Progress on Avanti West Coast's 805/807s Hitachi AT300 sets
Scotrail88
21 Jul 2014
I assume you mean run at EPS speeds rather than 125mph as the train is capable of 140mph.
I read that as May the 22nd rather than May 2022! ;)
@Scotrail88 apologies if that is what you meant
Yes - May 2022 was the intention.
Was thinking that if they are in build now, then hopefully 6 months for the first to arrive and training to commence. Next May should be realistic for some to enter traffic.
Not sure if been spoke about, or worthwhile elsewhere but be good for capacity for the Voyagers to be cascaded - my wish is cross country but hope to hear plans soon
There have probably been dozens of separate threads here about future WC Voyager use. Certainly far too many to list...
hexagon789
2 Sep 2016
Then yes, May 2022 seems perfectly reasonable. Apologies for the misunderstanding earlier, I totally read that as the calendar date rather than year!
just saying, if it could be done, surely Hitachi could mode the 805/807 design to be able to tilt so they wouldn't need to slow to 110 for most of the trip
Don't know about Hitachi, but Alstom talk about a high-speed design which can tilt.
The DfT spec for IEP definitely didn't request a tilt option, so it wasn't offered.
Adding tilt for the UK gauge is certainly not trivial.
Aictos
28 Apr 2009
Strictly, it's between Carlisle-Carstairs-Edinburgh for the ECML diversions.
But LNER operates a regular Edinburgh-Carstairs-Glasgow Central leg as well, so the whole WCML route north of Carlisle must be cleared.
TPE has also run 802s on test on parts of the WCML in the northwest, but I'm not sure they covered the whole route north of Crewe.
I wouldn't say a daily service is a regular leg, regular leg I believe is more then 1tpd.
Unit allocations to service groups will be rejigged.
As others have pointed out several times 807s will operate London Euston to Liverpool Lime Street & Blackpool North (and some Birmingham New Street) services. This will release some voyagers (leaving franchise) and some 9car 390s which be cascaded to run the Euston - New Street - Scotland services releasing more Voyagers (leaving franchise). There will be no 807 running on the ECML north of Preston.
805s will replace voyagers directly on the Chester, North Wales and Shrewsbury services, running on electric south of Crewe/Wolverhampton.
Just to point out that Preston isn't located on the ECML but rather the WCML, unless you're confusing Newcastle with Preston?
hexagon789
2 Sep 2016
They make ones that tilt for Japan, I'm sure they could do it but it would be interesting to see how straightforward it would be to fit such a design into the GB loading gauge.
Wapps
1 Jul 2020
The “Class 80T”.
The “Class 80T”.
craigybagel
25 Oct 2012
could the standard 800 series design be modified to tilt in order to be able to achieve 125?
Could it be done? Probably.
Is it worth the extra cost (both in terms of the upfront extra build cost of the units and the ongoing costs for the extra maintenance and fuel/electricity to move all the extra weight? Probably not, given the choice Avanti have made.
221101 Voyager
17 Nov 2019
Milton Keynes
If the WCML ran at 140mph then tilt would've been worthwhile, as one, 390s would've been used to their full potential, just like a tilting 80x would've done.
Also has the first 805/07 been built yet?
gallafent
23 Dec 2010
A tilting “A-train” was definitely on the cards at one point (though not for the UK, instead for Taiwan) more than a decade ago (from links from the wikipedia page, for example the link below).
The profile of the UK AT-300 bodies feels far too spacious to fit into the UK loading gauge if it tilted, so they'd definitely be a very different beast from any of the A-trains that have been ordered for the UK so far.
So for some definition of “could”, then yes, but the “modification” would be very deep!
Taiwan tilting Hitachi train testing in 2006
Hitachi, Ltd. is now going underway of designing and manufacturing limited express tilting trains for Taiwan Railway Administration (TRA). Its delivery will start at the end of 2006, and total 6 units (48 cars) of tilting trains will be supplied by the end of 2007.
The tilting train is the "A-train" with 8 car vehicles (4 motor cars and 4 trailer cars). Its car body shell is the distortionless aluminum double-skin structure utilizing Hitachi's Friction Stir Welding (FSW) technology. Moreover, the state of the art VVVF inverter units will be provided for the propulsion system.
