craigybagel
- Joined
- 25 Oct 2012
- Messages
- 5,082
Use of 230s on Crewe-Shrewsbury* would only be short term (if done) until all the units are needed for the 2tph to Bidston.
*(Only seen this idea discussed here: Crewe-Chester is the one mentioned in official press releases)
Indeed, I should have made clear I was referring to 170s instead of 230s on Crewe - Chester, using units from a pool that would also cover the HOWL. There has been no mention anywhere of what will be used for Crewe - Shrewsbury, that one is a mystery. Given that at present Crewe - Shrewsbury and Crewe - Chester both require 1 unit each I would have thought it much more sensible to use a 230 on Crewe - Shrewsbury and a unit more suited to high speed and passenger comfort on Crewe - Chester, rather then the reverse that appears to be planned, but we shall see.....
