A lot of articles keep making a point of how the new trains are capable of up to 100mph. Will the timetable be recast for shorter journey times when they’re introduced? Im not expecting them to because of the other services on the line but it’d be great if they did.
Road learning and also traction training for those who still need it.There's a Northern 158 at Chester now .Guess that's for road learning.
Barring a short section near Warrington that's too short to be of much use, there isn't any section of track with a speed higher then 90 that this new service will use.
And capable of accelerating faster? Which is rather more relevant in Northern-land.That’s what I suspected. The max speed of the trains is basically irrelevant on this line then and the only benefit of them is that they’re brand new so in better condition.
0 - 90MPH is faster in a 158 than a 195. A 195 is slower to 100MPH than a 170.And capable of accelerating faster? Which is rather more relevant in Northern-land.
Given that a 3-car 195 will have circa 300hp more than a 3-car 170, that's difficult to believe. Are they really that much heavier / poorly geared?0 - 90MPH is faster in a 158 than a 195. A 195 is slower to 100MPH than a 170.
The latter. The 172's also suffer from the same issue.Are they really that much heavier / poorly geared?
I'll find the figures later. It's the initial acceleration that fools you.Have you got a source for this? It seems very different to what most people would expect - and any time I've traveled on 172s they seem far better at acceleration then 170s....
It is roughly 20 minutes quicker, including a 14 minute wait at Victoria.Yes, but how many will want to go Chester-Rochdale or Bradford-Warrington (I don't think either route has had a through service before).
Also I suspect Chester-Leeds will be quicker changing to TPE at Victoria.
Think some people will use it because they don't want to change trains even if the direct service takes longer
True, if it was only 20 minutes I’d use it. Another classic is Trowbridge to Worcester. There is a slower direct train but you can also save 30 minutes by changing at Bristol and Cheltenham. That said, with changes, you have an increased risk of arriving late if one of the trains is disrupted.
The 175s have good acceleration at most speeds. Going out of Crewe they are doing 90-95 at Sandbach and coasting at 100 a few seconds later.Have you got a source for this? It seems very different to what most people would expect - and any time I've traveled on 172s they seem far better at acceleration then 170s....
Also, over at TfW we have one 158 (158834) with a bus style transmission. Granted, it's a 4 speed DIWA rather then the 6 speed ZF fitted to 172s, but it's also notable that acceleration on this unit is much better then on the rest of the 158s, albeit with the catch that it's not at all smooth, especially when transitioning from coasting to taking power at speed.
Whoops! I'll get my eyes tested.I suspect your GPS needs calibrating - the linespeed is only 85 as far as Sandbach!
I travel from Ellesmere Port to Bradford fortnightly to watch Bradford (Park Avenue) and don't use the train for home matches as it takes about 3.5 hours to do 58 miles (as the crow flies, 73 miles by road) with multitudinous stops. The new service will help but I'll still have to go via Hooton and Chester as the timings don't fit with the footy. However the early E. Port - Leeds working might be useful for cricket at Headingley and at least I'll get a seat.
On a less self-centred note, TfW Chester - Warrington - Manchester trains are often seriously overcrowded and a half hourly service is urgently needed. And it is quite right that these should alternate between Piccadilly and Victoria as these offer very different connections.
It is rather weird that the Calder Valley is getting through services to Chester but not as yet the promised links to Piccadilly and the Airport which I thought were the prime purpose of the Ordsall Chord. It shows that the the Calder Valley it is still well down the pecking order.
Is this service actually starting in May? I can see Northern have published all the new timetables but can't see this listed anywhere
