Northern Class 170's
superkev
1 Mar 2015
west yorkshire
Northerns 3 car 158s would look a good match for the Harrogate line as they would get out of 1st gear. The slow to accelarate 170s more suitable for flatter and faster lines.
K
PomWombat
1 Jul 2018
I agree. But the 158s are less suitable for my knees so I'm hoping they don't start up a whole new random unit generator
northernchris
24 Jul 2011
K
The 158s aren't suited to the Harrogate line with their end doors though. The dwell times would increase and so would late running
Class455
19 May 2016
This morning the usual Class 170 on the Selby-Leeds route was replaced by a refurbished Class 158. Anyone know if this it temporary, or whether the 170s have moved on?
It’s probably due to a shortage of 170’s especially as one is on loan to TPE each day for the time being
superkev
1 Mar 2015
west yorkshire
The 158s particularly the handfull of 400hp ones are Northerns quickest dmu so the increased station time may be made up elseware.
From Rail express magazine 0 to 60 times are 158 350hp 98seconds, 170 114sec, 156 124sec.
K
Harvey B
11 Mar 2019
I don't know if this has been brought up before but what are the current routes that these units currently run on. Just need to double check if they run to York via Cross Gates.
northernchris
24 Jul 2011
The 170s operate the Leeds - Selby services and one comes off Neville Hill for the 1743 Leeds - York
Harvey B
11 Mar 2019
Only one service via to York Cross Gates? I would have thought there were more going to York via that Route. Are Leeds to York via Harrogate, Leeds to Selby, the late peak service to Doncaster and the 1743 Leeds to York via Cross Gates the only services the 170s run on at the moment ?(excluding the TPE service)
Adam0984
18 Feb 2014
Yes there’s one 170 Leeds to York via Garforth at 1743 all the others are generally 158s as they interwork with the York to Preston trains.
The other routes the 170 are on is Leeds to York and Knaresborough Via Harrogate, 0657 Doncaster to Leeds and 1757 back (booked a 321 but regularly turns a 170), Leeds to Selby and from the timetable change some of the Sheffield to Bridlington trains
Harvey B
11 Mar 2019
Thats a weird allocation for a 170. I guess the units may have to run an ECS move from Leeds to Sheffield every day but I think the wiser thing to do is either run them on a service that terminate at doncaster (Which is what they are doing already) then run it on an ECS to Sheffield or run it from Leeds to sheffield with passengers.
clagmonster
8 Jun 2005
I have seen mutterings that there may also be some York - Hull services worked by them. That would seem a cunning way to swap them in and out of Hull. The alternative is the Hull - Halifax when they start, as they are I believe effectively extensions of the already 170 worked Selby - Leeds.
Harvey B
11 Mar 2019
Both those routes could also work for the 170s to switch between Leeds and the Brid to sheffield route.
darloscott
12 Dec 2013
Stockton
There is a Hull-Leeds via York & Harrogate each way per day to swap the 155's in and out of Leeds so these could logically change to a 170 and be used to rotate the 170s. Am I right in thinking 155s will no longer work in and out of Hull at all?
61653 HTAFC
18 Dec 2012
The plan was for all 7 155s to work local services around Hull and be based there. Plans may have changed though.
Harvey B
11 Mar 2019
I think something like this would be ideal for a 170 to switch lines. They could also run the 170s to York via cross gates to allow them to switch on to the Bridlington to Hull to Sheffield workings. Or the other alternative is run them to Sheffield so they can switch on to the Sheffield to Brid services there.
Geeves
6 Jan 2009
Rochdale
The plan has indeed changed and the 170s should be going onto the Hull - Sheffield and Leeds - Nottingham work and coming off the Harrogate lines... Apparently.
More 158s are needed for the Barrow and Windermere work from May onward.
darloscott
12 Dec 2013
Stockton
I thought I saw a post suggesting they weren’t able to reach Lincoln? This would preclude them from working the Nottingham’s unless they interwork those with other services?
Geeves
6 Jan 2009
Rochdale
I think that might be another old wives tale as they have been there in Central trains days, unless things have changed since then ?
Harvey B
11 Mar 2019
What about working Leeds to Selby? Will that still be 170's?
matacaster
19 Jan 2013
Huddersfield
Was on a 170 today, Hudds -> Wakefield. Big improvement over 142, particularly impressed by seating which is reasonably comfortable and general ambiance.
greyman42
14 Aug 2017
Some York - Hull services are already operated by 170s. I don't know if these services are planned for 170s or if they are just standing in.
NoMorePacers
18 Feb 2016
Humberside
Can anyone say what the refurbished Northern 170s are like? I would like to know before they come onto services around Hull. Thanks.
61653 HTAFC
18 Dec 2012
Agree with @YorkshireBear that this will be unusual, as platform lengths/occupation at Huddersfield is a problem for the Wakey shuttle. Kinda wish I'd managed to bag a 170 on that!
Harvey B
11 Mar 2019
This is rare a Northern 170 at Huddersfield that is actually running a Northern service for once so i'm guessing that 170 must have been on worked a Transpennine Express service between Leeds and Huddersfield to get down there.
Which bears the question are you sure you wasn't on a transpennine Huddersfield express to Leeds service operated by a Northern class 170?
