Megatrain Bristol to Waterloo @ 1551
hantsman1205
11 Nov 2011
NRE States this route ends at Paddington then you get the underground to Waterloo, megatrain doesn't mention the underground , I assume NRE is correct but does the megatrain reference cover you for the underground?
StarCrossing
27 Jul 2015
When are you travelling? The 1551 is direct to Waterloo, but isn't running at the moment due to engineering works around Bath.
Mojo
7 Aug 2005
Megatrain between Bristol and London is only available on the South West Trains services that run between Temple Meads and Waterloo.
Kite159
27 Jan 2014
West of Andover
If it was megatrain wouldn't it put you onto the 15:51 SWT service from Bristol to London Waterloo via Westbury (as in not the quickest route from Bristol to London)?
hantsman1205
11 Nov 2011
Sorry guys, I'm looking for next February, the megatrain journey at 1551 is the only one direct to Waterloo but its slightly slower.
dzug2
5 Feb 2011
You are not making sense - the megatrain site says there are no Bristol to London rail trips at the moment.
If you go to Paddington it's on FGW to which you have the option of adding an underground leg to Waterloo. Megatrain doesn't enter into it
bb21
Emeritus Moderator
4 Feb 2010
Booking isn't even open for next February so there is no guarantee any seats would be available.
Where does it say that?
This is what NRE says about Megatrain:
http://www.nationalrail.co.uk/times_fares/pr1862e8e02343bea84256c05efaa18f.aspx
Available on selected journeys with the following train operators:
  • East Midlands Trains
  • South West Trains
  • Virgin Trains
Megatrain covers you to the station detailed on the itinerary you are provided with, and that will not include London Underground.
The Megatrain site isn't letting me look beyond 23 October, on this date all Bristol to London journeys are showing as by bus.
NRE does not sell any tickets, let alone Megatrain tickets.
You can only view or purchase Megatrain tickets on the dedicated Megatrain/Megabus website.
Hadders
27 Apr 2011
Your mis-understanding the route.
If you click under 'view' on the megatrain link you've given above you will see that you catch a train from Bristol Temple Meads to Bath where you change for a South West Trains service to Waterloo.
Although the train from Bristol does go to Paddington you have to get off it at Bath.
hantsman1205
11 Nov 2011
Many thanks, got it now. :D
James H
25 Jun 2014
No - it's a direct SWT train, calling at Bath Spa. FGW trains don't enter the equation.
Hadders
27 Apr 2011
So it is - at first glance it looked as though you had to change at Bath although I see it's just a call on the service.
I wonder why they haven't added in all the other stops that train makes...
Mojo
7 Aug 2005
Because Bath is the only place on that service you can get Megatrain from, apart from Bristol.
dharkhig
18 Aug 2014
Yes - but not on the train from Bristol. Different times.
Probably depends what's left. You can certainly do the reverse journey by Megatrain to Salisbury on the through trains terminating at Bristol&Exeter.
