Can I return to the windows for a moment. According to various press reports, mainly the Croydon Advertiser, the windows fell out when the train toppled over. One passenger said they smashed.
"Fellow passengers on the early morning Croydon Tramlink service in South London told how one man was flung through a window."
"Rhys McCausland, 19, recounted the horror crash, saying his head was crushed against the ground as the tram windows smashed behind him.The teen said: "There was nothing unusual going on the tram. I had my headphones in sitting there in he middle. Going to Sandilands through the tunnel there was nothing unusual either. We go very fast through there on a regular basis. I didn't notice we were coming to a corner because I wasn't really paying attention. The next thing I knew the tram was rolling over on its side. There was no attempt to brake or anything like that. I rolled on my back. The glass has smashed behind me and my face rolled over the gravel. I was quite lucky not to be trapped like the others.He said the passengers were caught in the dark with rain pouring down on the wreckage.He said: "I could feel the blood dripping and I was in total shock about what happened."I have been getting on that tram nearly every day for four years. To realise it's on its side in pitch black you can't really believe it. Having no way out is the hardest."
Other passengers fell out - presumably no windows in place - and were trapped underneath the train. One survivor reported that he felt the train topple over and the next thing his hand was scraping along the gravel.
Another passenger, Rui De Sa, a builder on his way to work when disaster occurred at 6.10am, said: "One man beside me was screaming and had his arm trapped outside the tram as it skidded along on its side. He added: 'I was on my phone with my headphones on then we just heard screaming in the first carriage. That toppled over then we went over. It went black and we were all just thrown around. People were screaming and shouting for help. De Sa said once the train was on its side anything it hit was "like a blade'' through it.
Now I have read the trains had laminated glass windows, so did the windows just fall out or blow out?
Safety Standards Railways safety standards say laminated glass should be installed in all railway passenger vehicles. But the standards also seem to assume laminated windows will stay in place during a crash, which these did not. Does a light railway vehicle/tram count for these standards, or are they exempt? And if so why?
http://www.rssb.co.uk/Library/risk-...improvements-in-safety-in-train-accidents.pdf)
It says here that laminated windows which stay in place during a crash provide the best protection against injury as they stop people falling out. Clearly that was not the case here, as the windows either fell out or shattered. Should they? Otherwise what is the point in fitting them unless to to provide protection during a crash. Yet they were smashed/fell out on the side which hit the ground, when the train overturned. Was it the act of falling over which caused them to fall out/smash? And did they smash into small pieces or come out as individual panels.?
RSSB report in 2009
3.1.2 Passenger and crew containment
Analysis of train accidents that have occurred in the last 10 years showed that 20% of fatalities occurred through people being ejected through breakable windows (usually when a carriage has turned onto its side). If windows are strong or tough enough, they can prevent people from being ejected from trains during an accident. However, if breakable, windows can be used to escape from trains after accidents. The analysis showed that, if the breakable windows are replaced with essentially unbreakable windows (using laminated glass), then more people would be expected to survive accidents on those rare occasions when such events occur.
One consequence of having all laminated windows is that passengers would no longer be able to use windows for escape after an accident without the intervention of the emergency services. Further exploration of the accidents database, and consideration of an extensive review of emergencies on trains overseas (including fires), found no examples where a life has been lost, or would have been lost, because of an inability to get out through the window.
The research shows that either there is no imminent requirement to leave the train under the circumstances, or alternatively, there are better (and safer) egress routes through the bodyside doors and gangway ends. Indeed, a number of significant injuries have been sustained by people escaping from derailed trains through windows. Furthermore, most serious train fires arise from external sources; even after impact, laminated glass is generally retained in position and helps prevent fire from entering railway vehicles.
The conclusions that were reached in this work, presented to the ATOC Board and the Office of Rail Regulation (ORR), were: Risk analysis showed that it is important that the industry has a clear and consistent approach to escape as passengers seeking to break unbreakable windows would put themselves and others at risk; it was duly recommended that all hammers provided for breaking windows be removed, even on those vehicles with breakable windows.
Accordingly, the analysis supported an industry approach that passengers should be contained in a rail vehicle in the event of an accident, particularly when they overturn, and should not be encouraged to escape through windows at all.
All bodyside windows in passenger and train crew areas on new vehicles should be fitted with laminated glass and have a high degree of containment; consideration should also be given to the frame and mountings. Windows on existing vehicles should be considered for progressive replacement with laminated glass, but should always be replaced when broken, subject to cost-benefit analysis on refurbishment.
To facilitate the incremental fitment of laminated glass, train operating companies (TOCs) should remove hammers and alter signage such that the primary egress route, in the event of an evacuation being required, is recognised as being via the doors and gangways instead of breakable windows. In order to realise the full safety benefits of laminated windows, a consistent transition strategy should be developed and implemented across all TOCs.
All passenger trains built since 1993 have mostly laminated windows, but the research confirmed that the best approach was to dispense with all designated escape windows. The containment work in T424 (Requirements for train windows on passenger rail vehicles) has been developed into a series of measures for vehicle bodyside windows, including a comprehensive suite of test requirements. These are incorporated in GM/RT2100 Issue 4, which is currently undergoing industry consultation and is scheduled for publication in Spring 2010. The introduction of a common approach to escape is being coordinated by ATOC.
