No working toilet on the train.
Krokodil
23 Jan 2023
Wales
Supposedly some Councils have been attempting to prosecute it as littering. Which is a bit dubious for #1, but I can see the point for #2 whether human or dog.
Damage to stonework has been a concern in some areas. I don't suppose that those councils had usable public toilets available?
infobleep
27 Feb 2011
There was an item on TV the other day about lorry drivers being cautioned/arrested for having a P (edit: not P as in parking!) in lay-bys. A little harsh if there's no facilities provided I thought. A few years ago during the stack-ups to/from Dover ferry port they were all having to do it as service areas were all closed due to lockdown.
In this country anyone would think relieving oneself was some sort of optional entertainment, not a biological necessity. It defies belief.
What was outcome? A fine? Court apparence?
Zamracene749
11 Dec 2005
East Durham
Not true, look at the relevant legislation:
My underlining. The law requires intent to be proven.
That's a relief (literally) to hear, I suspect what my policeman m8 was getting at is that an arrest is possible, even likely. I suppose the proving of intent etc would perhaps come later in court?
Krokodil
23 Jan 2023
Wales
There's also the common law offence of "outraging public decency" which doesn't require that the offender intends someone to see it (so long as at least two people do). Discreetly urinating into a bottle is not going to get a conviction on that charge.
inkyadrian
1 Nov 2011
The various TOCs, must stop at a railway station when there are no toilets working on any train. A suitable station, with toilets, should be chosen by the guard and class it as an 'L' stop.
Krokodil
23 Jan 2023
Wales
And when no station (with unlocked toilets) exists? On some routes it's easily possible to be an hour between staffed stations.
MichaelTrains
9 Jun 2022
Bradford
The last WBQ to LDS had no working toilet tonight. A journey time of just over two hours.
Completely disgraceful from Northern.
That assumes that the said station doesn't refuse to unlock the toilet (cough, Maidstone East, cough).
infobleep
27 Feb 2011
What about trains that have toilets out of service but the stock is being used on a route that usually has rolling stock with no toilets?
You also get routes where they use to be toilets but then due to wider rolling stock issues they switch to units with no loos on board.
I also got caught out once when thr last train of the night from Waterloo to Guildford was a class 455 and booked to be so as standard. I wasn't expecting it as all other train were either 450 or 444. There may also have been one 458. All of which have loos.
I joined it either at Vauxhall or Clapham Junction.
Zamracene749
11 Dec 2005
East Durham
Dumping sewage onto tracks is horrible for trackworkers. Toilets should of course be serviced and available. But, with my risk assessment head on, perhaps allowing a tank to overflow for the last few hours of a diagram onto hopefully remote tracks that may not be visited by a worker for weeks? vs Punters and carriage cleaners having to deal regularly with train interiors that have been urinated on? Thoughts?
gabrielhj07
5 May 2022
Herts
Or even just send stuff from the sink overboard.
43066
24 Nov 2019
What on earth is an “L” stop?
It’s certainly possible for trains with u/s loos to make stops to access toilet facilities, albeit these are usually just longer dwells at scheduled stops, with passengers requiring them being requested to make themselves known to the guard in advance.
Krokodil
23 Jan 2023
Wales
Only where those faclities exist. You can easily be an hour from an open station toilet.
duffield
31 Jul 2013
East Midlands
At the very least, retention tanks should have an emergency "dump to track" release under staff control for use in defined circumstances (such as a lengthy stranding).
Wolfie
17 Aug 2010
Given that raw sewage is legally a biohazard and disposal of such items is very tightly legally controlled that idea is fraught with all sorts of complications. The amount being dumped in one location would be vastly more than the old flush to the tracks toilets. A TOC who permitted it could find themselves facing a very expensive clean up job.
Disregarding that for the sake of discussion l also assume that the other problem in your proposal would likely be how long the train water tanks lasted in such a scenario.
185
29 Aug 2010
TFW doing the same sending 2-car sets on 3 hour journeys to Manchester with one toilet that locks itself out.
The solution is retrofitting bioreactor toilets. They becoming proven in Europe and only require water, and empty only water onto the track with the err... compostable brickettes being emptied every two-three months.
Goldfish62
14 Feb 2010
That's what the 701s have. Pity they're not actually in service, but that's for another thread...
I guess it also comes down to whether they're being locked out due to the waste tank being full or the clean water tank being empty. If the latter, non flushing urinals could save a lot of water.
infobleep
27 Feb 2011
Well the 19:29 Gatwick Airport to Reading service tonight has no working loo.
I boarded it at Redhill unaware of this. Even Journey Check doesn't mention it. That obviously requires someone to inform someone and someone to have time to do the update. The Journey Check Web site can be found at https://www.journeycheck.com/greatwesternrailway/
Fortunately I should be OK to reach Guildford. Apart from Reigate, no other station has loos, as they were all closed years ago, assuming they all had loos, usually when the station buildings were demolished.
IanXC
Emeritus Moderator
18 Dec 2009
There's no "must" about it - TOC's choice.
I'm fairly sure 'L' stop has no meaning.
Old Yard Dog
21 Aug 2011
Still at least the loos at Liverpool Central and Chester won't be so gross any more.
The new toilets at Liverpool Central are suffering from teething problems (see other thread under Infrastructure & Stations) while those at Moorfields (the old ones at least) are also often closed and even when not, require staff to open them. The toilets on the main Lime Street concourse are the best bet for Wirral Line passengers.
The only toilets currently open at Chester are outside the gate so passengers changing trains have to go through the barriers twice.
Starmill
18 May 2012
Bolton
Yes it's disappointing agreed, but they also couldn't stay as they were in either case because they were foul. So hopefully both will be fixed shortly...
johntea
29 Dec 2010
I was on a Leeds - Manchester Victoria 195 the other afternoon where the toilet was seemingly out of action and the guard sorted out a pit stop at Hebden Bridge for anyone wanting to spend a penny
Even those who didn’t need to spend a penny ended up potentially earning a penny as it then meant a 15 minute delay repay claim :D
Can the broken toilet be sorted at a larger station (say Leeds) prior to departure or is it a depot job only?
Wolfie
17 Aug 2010
I guess that it depends why the toilet is out of order. If the water tank is empty it could be topped up at a station l guess. If the retention tank is full then specialist facilities are required to empty it. If there is another defect then who knows - most likely though is a repair when the unit is back at depot.