The tilting system is the controlled-type tilt (maximum 5 degrees tilting angle), which enables to pass the sharp curves quickly and comfortably.
Owing to Hitachi's rich and advanced technologies on tilting trains, travel time between Taipei - Hualien is expected to be shortened after this train is in service.
Hitachi is boosting up railway system business in Taiwan by this tilting train project.
hexagon789
2 Sep 2016
I'd say it could be done, but to a price
On this point I agree, it's not.
Partially, 140 was as I understand, only ever going to be on the southern section of the WCML so less curvaceous and you wouldn't do 140 on the curviest bits anyway.
Both financial and in passenger comfort. 80x don't have a tilt profile so are a bit wider than they would be able to be if they did tilt.
With HS2 coming and so motivation to work towards no-tilt 125 north of Crewe at least, tilt just doesn't make sense any more.
hexagon789
2 Sep 2016
Indeed, the bodyshell would need 'trimming' which would likely cost more and like you say - reduce passenger comfort through reduced space internally.
Quite, what might be better is a small programme of improvement works to straighten/re-align some sections or take out the worst PSRs that sort of thing - so there was more running at the higher limits or less need to reduce speed heavily and build it back up again etc
Wyrleybart
29 Mar 2020
South Staffordshire
How much is "most of the trip" ?
I guessing there are less than a dozen locations between Euston and Birmingham that actually require a non tilt 125mph train to actually slow to 100mph or less IF non TASS trains were allowed to start with. .
800001
24 Oct 2015
Some shells have been delivered to Newton Aycliffe, but not sure how progressed those are now, nor if the rest of the fleet will be using imported shells or N.A. built ones
Avanti shells that were Delivered to Aycliffe are sat with no work started on them. Only EMR and First East Coast units are currently under assembly.
Domh245
6 Apr 2013
nowhere
That's surprising! The Avanti units were all due to be in service by 2022, with the EMR units entering service in 2023 - dates will have obviously slipped around a bit, but I still would have expected to see Avanti units ahead of the EMR ones. Thinking out loud, I wonder if the EMR units at the moment are (a couple?) of pre-series units with the main production to occur simultaneously/after the avanti units?
hexagon789
2 Sep 2016
Iirc only about 40% of the Avanti unit bodyshells are to be manufactured in the UK, allowing for that they might not be as far behind as it seems possibly?
I did see something to the effect that 70 shells of the Avanti order would be welded at Newton Aycliffe.
That leaves 65 to be welded elsewhere (Kasado or Pistoia?).
Those numbers might mean the 807 fleet will be locally built, or there might be another mix.
Domh245
6 Apr 2013
nowhere
I'm more surprised that EMR units are progressing ahead of the Avanti units than the slippage compared to the original plan, though given a couple of weeks ago we saw that the first EMR shell had been welded together (bar cab section) it may yet be the case that it's still further behind those delivered shells
hexagon789
2 Sep 2016
Either that or things have swapped? Though is that possible given how these things are usually fixed in terms of order.
greatvoyager
15 Aug 2019
Exeter
Would EMR units need more build time as unlike the 805/807, they aren’t using the same body shell as the original class 800?
Domh245
6 Apr 2013
nowhere
I shouldn't imagine that the 'build time' (as in hours at each assembly stage) would be significantly different to a normal 800, but the first few through will no doubt be slower as they check and adapt processes (and validate the design!)
greatvoyager
15 Aug 2019
Exeter
That makes sense.
Dazzer390
23 Apr 2021
South Carolina
Whilst I'm looking forward to the new trains, I'm going to miss the voyagers. Rode on a few a few years ago but at least they're keeping the Class 390.
Dazzer390
greatvoyager
15 Aug 2019
Exeter
Dazzer390
I will too, but it will be nice not having so much diesel under wires.
Also, welcome to the forum :D
Dazzer390
23 Apr 2021
South Carolina
Thanks. Yeah it would be nice not to have a lot of Diesel under the wires, but again, I'm used to riding the Class 390s.
Dazzer390
Dazzer390
They're not vastly different in ambiance to 390s but do benefit from slightly bigger windows. I'd take one over a Voyager, at least legroom is generally good.
