Failed with no power this morning.A pair of shiny new ones at Preston this morning, just before 8. One on the parcels platform (010} and another on P1 (004, if car numbers match)
Not sure what the exact fault was, but it could not be used.Thanks for the explanation. Why couldn't the other pantograph be used?
Still no resolution to the never working seat reservations, which seems to be related to either the short turnrounds at Euston or joining sets at Chester
As evident by the 10 car run from EUS.... yes. Even with one gen set out on one of the units. Takes a while to get going, but they do get there.
No. The TMS is hard wired for 125 mph max. Its up to the driver to set the TMS speed limiter to the required lower value as appropriate.
Such alterations to the TMS software require funding & development. Which isnt available. Its still a pipe dream, but speeds higher than 110 will be needed if the MU speed profiles are ever introduced. Which would in theory make any amendment to speed set now be temporary & therefore definitely not worth the expense.Might be an idea to have it default to 110 mph when logging in since it can’t be turned off.
Especially when you remember that the majority of trains in the UK have no form of speed limiter fitted at all - and of those that do most only cut off at the maximum permitted speed for that unit and don't take into account if the line speed is lower.Such alterations to the TMS software require funding & development. Which isnt available. Its still a pipe dream, but speeds higher than 110 will be needed if the MU speed profiles are ever introduced. Which would in theory make any amendment to speed set now be temporary & therefore definitely not worth the expense.
Sticking to 110 isn't the issue. Its the places where significantly lower speeds are absolutely essential, but where drivers have been used to proceeding at much higher speeds on one single type of traction. Its interesting your take on the traction/road knowledge side of things & its something I have pondered. Some drivers (a decreasing number) cut their teeth on tap changers & class 90s & progressed to 390s & 221s. They had little problem adjusting to the new differential speeds that were introduced in fits and starts & eventually became very long stretches of contstant thrash. There are now a significant number of drivers that never experienced the switchover to EPS & also rarely have to drive to PS speeds due to fleet reliability. It is going to be interesting to see how drivers cope with a brand new speed profile that is different again from PS & requires far more speed step downs & step ups utilising a more maximum effort style of driving than the more defensive approach taught. But then I guess thats why they have been "traditionally amongst the highest paid". Its a slight tangent, but it is part of the bigger picture of introducing the 805 & 807 along with the possible prospect of MU speed profiles.Especially when you remember that the majority of trains in the UK have no form of speed limiter fitted at all - and of those that do most only cut off at the maximum permitted speed for that unit and don't take into account if the line speed is lower.
If what are traditionally amongst the highest paid drivers in the industry can't be trusted to stick to 110 without computer intervention, that would be very concerning. And I say that as a driver with 6 different tractions on their card with 4 different top speeds to remember.
"all it requires" = expense. It wont happen unless the DfT order it.It might do - but all it requires is the default setting on login to be 110. It should still be able to be increased to 125 in the normal way. For example if a driver logs out and a new driver logs in on changeover it defaults back to 125. It could be 110 to make things simpler.
The speed limiter permanently on setting was part of a TMS update.
Indeed, which is why I don't believe a 110 limiter is necessary - drivers should be picking up the knowledge of where the speed limit is 110 (be that as PS or MU or whatever) and acting accordingly, the same as they should with any other speed.Sticking to 110 isn't the issue. Its the places where significantly lower speeds are absolutely essential, but where drivers have been used to proceeding at much higher speeds on one single type of traction. Its interesting your take on the traction/road knowledge side of things & its something I have pondered. Some drivers (a decreasing number) cut their teeth on tap changers & class 90s & progressed to 390s & 221s. They had little problem adjusting to the new differential speeds that were introduced in fits and starts & eventually became very long stretches of contstant thrash. There are now a significant number of drivers that never experienced the switchover to EPS & also rarely have to drive to PS speeds due to fleet reliability. It is going to be interesting to see how drivers cope with a brand new speed profile that is different again from PS & requires far more speed step downs & step ups utilising a more maximum effort style of driving than the more defensive approach taught. But then I guess thats why they have been "traditionally amongst the highest paid". Its a slight tangent, but it is part of the bigger picture of introducing the 805 & 807 along with the possible prospect of MU speed profiles.
Whilst PS speeds are part of the route knowledge MU speed profiles are not known to drivers on the WCML. The boards remain firmly covered (& will probably do so for a long time). Further to this, the MU speed profiles will interfere with the existing approach to PS speeds as the step downs happen at different locations to where a train doing PS would. Every driver that signs 805/807 traction will be required to re learn the entire speed profile which apparently involves 80 odd changes. I too hope the transition is smooth & it was suggested introducing MU speeds in predictable stages. Maybe one day we will see.Indeed, which is why I don't believe a 110 limiter is necessary - drivers should be picking up the knowledge of where the speed limit is 110 (be that as PS or MU or whatever) and acting accordingly, the same as they should with any other speed.
I am sympathetic to the challenges of having to follow speeds they rarely used in the past - we went through a similar process with new traction at our place where we had to use PS speeds that never applied with our fleet before, but it turned out to be surprisingly easy in the end. I think most of us picked up these new (to us) speeds at the same time as learning that new traction. I hope the folks at Avanti find the transition similarly smooth - especially as it's knowledge they should have already held for those rare times tilt wasn't working - though ideally they'll be learning the MU speeds instead of PS as soon as possible!
