Schnellzug
So if the point is that the guard can keep an eye on the platform until the train is clear, in case anyone gets caught in the doors, tries to grab hold of it of it or whatever, surely having to stand by a closed door (since you can't move off with a 158 until the doors are all closed, can you?) is not really a very helpful way of doing it, is it? for a start, you can hardly see anything, and if you did, there wouldn't be anything you could do, would there? Apart from pull the Emergency stop. I'd have thought looking out from the cab window, where you could give the driver an emergency signal to stop, would be more useful.To clear this up once and for all
On all Diesel traction the doors MUST be closed from the rear and we stand by the doors until the end of the set/sets has cleared the platform
The doors can be OPENED from the front but not CLOSED (in other words once opened walk to the rear of the train and close doors from there)
If a set is locked out of use the doors are worked from the rear of the Train IN USE
Class 323's doors can be worked from the middle as there are no GRAB RAILS on the unit.
There ya go
but heavens, I wouldn't want to question Management decisions.
