Is a medical fail the end?
Layaboutlarry
30 Jan 2013
England
Hi,
Im hoping someone in this helpful site can help me, I was wondering if you fail tour medical with one toc, would it be a fail accross the board abd therefore end with you being blacklisted (so to speak)?
The reason I ask this is my brother had gone for two different interviews with bus companies and fail the medical due to his vision at one bus company but passed at another but just wondered whether it would be different.
Thanks in advance
TDK
19 Apr 2008
Crewe
Hi,
Thanks in advance
If it is vision you are concerned about a trip to the opticians prior to applying and asking them to do the Railway Group Standards eye test would clear that one up.
455driver
10 May 2010
Tell your friend to google "ishihara test" and see (sic) how well they do, somebody posted a link on here and I got every one right, it is supposed to be effected by your screen settings but I got them all correct on my laptop (which is all over the place) and my desktop which is somewhat closer to normal.
Here it is-
http://colorvisiontesting.com/ishihara.htm
156441
30 Aug 2011
Manchester
To add to the above. The RGS standard for eyesight should your optician not know is....
Visual acuity
a) distance vision at least 6/9 in the better eye and 6/12 in the other eye, with spectacles or contact lenses if worn
b) if a person is dependent on contact lenses to meet these requirements, spectacles of an equivalent prescription shall be carried when on or near the line
c) no pathological condition of the eyes likely to cause visual impairment should be present
d) the use of tinted or photochromic prescription spectacles is permitted, subject to the requirements of sub-paragraph (c).
Mojo
7 Aug 2005
Do they still do the Ishihara test? When I had my last medical about 15 months ago it had been replaced with a more modern test involving boxes flying around on a computer screen. Might vary by company as my first medical for a Toc did have one...
benno79
15 Jul 2013
I was worried whether my sight met the requirements but I took the rgs standard paperwork with me to the opticians and I was fine. I also did both the isihara test and the "boxes" test and there were no problems.
I also got my current employer to pay for the test as they are required to do so because I use a vdu.
If you going to go through the arduous process of becoming a driver I can't think of anything worse than failing at the final hurdle. Getting the test done really put my mind at rest and then you know for sure one way or another.
BestWestern
6 Feb 2011
Visual acuity
Is there not a requirement for a standard of uncorrected vision also, i.e. with lenses/specs off if you wear them?
benno79
15 Jul 2013
yes it's
Where spectacles or contact lenses are used, uncorrected visual acuity shall be at least 3/60 in each eye.
BestWestern
6 Feb 2011
benno79:1570874 said:
yes it's
Thought so, thanks!
alex17595
15 Mar 2013
Burton on Trent
Is that the thing with circles on? I did that for my medical in the beginning of August.
158Driver
28 Nov 2013
Just as a side question, does bupa give a report back to the TOC or only if the medical is failed?
parsons16
19 Oct 2012
Not sure if this is any help to you but I failed a medical in 2008 but re-applied again last year as my condition had improved and got the job this year, so I suppose it depends what the condition is you have and how much the TOC considers it a problem.
Belgini
29 Mar 2013
Anybody know what the psychological phase entails? This has now just been brought in.
