J-2739
The FASTECH Project in Japan produced a Shinkansen set that could stop from 320km/h in under 4000m. Indeed they had one that could do it from 360km/h but that had air brakes.
Now that would increase the capacity on HS2!
Now that's what I call I-M-P-R-E-S-I-V-E!
Now if only HS2 got something like that...
![Icon Biggrin :D :D](/styles/default/xenforo/smilies/rfsmile/icon_biggrin.gif)
It depends on the type of train you are considering. S-Bahn trains in Germany have a high power-to-weight ratio and accelerate very well. However braking (not breaking) is much more gentle at least in the open sections. On the underground sections in central Munich braking is more similar to what one would expect on the London Underground. Swiss railways brake hard and late and my experience of the Paris suburban system is that braking techniques are more like ours. Acceleration depends on the power-to-weight ratio and it a bit dependent on the age of the stock - older trains tending not to have so much power.
German trains, like their cars, always have enough horsepower but the braking of longer distance trains is more dependent on the track layout on the approaches to the stations. Having said that continental administrations don't seem to be so concerned about SPADs...
...which may be one of the reasons why the UK railways are the safest in Europe by a country mile.
I agree with you on all those countries, from what I've seen, the Germans tend to vary in their braking distance, while the Swiss are so aggressive with their FLIRTs. I've always found the RER to look quite smooth when braking, albeit, close when braking. The other French railways are similar though.
They care about SPAD?? The level of concern may vary though, which is why we get different safety statistics for different countries.
From the videos I've seen on the internet, many of the commuter trains of some of Europe (Germany) and Japan (Yamanote Line) seem to pull out aggressively out of stations (except at points) and still be at c.100km/h when arriving at a station, followed by sharper breaking to a standstill.Is there any evidence that trains are driven more aggressively in Europe or Japan?
I imagine the same considerations would apply all over the world i.e. defensive driving, leaving something in reserve in case of unexpected low adhesion etc. Things are obviously different on closed underground systems where there is much lower risk of low adhesion.
Certainly my TOC's policy is "defensive" e.g. max 20mph at 200m from a red signal, including if the signal is at the end of a platform. It's also frowned upon to regularly use brake step 3 as this leaves you with nothing in reserve apart from emergency (and in the case of a heavy train the emergency brake step won't deliver any more brake force than step 3).
There is little incentive for drivers to drive aggressively. Timetabling is so tight it's impossible to make time up and if you slip through a station or SPAD your job is at risk.
Other than that, I see what you mean for the rest of your post
One of the numerous things that impressed me about Japanese railways was the speed with which they enter a station they are due to stop at.
On the main commuter lines around Tokyo a 14/15 coach commuter train would generally arrive at the end of each platform at
100kmh stopping usually just short of the platform end. Thats pretty much double what most UK trains would do ('enthusiastic' drivers excepted!)
I suspect they have a form of semi automation to do this plus no issues with adhesion despite being there in autumn and on occasion in drizzly conditions. The quality of their permanent way is an eye opener.
That's always impressed me also.
They use a form of D-ATC, which I guess helps.
