I see a little bit but that's to be expected when my resolution is 3840x2160I don't understand why people are talking about white space, I'm not seeing it on 1920x1080.
We will not be providing 'Tap To Talk' assistance at the moment as there are more pressing things to be getting on with, but it is on my list
The adverts at the top and bottom of the page always used to appear whether you were logged in or not. There was one advert that was made to look like a post, this Ad only appeared if you were logged off but does not exist at all at the moment.But whenever I used to log in, they would disappear. Now they don't.
https://www.railforums.co.uk/members/paul-sidorczuk.9957/followingSorry if this has already been discussed, but under the previous vBulletin system, there was a section that showed all your contacts/forum friends in a four-column alphabetical list order and there was another small section that showed the number of forum friends you had (I had 589 at the last count) plus the number of members who had visited your profile page (mine showed a figure of 7718 last time I saw it).
Has the same information been transferred across and where do I find this information in this new system?
Right, I just haven't noticed them before.The adverts at the top and bottom of the page always used to appear whether you were logged in or not. There was one advert that was made to look like a post, this Ad only appeared if you were logged off but does not exist at all at the moment.
What is the black dot that appears before some threads on the index page
Having just updated mine I look forward to seeing what you/my good friend Google make of it!I like that you can click on someone's location and it brings up a Google Maps result of it.
This has amusing effects for Mojo's location - and others hahah!
If you click it then you'll be taken to the first unread post.
Yes that is supposed to work that way.I also get taken to the first unread post when I click on the thread title... is that how it’s meant to be?
Some help is available at the link at the bottom of the page. We will endeavour to provide more over time.Im looking for a 'help' section , or 'What to do if you want to ....', or a page that tells us what the symbols mean and a simple glossary and definitions of items etc
(Happening with IE11, Firefox 52 and Chrome 61 running on Windows 7)
Will any member who only uses Tapatalk have any difficulty in making postings now?
Sat on a train, posting from my iPad using the web interface, it is improved enough that I no longer wish to use Tapatalk, which itself isn’t that good anyway.
I’m impressed with this update. Altogether much nicer to use. Thanks and well done to the forum staff for their choice of software.
yep, that works. Another great feature as it stops an entire page being rendered unreadable because of one large image. This on chrome via Android.Something that I've just noticed may be a feature, based on this post is automatic image resizing - I assume that this works on all mobile as well? Here is a large picture off wikipedia to check
It also shrinks the images down when they're quoted so quoted images won't make it even more unreadable!yep, that works. Another great feature as it stops an entire page being rendered unreadable because of one large image. This on chrome via Android.
It also shrinks long quotes as well so a huge wall of text doesn't get duplicatedIt also shrinks the images down when they're quoted so quoted images won't make it even more unreadable!
Yes as there is no separate mobile site so viewing an a mobile you get full functionalityCan you insert a photo using the mobile site..?
