DarloRich
In other news, has testing been ongoing?
not on the Vale yet. The unit has been in the shed so there may be static training ongoing.
Believe the unithas been out on test, seen video of it leaving Bedford.not on the Vale yet. The unit has been in the shed so there may be static training ongoing.
Reputedly it was mentioned as SWRs' preferred option for Island Line in the October issue of Modern Railways. I can't answer definitively as I've not read it, but this article from March this year offers the following caveat:Has the "forum discussion" on another thread on whether or not the Class 230 units being under consideration for future use on the Island Line any definate statement of intent by the TOC that runs that line or is this just "forum chatter"?
https://www.londonreconnections.com/2018/third-ryde-tube-transfer-troublesome/
Vivarail’s refurbished ex-D78 trains have often been suggested as a potential Island Line rolling stock solution. Being approximately the same height as mainline rolling stock, they would require the trackbed in Ryde Tunnel to be re-lowered, but even then they might not be suitable. The 1973 stock driving cars are 17.47m long. The D78 driving cars are 18.37m long. So if a 1973 stock carriage is too long for Ryde Esplanade station, a D78 is even longer. Until someone performs a proper gauging exercise, it’s impossible to rule replacement vehicles in or out.
There were quite a number of factual errors in the article (guest author and not enough editorial checking), the comments below are much better including pointing out the author didn't know enough about the tunnels, the problem low beams underneath the roundabout having been removed and a proper gauging study having been done.Reputedly it was mentioned as SWTs' preferred option for Island Line in the October issue of Modern Railways. I can't answer definitively as I've not read it, but this article from March this year offers the following caveat:
I think you’re referring to the March article quoted within the above post #6582. Because that has been removed by the forum software it now looks at first glance as though you’re also commenting on October’s MR...There were quite a number of factual errors in the article (guest author and not enough editorial checking), the comments below are much better including pointing out the author didn't know enough about the tunnels, the problem low beams underneath the roundabout having been removed and a proper gauging study having been done.
They could be a solution for Island Line, but I'm pretty sure that to do so would require work to Ryde Tunnel - at present they simply wouldn't fit
They do fit, see the relevant thread. The beams in the tunnel have been replaced with narrower ones in recent years.
I was of the belief that the track level had been raised significantly to prevent tunnel flooding and that was the problem preventing anything taller than a subterranean unit operating? Isn't there a "hump" halfway through the tunnel that was the sticking point?
The "hump" was actually in the roof height due to the former beams.I was of the belief that the track level had been raised significantly to prevent tunnel flooding and that was the problem preventing anything taller than a subterranean unit operating? Isn't there a "hump" halfway through the tunnel that was the sticking point?
Correct I was.I think you’re referring to the March article quoted within the above post #6582. Because that has been removed by the forum software it now looks at first glance as though you’re also commenting on October’s MR...
It was that combined with the beams. With the beams narrowed mainline stock will fit as long as it doesn't clout the sides on the reverse curve, a problem D-stock won't have as it has very short vehicles (18m).
I believe PEP stock will also fit, though is unlikely to be used due to its condition.
Anyway, there's a thread for that!
If that's the case, gerremin! I can't think of many better candidates for the BEMU model to be honest - closed system, relatively long turnaround at each end for charging and a low-density timetable. There could be a case for the 3-car models too?
Putting new supplies for charging at either end should be cheaper than fully refurbishing the 650V third rail system.
but the heavy batteries you mention would be maintained by the TOC and not NR so has more of a hance than trying to find the money in NR budget to replace the 3rd railI find it very hard to believe that the whole-life costs of using heavy, expensive batteries would be any cheaper than renewing the 3rd rail infrastructure as and when necessary.
IMO it's probably suffered the same fate as all the other 'innovative' solutions proposed for Island Line, especially as recent reports about the 'costed option' by SWR and others made no mention of batteries while Heritage Railway supposedly reported that the 3rd rail would be retained.
