Apparently you can taste the diesel, I don't know if they mentioned it.
I know what they mean. The thick fug that seems to get inside Thames Turbos makes me want to puke, as does the same from idling Voyagers at New St.
That makes you sound very priveleged, and also detached with the real world.
I've never been in or seen a house with air conditioning.
In the UK it's almost none. And they are not to be encouraged - it's a massive waste of energy. (Unlike a moving vehicle, where the improved fuel efficiency by having a perfectly flat bodyside can offset it).
Because there's never been a replacement built with similar characteristics. Nothing built since has managed to combine the TE and RA of a 37, which is why they remain popular machines for this sort of work.
"This sort of work" should be done by a modern 4-car (or 2x2-car) DMU. And the only reason such DMUs aren't in existence is bad planning and rolling stock strategy. If there was one, it'd be hugely cheaper for this specific work than a Class 37.
It's essential in the south!
Is it heck. Most homes in the South don't have air conditioning, either - I'm not sure I've ever seen *one* in MK, for example.
I guess you must live in very much a premium area?
Around 2/3rds of the homes in my street have some form of air conditining equipment installed. It's great. Mine keeps the place comfortable in summer and is an efficient source of heating in the winter through heat-pump technology.
Great in the winter, but an almighty waste of energy in the summer. We should instead be designing homes that are naturally warm in summer and cool in winter, then adding heat pumps to *heat* them.
I don't get it, the house buyer made an assumption so Northern should try and sort it out?
Locomotive and DMU engines should not be left idling, full stop. They should be started when the locomotive or unit needs to move, and stopped when it does not.
If, as I suspect, an old design like the Class 37 does not support this, it's not fit for purpose and should be scrapped in favour of something more modern. And all the 15x should be modified to allow immediate engine shutdown, which they presently don't.
The Germans have had this right for years. DMU arrives at terminus, engine off. Two minutes or so before departure, engine on. Since the 1990s or earlier. Shore supplies should be provided if required for hotel power or pre-heat, for example, though really a non-aircon DMU shouldn't need one, the batteries should be quite sufficient for a typical short layover.
My impression is that was the case. There's a difference between a passing loco, no matter how noisy, and a 37 ticking over for extended periods. I once had a neighbour who left his diesel Jetta on for half an hour under my bedroom window every morning. By the time he left for work my bedroom looked like a London smog and my eyes were streaming.
Agreed, this practice is considered antisocial in the context of road traffic, no reason it should not be seen as the same in the context of rail traffic.
New St, for example, is horrible when a Voyager or other DMU is left idling. Switch the thing off.
They buy, pointless, fans at most.
Fans aren't pointless. Moving air helps our body's natural cooling mechanisms to work better.
Air conditioning in buildings is nothing other than a combination of poor design (I'm thinking wall-of-glass office buildings here) and a complete waste of energy. TBH, I'd actually be happy to see it banned in new buildings in favour of more sustainable design. I understand it's actually already restricted in Switerland, FWIW.
