GWR Intercity Express Train (IEP) initial diagrams & allocations
6 Sep 2016
Confirming that, oberservations at Bristol TM while waiting for a train to Exeter with some room; 1A22 HST. 1A23 800015/006, 1A24 800024/010 in that order.
Must of been swapped out, did note a subject to change was in order on my original post. Thanks for noting here too by the way, that diagram must've been swapped as it's definitely been IET operated before.
6 Sep 2016
Only IET Diagram for Sunday 24 December is:
Subject to change as usual, could be more likely this time due to the services terminating at Reading.
5A12 0914 Stoke Gifford - Bristol Temple Meads
1A12 1000 Bristol Temple Meads - Reading
1C11 1215 Reading - Bristol Temple Meads
1A20 1400 Bristol Temple Meads - Reading
1C19 1615 Reading - Bristol Temple Meads
5C19 1754 Bristol Temple Meads - Stoke Gifford
D1009
22 Feb 2012
Stoke Gifford
I wonder whether today may be one of the rare occasions when GWR HSS services actually have spare rolling stock?
6 Sep 2016
To sum up the January SX diagrams, here goes. The diagram numbers are not the actual ones. All the SX passenger workings listed underneath, by reporting number.
Firstly - the 180 replacement diagrams , 2 from 02/01/18 and 2 from 15/01/18. Meant to be first two, last two in date order but it could all change if no agreement with LTV drivers for the Oxfords is reached or the north Cotswolds station validation gets further delayed.
1) 1P80, 1W14, 1P25, 1D26, 1P32, 1W33, 1P47.
2) 1W12, 1P22, 1W23, 1P33, 1D34, 1P41, 1D38, 1P46.
3) 1K05, 1D15, 1P19, 1D22, 1P28, 1W29, 1P42.
4) 1D13, 1P16, 1W19, 1P29, 1W31, 1P45.
Secondly - the longer distance diagrams, all 5 car and everything is reset from 02/01/18. Start or end locations shown for the portion working.
5) 1A03, 1B12, 1L51, 1B40, 1L90, 1D41, 1P50.
6) 1A03, 1B12, 1L51, 1B40, 1L90.
7) 1C02, 1A10, 1B27, 1L65, 1C22 (TAU).
8) 1C02, 1A10, 1B27, 1L65, 1C22 (BRI).
9) 1A09 (TAU), 1B25, 1L71, 1C25, 1A33, 1B94.
10) 1A09 (BRI), 1B25, 1L71, 1C25, 1A33, 1B94.
11) 1C01, 1L48, 1C15, 1A23, 1B69.
12) 1C01, 1L48, 1C15, 1A23, 1B69.
13) 1L42 (CMN), 1B31, 1L68, 1C24 (BRI).
14) 1L42 (SWA), 1B31, 1L68, 1C24 (TAU), 1A37 (TAU).
15) 1L08, 1C06, 1A14, 1B37, 1L74, 1C26 (BRI).
16) 1L08, 1C06, 1A14, 1B37, 1L74, 1C26 (WSM), 2M70, 1A37 (BRI).
Then on 12th February the following should start;
17) 1L38, 1C13, 1A21, 1B59, 1L96.
18) 1L38, 1C13, 1A21, 1B59, 1L96.
19) 1B05, 1L52, 1C17, 1A25, 1B79.
20) 1B05, 1L52, 1C17, 1A25, 1B79.
Hope this is useful and apologies in advance for any typos.
