
16 Jan 2016
Dumfries
Probably might wait until HS2 is closer to completion (as the stock is non-tilt, and there's certainly some opportunity to get in some 125mph running without tilt from Crewe - Glasgow)
dave59
28 Jul 2010
Thought so. The Railcam camera at Thankerton (which is a 125mph stretch) shows the 397's going at a very leisurely pace compared to the 390's.
It's a 125mph stretch for tilting trains (known as the Enhanced Permissible Speed). As mentioned the general maximum on the WCML for other trains is 110. I think there used to be a short section of 125 in the Motherwell area, used by the ECML trains via Carstairs, but not really long enough to make much difference to journey times.
Cheshire Scot
24 Jul 2020
North East Cheshire
Was that an HST differential rather than a general line speed? If it had been still in place 397 could have used it albeit as you say without much difference to journey times.
Ianno87
3 May 2015
Yes, there's a short burst of HST differential on the down between Shieldmuir and Motherwell.
hexagon789
2 Sep 2016
Still there but 105 not 125, limit is 90 otherwise
There's nothing faster than 95mph on the Edinburgh-Carstairs line (and no EPS/TASS tilt equipment).
Carstairs-Glasgow is TASS-equipped for about 2 miles on the Down through Shieldmuir, offering EPS/tilt at 105mph, but otherwise slower and no tilt.
Effectively, WCML tilt ends at Carstairs South Jn from the south.
Things might possibly change when the promised Carstairs remodelling/upgrade is done.
hexagon789
2 Sep 2016
This is the section I was thinking of both EPS and HST 105:
driver9000
13 Jan 2008
100mph for non tilting trains passing the camera.
AGH
15 Feb 2021
Newton Le Willows
I don't think the top speed of these is that important. Their acceleration is excellent so suspect that they get to and stay at maximum speed quicker and the additional blast of extra 15mph won't have much effect on overall times
Yes, that's one of the odd sections of the WCML (the others are on the Birmingham loop) which allow common HST/EPS speeds.
On that route, presumably that just applies to Azuma/IC225 sets and 397?
It's downhill anyway, and 2 miles is not going to make any difference at all to journey times (before the signal check at Motherwell!).
driver9000
13 Jan 2008
397s aren't permitted to run at HST speeds but they can run at MU speeds.
hexagon789
2 Sep 2016
It means two extra miles of 105 for EPS/HST trains, the limit immediately before is a pure 105, so it means the reduction to 90 can happen later.
HST speeds apply to trains permitted to use MU or SP differentials.
No mention of 397s or HST speeds applying to MU or SP differentials.
The only note is that - "ScotRail HSTs may run at HST differentials, note 2.2 does not apply".
Cheshire Scot
24 Jul 2020
North East Cheshire
I did wonder if that table had not been updated to include 397 but then I noticed 350 are not listed either.
I had understood it was a general principle that units cleared for the 'lighter weight' differentials such as MU or SP also take the 'heavier' differentials which apply to HST.
Class 80x are also not included but I would have expected them to be able to run at HST speeds on the former LNER HST routes such as Edinburgh to Aberdeen, but clearly not.
hexagon789
2 Sep 2016
I hadn't noticed that omission, seems strange as they can use HST speeds on the Western area.
I would suggest the data hasn't been updated to reflect it but there is a note for the shortened ScotRail HSTs.
Does seem peculiar but I'm almost certain they are allowed to use HST differentials otherwise they'd be even less able to keep timings north of Edinburgh.
hexagon789
2 Sep 2016
I think it is an omission, because here is the list of permissible speeds in the London North Eastern SA, and 80x appears under HST:
Cheshire Scot
24 Jul 2020
North East Cheshire
Class 397 SOC dated December 2019 states they can take HST differentials. Extract attached.
'AT300' SOC of the same date likewise states class 800/801/802 can take HST differentials.
Unless these have been subsequently rescinded - I do not have access to any subsequent SOCs - there is a conflict between the SOC and Sectional Appendix, Does the Sectional Appendix overrule the SOC? I'd guess from the above it probably does, maybe one for the relevant TOCs to progress with Network Rail.
  • extract from Class 397 Service SOC Dec 2019.docx
Shwam3
13 Jun 2011
Norwich
No, SoCs overrule the sectional appendix.
hexagon789
2 Sep 2016
Other way round afaik, which I think proves the Scotland SA needs updating
