But Darlington is over 200 miles from London and Nuneaton only 90.
You get direct hourly trains into London which take 75 minutes, plus some at the extremes of the day taking 60 minutes. This is quite a good service. Your only complaint really can be the stock used.
Why does Nuneaton warrant intercity stock with carriage end doors rather than Desiros with 1/3, 2/3 doors?
You can understand his point, since 2008 the train has been only 4 cars in length, and has to serve all those stations along the Trent Valley.
Originally it was timetabled via Northampton. So they went from an hourly 9 car fast service plus some odd extras, to an hourly 4 car desiro service via Northampton which at that time took a lot longer I understand.
Later, pressure from the Trent Valley or whatever lead to the trains being rerouted on the fast line, with 110mph modifications. Which was obviously an afterthought.
Now whatever anyone says about the worthyness of the Trent Valley stations to have a regular fast service, stations such as (Lichfield, Tamworth, Nuneaton and possibly Rugeley?) went from having some sort of regular daytime fast service to London with 9 car trains, to a 4 car via Northampton slow line service which was supposed to accommodate the flows from all those towns in one train together without any overcrowding.
Was that ever realistically going to happen?
Before long the service was upgraded to the fast line to make journey times realistic, bit the length of the train was never improved because of past decisions that the same service must serve local stations around Stoke on Trent.
Now it wouldn't take that much out there thinking and foresight to guess that the train would probably not cope with the needs of this route in the future as a 4 car.
Well Nuneaton is actually 107 miles from London Euston for a start and I was comparing Nuneaton with Darlington slightly ironically in case no one got that. I believe that I am right in saying that south of Nuneaton, a 110mph train effectively takes up 2 x 125mph paths, hence the MAIN need for 125mph stock as using 110mph stock actually reduces overall line capacity. A 125mph service, first stop Nuneaton would free up capacity, then it can use the slows (which are in fact pretty fast) to call at Tamworth and Lichfield then probably Stafford and Crewe. The solution of using 110mph stock is simply a fudge of a solution, it doesn't make sense. If you then add a stopping service via Northampton you cover all the requirements.
125mph stock for use on the Euston - Crewe service must be a no hoper now. With HS2 due in 2026, cant see the leasing companies purchasing any new tilting stock. And the 125mph and tilt would only be utilised as far as Rugby, and slow line running from there to Crewe wouldn't really justify the purchase and manufacture of new design tilting trains (the old 390 design is now not up to current new train regulations).
110mph is pretty good. As long as the trains are up to standard. I.e. refurbishment when needed, not running 350/2s in fast paths at max 100mph with 3+2 seating. And lengthening all workings to 12 car if necessary.
One thing VT could have looked at though, was stopping the 3 new Blackpool services at Nuneaton, potentially rather than Rugby. It wouldn't upset journey times as these services are yet to be established, and the fact they're not calling at Kirkham and Poulton would surely have meant a few minutes extra in the Trent wouldn't have been that much of a big deal.
Add to that the potential of the GNWR fast service calling at Milton Keynes and Nuneaton.