So if I am not mistaken, that should be the following:
From January 2:
1P80 0559 Reading – London Paddington
1W14 0652 London Paddington – Great Malvern
1P25 0954 Great Malvern – London Paddington
1D26 1250 London Paddington – Oxford
1P32 1501 Oxford – London Paddington
1W33 1622 London Paddington – Great Malvern
1P47 1942 Great Malvern – London Paddington
1W12 0548 London Paddington – Worcester Foregate Street
1P22 0825 Worcester Foregate Street – London Paddington
1W23 1122 London Paddington – Worcester Foregate Street
1P33 1355 Worcester Foregate Street – London Paddington
1D34 1652 London Paddington – Oxford
1P41 1831 Oxford – London Paddington
1D38 1950 London Paddington – Oxford
From January 15: Subject to change
1K05 0609 ?Newbury? – London Paddington
1D15 0721 London Paddington – Oxford
1P19 0901 Oxford – London Paddington
1D22 1050 London Paddington – Oxford
1P28 1301 Oxford – London Paddington
1W29 1421 London Paddington – Worcester Foregate Street
1P42 1726 Worcester Foregate Street – London Paddington
1D13 0618 London Paddington – Oxford
1P16 0807 Oxford – London Paddington
1W19 0921 London Paddington – Worcester Foregate Street
1P29 1200 Worcester Foregate Street – London Paddington
1W31 1522 London Paddington – Great Malvern
1P45 1834 Great Malvern – London Paddington
From January 2:
1A03 0600 Bristol Temple Meads – London Paddington
1B12 0815 London Paddington – Cardiff Central
1L51 1056 Cardiff Central – London Paddington
1B40 1345 London Paddington – Swansea
1L90 1729 Swansea – London Paddington
1D41 2118 London Paddington – Oxford
1P50 2301 Oxford – London Paddington
1C02 0630 London Paddington – Bristol Temple Meads
1A10 0900 Bristol Temple Meads – London Paddington
1B27 1115 London Paddington – Cardiff Central
1L65 1356 Cardiff Central – London Paddington
1C22 1630 London Paddington – Taunton
1A09 0712 Taunton – London Paddington
1B25 1045 London Paddington – Swansea
1L71 1429 Swansea – London Paddington
1C25 1800 London Paddington – Bristol Temple Meads
1A33 2030 Bristol Temple Meads – London Paddington
1B94 2245 London Paddington – Swansea
1C01 0519 London Paddington – Swansea via Bristol Temple Meads
1L48 0929 Swansea – London Paddington
1C15 1300 London Paddington – Bristol Temple Meads
1A23 1530 Bristol Temple Meads – London Paddington
1B69 1745 London Paddington – Swansea
1L42 0730 Carmarthen – London Paddington
1B31 1215 London Paddington - Cardiff Central
1L68 1456 Cardiff Central – London Paddington
1C24 1730 London Paddington – Taunton
1A37 2127 Taunton – London Paddington
1L08 0458 Swansea – London Paddington
1C06 0830 London Paddington – Bristol Temple Meads
1A14 1100 Bristol Temple Meads – London Paddington
1B37 1315 London Paddington – Cardiff Central
1L74 1556 Cardiff Central – London Paddngton
1C26 1830 London Paddington – Weston-super-Mare
2M70 2134 Weston-super-Mare – Bristol Temple Meads
Joins 1A37 2127 Taunton – London Paddington at BRI
From February 12:
1L38 0759 Swansea – London Paddington
1C13 1200 London Paddington – Bristol Temple Meads
1A21 1430 Bristol Temple Meads – London Paddington
1B59 1645 London Paddington – Swansea
1L96 2029 Swansea – London Paddington
1B05 0645 London Paddington – Swansea
1L52 1029 Swansea – London Paddington
1C17 1400 London Paddington – Bristol Temple Meads
1A25 1630 Bristol Temple Meads – London Paddington
1B79 1845 London Paddington – Swansea
Bornin1980s
4 Apr 2017
Okay, which ones are currently running to Taunton? And will any be running to Taunton on or after January 2?
And when will any be coming closer to Exeter?
Even so they proved most useful and I managed to get a return journey from Paddington to Reading both ways on IET. Many thanks once again :)
TheAdelante
14 Nov 2017
I wonder how quickly the 802s will be introduced? The 800s have had a quite a speedy introduction.
Clarence Yard
18 Dec 2014
They got stopped after a couple of weeks of service. Not too sure why.
Problems with the software after joining. So the workings were quickly altered and everything going to or coming from west of Bristol went as load 10 with five locked oou. Hitachi are working on a fix as it required for 2nd January.
The 802 sets should enter traffic in July, depending on how the staff training works out. Delivery currently stretches until January 2019. Once the 9 car 800 sets start to arrive at roughly the same time as the 802 5 cars, there should be a rapid changeover in summer/autumn on GWR from 8 coach HST sets to 9 and 10 car Hitachi trains. Then it will slow up for the last few sets.
Dhassell
22 Mar 2015
Don't think they ever did split at Bristol TM in the first place tbh.
6 Sep 2016
They didn't until a few weeks later after the Taunton diagrams started. The set not in use was locked out of use after Bristol when it was then put back into use on the return at Bristol. The new diagrams will see them run to/from Taunton as a five car and then doubling up/splitting at Bristol.
Clarence Yard
18 Dec 2014
Sorry, didn’t make myself clear. Apologies. The problem was spotted before entry into service and Hitachi asked for a hold on join moves until they had sorted it.