The TMS on the 390 is hard wired to produce a warning the moment 127 mph is reached.Eventually ETCS where installed will provide absolute speed supervision. Today, the biggest overspeed risk is very low speed TSRs on high-speed track and diverging switches where the turnout speed is much lower than the main route. Indeed recent incidents at Peterborough prove the point. The only reported incident of gross overspeeding above 125mph resulted in a blanket 125mph limiter being fitted to Hitachi 80x units, but I'm not aware of any other 125mph capable trains having a limiter fitted.
Now that does sound challenging alright. Good luck to them, though I'm sure they're all well capable.Whilst PS speeds are part of the route knowledge MU speed profiles are not known to drivers on the WCML. The boards remain firmly covered (& will probably do so for a long time). Further to this, the MU speed profiles will interfere with the existing approach to PS speeds as the step downs happen at different locations to where a train doing PS would. Every driver that signs 805/807 traction will be required to re learn the entire speed profile which apparently involves 80 odd changes. I too hope the transition is smooth & it was suggested introducing MU speeds in predictable stages. Maybe one day we will see.
67s allegedly do - if I remember correctly it's something like power off at 128 and brakes dumped at 130. I say allegedly as I doubt many have tried! The existence of this has amused me ever since I first found out about it....Eventually ETCS where installed will provide absolute The only reported incident of gross overspeeding above 125mph resulted in a blanket 125mph limiter being fitted to Hitachi 80x units, but I'm not aware of any other 125mph capable trains having a limiter fitted.
Yep, correct.Realtime Trains | 5Q23 0820 Merchant Park Sidings to Oxley Car. M.D. | 26/03/2025
Real-time train running information for 5Q23 0820 departure from Merchant Park Sidings to Oxley Car. M.D. on 26/03/2025. From Realtime Trains, an independent source of train running info for Great Britain.www.realtimetrains.co.uk
Assuming that’s 805002 being delivered then.
The very final 805 to be delivered. Only 807009 & 800710 for the yet to be delivered Everos now.Yep, correct.
A friend of mine signs the whole ECML from Kings Cross to Edinburgh and has to remember all the limits, signals, slow line speeds junction speeds platform entry speeds. In addition to the classroom time, a minimum 300 hrs supervised driving is required before someone is qualified to drive alone. That is a lot of training!Whilst PS speeds are part of the route knowledge MU speed profiles are not known to drivers on the WCML. The boards remain firmly covered (& will probably do so for a long time). Further to this, the MU speed profiles will interfere with the existing approach to PS speeds as the step downs happen at different locations to where a train doing PS would. Every driver that signs 805/807 traction will be required to re learn the entire speed profile which apparently involves 80 odd changes. I too hope the transition is smooth & it was suggested introducing MU speeds in predictable stages. Maybe one day we will see.
The iPad for LNER to best of knowledge does not display speed limits etc.A friend of mine signs the whole ECML from Kings Cross to Edinburgh and has to remember all the limits, signals, slow line speeds junction speeds platform entry speeds. In addition to the classroom time, a minimum 300 hrs supervised driving is required before someone is qualified to drive alone. That is a lot of training!
It is crazy however that in this day and age, we don't have some sort of signal and speed limit indication in the cab as standard by now + and I mean just a simple indication - a system without intervention - just displaying upcoming speed limits and signal aspects. Though I think LNER drivers have iPads that might display some of this info.
In addition the Tractive Effort on Class 390 is automatically ramped down to zero over the speed range from 125mph to 127mph. This feature was introduced after a train was clocked at 135mph as exiting a tunnel in the early years of operation with Tilt/TASS isolated. Provision to revert to 140mph maximum speed is provided by a hard-wired input to the Traction electronics.Whilst PS speeds are part of the route knowledge MU speed profiles are not known to drivers on the WCML. The boards remain firmly covered (& will probably do so for a long time). Further to this, the MU speed profiles will interfere with the existing approach to PS speeds as the step downs happen at different locations to where a train doing PS would. Every driver that signs 805/807 traction will be required to re learn the entire speed profile which apparently involves 80 odd changes. I too hope the transition is smooth & it was suggested introducing MU speeds in predictable stages. Maybe one day we will see.
Yes, correct. 807009 and specially liveried 807010The very final 805 to be delivered. Only 807009 & 800710 for the yet to be delivered Everos now.
807006 in service today in 1416 EUS to BHM805006 to enter service soon
805002 delivered to Avanti 12mins ago
807009 and unique liveried 807010 yet to be delivered
Pretty sure 006 has been in service since the back end of last year807006 in service today in 1416 EUS to BHM
It's 805006 that's not yet entered service, not 807006.807006 in service today in 1416 EUS to BHM
13th of December from a quick search, but perhaps they mean 805 006Pretty sure 006 has been in service since the back end of last year
Easily done! Hopefully one of the fleet gets some sort of update that causes them to become /1's in the future13th of December from a quick search, but perhaps they mean 805 006
Arguably the main thing anyway is that an additional new train is in service - a positive either way even if an 805 rather than 807!Easily done! Hopefully one of the fleet gets some sort of update that causes them to become /1's in the future![]()
Is 805006 in service today? Nothing allocated on RTT and the service listed above (1416 EUS-BHM) is actually 807006Arguably the main thing anyway is that an additional new train is in service - a positive either way even if an 805 rather than 807!![]()
Post 3773 shows confusion with classIs 805006 in service today? Nothing allocated on RTT and the service listed above (1416 EUS-BHM) is actually 807006![]()
Any word on 807005 entering service yet?It's 805006 that's not yet entered service, not 807006.
Easy mistake!![]()
So it is 807006, which entered service late last year, with 805006 still to appear?Is 805006 in service today? Nothing allocated on RTT and the service listed above (1416 EUS-BHM) is actually 807006![]()
