If they can't negotiate a simple extension to Glasgow, there is no chance of Aberdeen
why not? XC probably doesn't want Glasgow as theres zero revenue, but could there be a lot more from ORCATS if they get to send their HSTs up to Aberdeen instead?
I'm a fairly regular traveller from London to inverkeithing and occasionally aberdeen.
It is frankly nonsense to argue that these trains are well loaded with through passengers. This market was lost by the mid 90s to air.
Are the EC services to ABD extras, or do they run instead of the normal ScotRail runs?
Not the case with the 14:55/14:52/14:48 (annoying how it got earlier and earlier), that always got between 25% and 50% through travel either side of Waverley (at least on Fridays). The same with the 10:30 ex-King's Cross. The 05:55 happened to be in a commuter slot for Fife to Edinburgh, so it's only to be expected. It's also worth remembering that through passengers have the heaviest luggage loads, and with Aberdeen Airport being quite hard to access (1 or 2 buses per hour from the city) and Dundee Airport being the size of an aircraft carrier, it would mean a lot of luggage problems at Waverley, to say nothing of clogging up the Turbostar doorways (HSTs are difficult enough). Whoever came up with this notion has obviously never been north of Edinburgh himself (probably never north of Potter's Bar).
The high-end figures for passengers passing through Edinburgh are about the same as for Newcastle. Does that not mean that many trains should be cut back to Newcastle? Of course not. :roll:
XC don't even want use all the HSTs they have, preferring Voyagers. I doubt they'd want more.And if those 15 sets were given to XC to supplement their 5, could 20 HST sets run XCs core Plymouth to Edinburgh Waverley (via Leeds and Newcastle) and with the extensions to Inverness and Aberdeen?
I think there could be something in what b0b says, we've discussed at length the reasons why XC might not want to take over Edinburgh-Glasgow, but ORCATS wise Inverness/Aberdeen must be a very different proposition. Couple of things I wonder though:
If the non electrified branches were taken off EC would they have enough 225 stock if all of their HSTs were taken away?
I've got a very interesting article from Modern Railways in about 1982 that deals with the internal use of HSTs in Scotland. Basically the argument was that the first inbound HST from the south got into Edinburgh only after quite a number of trains had departed for the south, so those sets at Craigentinny to form all these trains might as well be used on internal Scottish workings as much as possible before heading south, even if that 'only' meant commuters riding. Nobody seemed too bothered if the first Aberdeen > Edinburgh working mostly detrained at Edinburgh as what would the set be doing otherwise? Thus an HST provided a high capacity, high quality commuter working from Fife and Dundee, removing the need for a 27 + stock to be used at peaks only, and an additional Queen Street > Edinburgh working got slotted in, allowing the shuttle to be operated by 5 shove duff sets all day. Any through traffic from Aberdeen/Dundee/Fife/Glasgow/Falkirk to England was just gravy.
This seems to me to highlight two important points. (i) the better things that can happen when you think globally in a network, instead of pretending that 'ScotRail' and 'East Coast' are two separate things, and (ii) what an absolute farce and operationally restrictive nightmare the electrification of the ECML was and still is. I wonder what East Coast is doing with all the Electras that need to sit around to form all Edinburgh starters departing before the first inbound arrival from the Cross at 11:08. Not much I should think. This problem would be worse if it wasn't for the fact that the 10:20 Edinburgh departure started back at Aberdeen. An all electric ECML would require at least 7 sets at Craigentinny to work southbound before any incoming set from the south could be turned round for an 11:30 departure. The last few of these 7 would be pretty badly utilised.
As above, it was a mix to cope with both demand and in attempt to keep a two hourly service, the same as Glasgow - AberdeenAre the EC services to ABD extras, or do they run instead of the normal ScotRail runs?
The sets are used quite intensivelyI wonder what East Coast is doing with all the Electras that need to sit around to form all Edinburgh starters departing before the first inbound arrival from the Cross at 11:08. Not much I should think
I am not aware of that being the reason as there was already a Kings Cross - Inverness serviceIIRC the Highland Cheiftan came about when Scotrail (in the BR days) saw that Intercity had a HST that didn't leave Edinburgh until mid morning, and one that was idle from half four in the afternoon
There are virtually no spares at Edinburgh, as they rolling stock from Craigentinny is used for the first few departures prior to 08:00
The remainders are then at Polmadie for the Glasgow departures
The first northbound arrives at Glasgow and from 10:00 onwards everything else is utilised as they arrive
It doesn't appear to beIt's in this future scenario that I mean the utilisation would be poor
There was a WCML service from London (via Mossend)
At present three of the Edinburgh departures have to be HSTs in order to maintain the timetable
This reduces to just one, the number of 225s remains the same, simply moved from Polmadie to Craignetinny
The Clansman started off as a joint Inverness / Glasgow - Euston serviceThe Clansman. This was diverted via Edinburgh and Carstairs a couple of years after the Chieftain started, and dropped a few years after that. A very poorly utilised set which didn't do anything before its departure from Inverness at 10:30, required so as to connect with the first arrival from Wick and Thurso at 10:10
It's the same at any depot at the beginning of any day, trains are sitting awaiting deploymentAye but once they're moved to Craigentinny, they're idle until they're needed to operate from Edinburgh southbound. My point was more that electrification reduced the options for deploying Craigentinny-based sets within Scotland
However the Mark 3 coaches it used on the Inverness portions were required elsewhere and so was replaced by Mark 2 coaches and rerouting via Edinburgh (as it already stopped at Carstairs to split / join)
With sprinterisation the service ceased
One could argue that the early morning HSTs are Bounds Green could used on commuter services to/from Peterborough prior to working their intercity rostered duty
It used to happen in the past, but now passenger charters apply so the cost / revenue risks have to be assessed
I would therefore agree it is better to have at least one set available until all the daily trains are up and running
There is a steady flow of London traffic to the north aswell on these services, as there are the la-de-daas going to Gleneagles or Pitlochry, and the Skiers going to Aviemore, (try getting all that kit on a plane!).
I've posted full details before (search Mark 3B BFO)Did it? My 1985 timetable has it as a train going from Inverness to Euston without picking up any other portion. It doesn't even stop at Carstairs
