- Joined
- 14 Jul 2011
- Messages
- 18,649
I don't know if you've travelled on the Far North Line, but most services are well loaded. Most passengers are not tourists. The 10:41 Inverness to Wick with the 16:00 return is the most popular for those doing the tourist run, and one doesn't usually get more than 2 or 3 groups out of a well-loaded 158.
Well loading a handful of two car units a day is not really a great achievement or a resounding endorsement of the usefulness of the service.
Inverness to THurso by rail takes variously 3hr38-4h00 depending on the service.As stated before, the bus is faster Inverness to Wick, but not Inverness to Thurso. The bus does not serve everywhere that the train does.
The X99 bus Inverness to Thurso takes approximately 3hr28 according to the published timetable.
And no, the bus doesn't serve everywhere the railway does, the bus serves place where people actually live.
(There is even a bus service in Lairg that could easily be extended to Tain to connect with the X99)
Irrelevant, the stations that generate substantial quantities of traffic are ones served both by the bus and the railway.Coaches are not objectively slow. It can't be surprising that a detour of an hour inland (Tain to Golspie) by the railway as compared to the newer road route in addition to the 30 minutes detour via Thurso of Wick passengers leaves the coach with a significant advantage.
Just because the railway has a terrible routing should not be counted against the bus - because there is not going to be money available to correct the mistake of the railway's builders.
This would significantly add to the congestion of the road. Which is not a good idea. New buses would have to be introduced to places that see their railway service cut which do not currently have bus services (see the entire section from Helsmdale to Halkirk). The road infrastructure does not exist in that area. So money would need to be spent on upgrading roads and building new ones. The small subsidy does not cover this.
Between Helmsdale and Georgemas Junction (the nearest station to Halkirk) the stations are:
Kildonan - 76 passengers
Kinbrace - 464 passengers
Forsinard - 2160 passengers
Altnabraec - 356 passengers
Scotscalder - 200 passengers.
So apart from possibly Forsinard the stations will produce one or so passengers per day on average.
Even Forsinard only manages a half dozen.
And there is a road between Helmsdale and Forsinard so if the loss of Forsinard is such a disaster you could have an Optare Solo run up and down between those villages and connect to the X99.
But even so when you can only produce 3200 passengers per year over many miles of track, there is something of an issue.
Buses cover Tain to Inverness 25 minutes faster than the railway can.As stated before, end-to-end journeys are not and should not be the only consideration. There is significant flow from Tain to Inverness, and patronage justifies an increase in a service from there. An annual patronage of over 30k per year with gaps in service of over 3 and a half hours is pants.
50 minutes versus ~76.
EDIT:
To make it clear, I am not anti railway as such.
But as it stands the railway really doesn't justify the resources required to keep it open.
It needs a journey time that is easily faster than the coach to be worthwhile at all.
Sub 3 hours or we might as well go home.
Perhaps tilting units or somesuch, and closing or gating every level crossing.
