- Joined
- 15 Apr 2008
- Messages
- 15,965
None of it would ever need 4 tracking, how many trains are people expecting?!
You don't automatically get (or need) 'intercity' services just because a line connects two cities though. You generally need quite a few cities, and often a London terminus...Coventry and Leicester are cities, so one would think that, if the line were re-joined, an inter-city service would be justified...
You would build the underpass, the loop is barking mad and would cost a fortune. Nuneaton North Chord is only signalled in the down direction anyway and you would have to go wrong road through P7 at Nuneaton in the down like the freight has to.
If the points leading into the underpass on the Leicester side (of the WCML) were of a triangle ish formation, couldn't trains go into Nuneaton on platform 6 and do a reversal and into the underpass line and on to Coventry?
That way they would retain a Nuneaton call, if needed, whilst still doing the move via the new underpass to Coventry.
No it (Nuneaton) isn't. The populations are:
- Coventry 350,000 (see Wikipedia or Coventry City Council website)
- Leicester 329,000 (Wikipedia)
- Nuneaton 70,000 (Wikipedia)
££££££££££££££How about constructing a Tamworth style interchange at Nuneaton with a high level and a low level station (but with more pleasant passenger facilities than Tamworth)?
How far south is the actual route of the (now missing) chord? Would it be possible to build a platform on it and link it to the main station?
Change at Nuneaton for Coventry seems the best option, but increase the service frequencies on the Nuneaton - Coventry and Leicester - Birmingham routes is where the traffic is. Try getting a seat from Nuneaton to Birmingham at even off peak times.... Standing room only in my experience.
See for yourself, it's here on the 1:25k map:
It's where the little long thin lake-like object is shown under the main line. So it's about 500m from the station.
The bridge on the old chord south of the station has been recently used to run high voltage feeder cables under the main line from a large substation near the site of the former signal box. To move this installation would add a significant cost to any new works.
As a local I cannot see a simple way to effect a reversal at Nuneaton without crossing the WCML on the level, which I cannot see being allowed given the large sums spent on creating platforms 6 & 7 and the North chord.
In other words, get on a train to New St and change for one to the Airport? Going via Sutton Park, Walsall and Aston would take longer than changing.
No, they just cross each other with no connecting curve in any direction.Oh right. Is there not a link/chord between the down from derby and the Coventry bound stour valley line?
Wasn't sure, presumed there was?
A rail campaigner has said plans for a valuable direct link between Coventry and Leicester will not be up and running any time soon.
The connection, proposed under a multi-million plan to restore a disused line, would slash commuting time and end the need to change at Nuneaton.
Council, business and industry chiefs estimate the route would provide an economic benefit of between £25million and £65million a year and help with the roll-out of HS2, scheduled to begin in 2026.
However Michael Tombs, of Coventry Rail Action Group, doesn’t believe commuters will be jumping on the route in the near future.
Indeed - a travesty of justice enacted to save money. WCML passenger benefitted - while Coventry - Leicester - Notts missed out.There was a Nottingham-Coventry service that was finished because of the WCML route modernisation. It crossed the WCML on the level and reversed in Nuneaton.
Rob
I don't know whether the paths could be found but to me if the rumours are true that the new West Midlands franchise are wanting to expand their operating area it would seem a much better idea for services to continue through New Street to Leicester rather than going on to Cardiff by a very indirect route.Indeed - a travesty of justice enacted to save money. WCML passenger benefitted - while Coventry - Leicester - Notts missed out.
Reading peoples' more expert contributions on here, it seems a tough one to get back.
Certainly changing trains at Nuneaton is a barrier for many ordinary folk - but if Nuneaton - Coventry could become 2 TPH, especially with one onward to Leamington, it would be much better.
Also, looking at the ORR figures, every station on the Brum - Leicester line showed a decent increase last year, including S Wigston (75,000 to 80,000) and even near-orphaned Water Orton (45,900 to 51,700) - I've rounded those numbers out - neither of which enjoy a particularly good service (both are sort of 1 train every two hours - but Water ORton misses out on some).
Reports in here say the Brum services are overcrowded. Would be be possible to find paths, if stock becaime available, to make this service 3 trains per hour, with two doing most but not all stops (to give each station a minimum of 1 TPH), plus the fast to Stansted as now? That would also better serve Leicester-Coventry connections - not as good as a through service, but not too bad.
While the number of units would be a problem for the first couple of years once all the new coaches are delivered there should be more than enough units. Personally I'd be looking at keeping reasonably long turnaround times at both Leicester and Hereford to try and keep trains making their path at New Street but if this can be achieved the Hereford service being extended to Leicester would actually be a very good solution to the lack of capacity.When the Hereford services went to Nottingham under Central Trains, the performance was poor, hence the reason it was split again. IMO i don't think extending the Hereford services to Leicester would be great, and do West Midlands Railway have enough units? I personally think that eventually the Hereford services will go to Moor Street via the Camp Hill line when that plan evolves. Let's wait and see.
