Perhaps a tad cynical. The timing of this announcement - if the report turns out to be accurate - seems unrelated to any election campaign. In fact, if there is delay resulting in future cancellation, that is more than likely to come in the next General Election period. So I suspect that this is a genuine programme. Whether this is the right programme will, of course, keep this board in posts for a good few years yet.Politics. All trying to win votes.
What improvements?
Didn't they have it reviewed, and cost to benefit ratios showed that the MML was vastly better an option? So why would you choose GWML unless there was another motive?
Bad news for the MML then if it's confirmed that the electrification proposal for the MML has been cancelled.
A coalition source said that recent improvements to the MML route meant that electrification was no longer a priority.
What improvements?
Surely if anything, the MML ought to have had the line from Bedford to Sheffield via Derby electrified together with Kettering to Sileby via Corby which would offer a diversionary route avoiding Leicester and then have the line from Sheffield to Doncaster, Sheffield to to East Midlands Parkway via Nottingham and Sheffield to Wakefield Westgate electrified which would mean East Midland Trains could run though services between Sheffield and London by using either the Nottingham or Derby route.
Also means that the the Corby services could transfer to the Thameslink franchise by means of extending some Bedford services and XC services would be able to use the wires from Edinburgh/Glasgow all the way to Sheffield before using diesel power to continue.
However it is good that the Manchester to Liverpool route is being wired up, just require London Midland to keep their 350s and not cascade any to TPE with TPE instead going for a AC version of the 444 for their Manchester to Edinburgh services and the existing 185s being used to bolster their other services.
It is also good that the GWML is being electrified but I don't agree with the MML being cancelled to permit the GWML to be done, I can see the GWML being done from Paddington to Bristol Temple Meads via Bath Spa and to Bristol Parkway via Didcot being done first as well as the line between both Parkway and Temple Meads being done before the line to Plymouth and Cardiff, if Swansea will be done I believe it will be down to the WAG to provide funding for Cardiff to Swansea.
Care to explain? Or are we into the "too many bridges and steep gradients" of another thread on the subject?I really dont know what to believe any more regarding the 'electrification' of the GWML, its a tricky thing to electrify.
The route enhancements to allow longer stretches of 125mph running, or 110mph where that's not possible, is what it's principally referring to, plus there's also the MMLs' not-quite-total-HST-replacement fleet of Meridians.
I've not been able to find anything official on the areas that will actually be upgraded to 125mph, but as far as i'm aware it's only going to be 20 or so miles south of Bedford.
Won't the Severn Tunnel be a bit of a problem? It gets very damp down there, and the clearances aren't all that good. Elsewhere, the fact that the line is a World Heritage Site might make it a bit difficult to replace some of the overbridges with limited clearance.
Heaspans are no longer used.Oh yes, and I hope they use gantries for the four-track sections rather than headspans.
Only for those looking for an excuse not to do it. There's nothing on the GWML that hasn't been electrified elsewhere.
There are no problems with the Severn Tunnel, especially not with the headroom. NR reported electrification of the tunnel as a non-issue to the Transport Select Commitee a couple of years ago, when they were discussing South Wales transport policy.
Furthermore, it most certainly is NOT a world heritage site, although an application has apparently been made, however NR have strongly objected - and I'd agree with them on that...