Wilts Wanderer
21 Nov 2016
I might be wrong but my sources tell me that there will be no short Paddington-Oxford workings for the time being, so the posted diagrams are definitely wrong in places.
jimm
6 Apr 2012
Clarence Yard's original post did make clear there were various qualifications around the Oxford/Cotswold diagrams - station validation has now been done, but the local rail user group was told by GWR a few weeks back that initial diagrams from January 2 might be these two
rather than introduction of the two diagrams on January 2 and two more on January 15 in the order given above.
I'd say it's a safe bet that the diagram starting with the 0559 from Reading will be an 800, as three-car Turbos lacking selective door opening can't call at the two-car platforms at Combe and Finstock if working the 16.22.
It may be wait and see as to which of 1W12 etc or 1K05 etc is covered, but both of them do involve some short workings from Paddington to Oxford and back, assuming that an agreement with the drivers has been reached - I assume that involves dotting the i's and crossing the t's about driver-only operating procedures.
Clarence Yard
18 Dec 2014
It was the DOO agreement (or lack of) that will determine what trains the single units will actually run. Even if there has to be a carve out of the Oxfords on 2nd January, hopefully it won’t be too long before they are back in.
Andy Pacer
11 Jul 2017
Leicestershire
Should be relatively the same as post #562, with some slight changes in timing due to the limited service into Pad. Whereabouts do you want to see one?
Thanks, just anywhere between Reading and Paddington. I’ll be mainly looking for HSTs but would be nice to get an 800 ride in too.
Wilts Wanderer
21 Nov 2016
It's also possible to separate N Cots from Oxford services with a layover set at Paddington for 50 min turnarounds rather than 20 mins. So you may find those diagrams are cut up with Turbos / HSTs working the Oxfords and 800s on the longer workings. It is almost 100% certain that the Oxfords won't be 800s in January as even if a late agreement is reached, there has been no training of LTV crews on the new stock and HSS crews have no agreement for DOO operation of any kind. I understand that temporary diagram arrangements are in place to get GWR through to May timetable without any agreement but beyond that the alternative rolling stock runs out.
jimm
6 Apr 2012
If that's the case and assuming two IETs and sufficient trained staff are available from Tuesday, then perhaps something like this
EDIT Friday am - just realised this won't work due to the extended journey time of the 13.55, with 15 minutes or so sat at Evesham and Oxford, so it passes the 16.22 just outside Paddington.Hopefully this and time sitting around going nowhere in other services will be addressed in the January 2019 timetable, to standardise journey times on the route.
1P80 0559 Reading – London Paddington - assuming this leg will be worked by an HSS link driver
then
Second one does involve a long layover at Paddington but on the four initial indicated diagrams there is no IET departure running past Oxford on to the Cotswold Line between its arrival from Worcestershire at 12.28 and the 14.21 departure.
Either way, the 16.22 has to be nailed on for an 800, wherever it comes from - unless GWR wishes to further antagonise passengers who were crammed into a two-car Turbo for the week before Christmas, though one might also say that when it comes to matching stock to demand, the 06.52 duty also needs an 800. The 180s could be full and standing on this service between Didcot and Oxford.
TheAdelante
14 Nov 2017
Hi,
In the new GWR timetables there are no H signs. Only a black square which in the key is said to mean:
Bike reservations are compulsory.
First Class accommodation, seat reservations, Wi-Fi and power points are available.
If there is one of these black squares does this assure an HST or IET?
I ask because in the timetable there is one of the London to Newbury trains marked down as one - could this possibly be an IET?
jimm
6 Apr 2012
It assumes an HST or IET when one is available and there are staff to work it - we already know that there are likely to be some Turbos on Cotswold Line duties that have the black block above the column for the first couple of weeks of January, pending delivery of two more Class 800s - and it sounds like that could well be the case for some London-Oxford workings as well if LTV (London & Thames Valley) drivers have yet to be trained on IETs.
Someone may know whether any Berks & Hants series are meant to convert to IETs before May but until the reversing siding at Bedwyn is extended there won't be many.
sw.trains.hs
4 Jun 2017
Hi guys, my local station (Cheltenham) currently gets served by the Cheltenham to London Paddington service and I was just wondering if the IET’s will operate this service or if not, if they will come at all and on which service??? Thanks
JN114
28 Jun 2005
IETs expected on these services spring/summer 2018
